Posted: Wed Jul 29, 2009 5:20 pm Post subject: Lyc oil pump ADs? |
Can anyone remember if there's an AD on the Lyc 320/360 oil pump or
drive gear after the the one in '96 requiring a return to steel pump
gears? That's the last one I can find.
Charlie
mrobert569(at)hotmail.com Guest
Posted: Thu Jul 30, 2009 2:56 pm Post subject: Lyc oil pump ADs? |
Charlie C
The one in 96 is the last one out.
Mike Robertson
Das Fed
[quote] Date: Wed C 29 Jul 2009 20:15:23 -0500
To: rv-list(at)matronics.com
Subject: Lyc oil pump ADs?
--> RV-List message posted by: Charlie England <ceengland(at)bellsouth.net>
Thanks C
Charlie
_=====
Windows Live™ SkyDrive™: Store C access C and share your photos. See how.
Kellym
Posted: Thu Jul 30, 2009 4:52 pm Post subject: Lyc oil pump ADs? |
Be careful. The compliance date was July of 2001. I'm sure there are
engines out there that still haven't complied, because of confusion over
that AD that was revised more times than the pump was revised. It is
easy to make the change if engine is off airplane, a larger pain if on
the aircraft. BTW, the original pump was aluminum/steel impellers and is
still legal. The later sintered impellers, and the later version of
aluminum/steel both had to be replaced with the current steel/steel
impellers. IMHO, I would want the latest version regardless of legalities.
Mike Robertson wrote:
| Quote: | Charlie,
Mike Robertson
Das Fed
> Date: Wed, 29 Jul 2009 20:15:23 -0500
> From: ceengland(at)bellsouth.net
> Thanks,
> Charlie
> _=====
Windows Live™ SkyDrive™: Store, access, and share your photos. See how.
<http://windowslive.com/Online/SkyDrive?ocid=TXT_TAGLM_WL_CS_SD_photos_072009>
KCHD |
Posted: Thu Jul 30, 2009 6:16 pm Post subject: Lyc oil pump ADs? |
Thanks, Mike. That means the acc case can stay on the engine.
Charlie
| Quote: | Charlie,
Mike Robertson
Das Fed
> Thanks,
> Charlie
Posted: Thu Jul 30, 2009 6:27 pm Post subject: Lyc oil pump ADs? |
Thanks for the heads-up, but I think I'm good to go. The AD was complied
with; I was concerned about missing an AD that might have come out later.
Charlie
Kelly McMullen wrote:
over that AD that was revised more times than the pump was revised. It
is easy to make the change if engine is off airplane, a larger pain if
on the aircraft. BTW, the original pump was aluminum/steel impellers
and is still legal. The later sintered impellers, and the later
version of aluminum/steel both had to be replaced with the current
steel/steel impellers. IMHO, I would want the latest version
> Charlie,
> Mike Robertson
> Das Fed
> > Thanks,
> > Charlie
rv8iator
Posted: Sun Aug 02, 2009 4:53 pm Post subject: Lyc oil pump ADs? |
Charlie...
I am currently overhauling my IO-360. An AD search has turned up nothing new regarding the oil pump gear AD. Yes, machined steel gears. (formerly sintered steel.)
Chris Stone
RV-8
Newberg, OR
_________________ C. Stone (RV8iator) |
