FLAP DRIVE / MOTOR FAILURE
alexander_rodriguez(at)YA
PostPosted: Mon Aug 03, 2009 3:21 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
part number: 9234c120-r7 Motion
Dear all,
After intermittent failures the flap drive finally quit working. After searching through the message board and also catching up with the Vans community it seems to be a frequent problem with these motors. Our question to you is now: Is there an alternative part or newer version (read not from Motion or where the problem is remedied) for this drive, and possibly avoiding drilling new holes in the fuselage? Quick answers would be super nice.
Thank you.
Visit - www.EuropaOwners.org
Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
Dear all,
Thank you.
Alexander
kheindl(at)msn.com
PostPosted: Mon Aug 03, 2009 4:37 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
Alexander C
I can't help C but as far as I know the statistics for the motor are very good. But I think now that I will always carry a spare with me C ordered from Europa.
The other reason for this reply is : what is the best way to do a flapless landing ?
I tried it in the early days C but gave up because of the nose high attitude.
Karl
Dear all C
After intermittent failures the flap drive finally quit working. After searching through the message board and also catching up with the Vans community it seems to be a frequent problem with these motors. Our question to you is now: Is there an alternative part or newer version (read not from Motion or where the problem is remedied) for this drive C and possibly avoiding drilling new holes in the fuselage? Quick answers would be super nice.
Thank you.
Alexander
ronics.com
ww.matronics.com/contribution
ami(at)mcfadyean.freeserv
PostPosted: Mon Aug 03, 2009 10:37 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
<<...Quick answers would be super nice...>>
Try cleaning the commutator; needs doing every 100hours or so and cures
intermittent operation.
Duncan McF
See article in archives.
Do not archive.
PostPosted: Mon Aug 03, 2009 9:35 pm    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
[quote:7884966cb3="mcfadyeanda"]
<<Quick>>
Duncan McF
Do not archive.
-----[/quote:7884966cb3]
Yes, it seems to have been the thing to do. Cleaning the commutator as one can find in the message boards here and for Van's. However, we had a failure after 54h engine time. Is not encouraging and also makes me wonder about the long term performance. We would like to go long distances and something like failing when setting up for a short field landing with no other field around is not my preference. I called Europa yesterday and they actually offer a different part now for approx. 380EUR. incl. an adapter plate. OK, there is an alternative, unfortunately with a hefty price tag. So, I still look around for some other solutions...
paul.the.aviator(at)gmail
PostPosted: Tue Aug 04, 2009 4:20 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
Hi Alex,
If you Google "Linear actuators" I suspect that you will find a lot of suitable replacements.  Take a look at http://www.firgelliauto.com/
Regards,  Paul
PostPosted: Tue Aug 04, 2009 10:52 pm    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
[quote:5f16f77796="paul.the.aviator(at)gmail.co"]Hi Alex,
Regards,  Paul
[/quote:5f16f77796]
Thank you Paul,
I just do not know enough technical specs about the original system to decide on a different actuator. I could not find anywhere the spec's of the original motor and actuator. I emailed Motion System and we are in touch but not much further. I was also wondering if somebody has the brand and spec's of the new actuator that EUROPA ships now. I had a look at the builder's manual but all I have is a picture without spec's. See the attachment. Anyone and idea what they ship and what is written on the engraving plate?
http://www.europaowners.org//zfiles/actuator_442.jpg
PostPosted: Wed Aug 05, 2009 5:11 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
Hi Alex,
I have a Europa Monowheel and it has a manual push rods for the flaps.  At one time I did seriously consider converting my Europa to a conventional tail dragger and I purchased a Motion Systems actuator based off the recommendation from Bob Berbue.
I can go to my hanger and go and check its specifications if you would like me to, however I used the information from Bob which may or may not be the same as what Europa factory specifies.
I assume that the part / model number has been removed from your actuator ?
One more suggestion, you might like to contact Bob Berbue at Flight Crafter's and ask him, or, perhaps put a note on the forum to the guys that have conventional tail dragger's and ask them what actuator they used.
Let me know if you would like me to go check the part number for the actuator that I have.
Paul
bdanbish(at)gmail.com
PostPosted: Wed Aug 05, 2009 8:50 pm    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
I show it as:
Motion Systems
Ball Drive Actuator, 85615
4.00" Stroke, 15:1 Reduction
12VDC 7400 -RPM Motor
Cover Tube with Seal
Rod End TM-4
Type C Gearbox Housing, 1/4" Dia Std
This is directly off my invoice - paid US$235.00 plus freight.
Motion Systems - 600 Industrial Way West - Eatontown, NJ 07724
732-222-1800 phone
732-389-9191 fax
PostPosted: Thu Aug 06, 2009 7:26 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
Just don't tell them that it is for an airplne otherwise they won't ship it to you. - Paul
On Wed, Aug 5, 2009 at 11:52 PM, danbish <bdanbish(at)gmail.com (bdanbish(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: "danbish" <bdanbish(at)gmail.com (bdanbish(at)gmail.com)>
I show it as:
Motion Systems
Rod End TM-4
732-222-1800 phone
732-389-9191 fax[b]
PostPosted: Thu Aug 06, 2009 11:13 am    Post subject: FLAP DRIVE / MOTOR FAILURE Reply with quote
Yeah, forgot that part. In fact, even though I bought this back in 2007, I seem to remember having concocted a "I need this to automatically open a gate for my poor old grandmother who's in a wheelchair" story.... too bad they never asked, Laughing
