Flight Test - cart before horse?
tdawson-townsend(at)auror
PostPosted: Mon Jul 27, 2009 7:25 am    Post subject: Flight Test - cart before horse? Reply with quote
Maybe I’m getting the cart before the horse, but did anyone make something like kneeboard-size flight test cards for your test period? Can I borrow your format, if yes?
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
coop85(at)verizon.net
PostPosted: Mon Jul 27, 2009 12:44 pm    Post subject: Flight Test - cart before horse? Reply with quote
Tim,
In my opinion you can’t start thinking about the first flight too early, mostly because it’s fun and motivating. There’s also the element that you’ll be better prepared. Anyway, I’ve attached the flight test cards that I received as a First Flight Advisor. If you have someone that is currently an advisor nearby you might be able to get something more recent as my info is somewhat dated. I also attached some gouge I found for an RV-6 just to get some thoughts going.
Good luck and enjoy planning that first flight,
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Monday, July 27, 2009 11:08 AM
Subject: Flight Test - cart before horse?
TDT
Tim Dawson-Townsend
40025
First_Flight_Script0001.pdf
 Filename:  First_Flight_Script0001.pdf
 Filesize:  624.14 KB
 Downloaded:  299 Time(s)
FLIGHT_TEST_PROGRAM_BP.doc
 Filename:  FLIGHT_TEST_PROGRAM_BP.doc
 Filesize:  54 KB
 Downloaded:  312 Time(s)
