Odyssey battery PC 625
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
cdewey6969(at)yahoo.com
PostPosted: Fri Jul 31, 2009 8:22 am    Post subject: Odyssey battery PC 625 Reply with quote
Are people still using the Odyssey battery PC625 in their Lightnings? Wondering if there is a better battery out there. Ours doesn't hold a charge, but is a couple years old. Charles
--- On Fri, 7/31/09, Jim Langley <pequeajim(at)gmail.com> wrote:
Subject: RE: More new EFIS and carb options
To: lightning-list(at)matronics.com
Date: Friday, July 31, 2009, 9:37 AM
Brian:
Their EFIS is a built by MGL
and in that form is called the
Enigma.  It has been around for about 4 years and you
are right, it is an awesome
package for the money.  I have the MGL Voyager (next
step up),  in my Lightning
which is in the Arion booth, so if anyone wants’ to
see what it looks like in
the Lightning panel, feel free to stop by.
[mailto:owner-lightning-list-server(at)matronics.com] On
Behalf Of Brian
Whittingham
Sent: Friday, July 31, 2009 8:23 AM
Subject: More new EFIS and carb
options
All,  I'm not trying to get
you interested in a new aircraft, but there's a company
that comes from the same background as myself called MySky
One.  What I'd really like to point out is that
they trust the Jabiru 3300 for their aircraft and they have
a couple of instruments that look pretty good.  Take a
look at the MSFAS and MSFIC: http://www.mysky.aero/flight-information-center--lsa-mysky-aircraft-msone-FIC1.html  Now I can't say
that I have experience with using this system, but it might
be worth a look for some of those who have not decided what
to put into your panel yet.  They also have developed a
carb and mixture control for the Jabiru.  I'm not
sure if that was the one that was talked about on here
previously or not, but they have over 70 hours on their
plane so it has some time on it and also might be worth your
while to check out!  Thanks, Brian
Whittingham
Windows
Live™ SkyDrive™: Store, access, and share your
photos. See how.
   http://www.matronics.com/Navigator?Lightning-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
- The Matronics Lightning-List Email Forum -
Wayne Lenox
PostPosted: Fri Jul 31, 2009 10:14 am    Post subject: Odyssey battery PC 625 Reply with quote
Charles
I use a Odyssey Battery 925L, It works great. Also have been using four odyssey 2150's in my motor home and love them.
Wayne L
Lightning N123WL
fly.lightning(at)gmail.co
PostPosted: Fri Jul 31, 2009 12:46 pm    Post subject: Odyssey battery PC 625 Reply with quote
I have an Odyssey PC 625 in my airplane (the engine is a Rotax 912).
I think they produce very high quality batteries.
I installed the battery new in 2005 and it has performed flawlessly
ever since. It started my engine without any hesitation after sitting
6 months in an unheated hangar.
This kind of battery (sealed lead-acid, AGM) is known for its ability
to keep a charge for a long time. I would measure the current
directly at the battery (remove the positive lead and insert an
ammeter) to determine what load is on the battery when all equipment
is supposed to be off.
It may be that there is some external reason for the battery's discharge.
Best Regards,
Hugh Sontag
Qdea Technical Support
Subject: Odyssey battery PC 625
Date: Fri, 31 Jul 2009 09:20:14 -0700 (PDT)
kayberg(at)aol.com
PostPosted: Fri Jul 31, 2009 5:17 pm    Post subject: Odyssey battery PC 625 Reply with quote
One of the aviation magazines has a circuitboard for a de-sulfinator.  It is about 20 bucks and can be assembled in an evening. I have been using one on an Odessy batery that would not hold a charge and it is working.
They are not a deep cycle battery and can sulfide up with a couple deep cycles.
That is about your only alternitieve to a new batt.
Doug Koenigsberg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
