John Bolding
Posted: Tue Jul 21, 2009 2:53 pm Post subject: VGs |
Hi John, Wish you were coming to OSH again this year, we could continue the short visit we started when you were here.
As always I enjoy your testing, do you have any theory on why the spread widens at higher speeds? 200fpm is pretty substantial.
LO&SLO John Bolding
vgstol(at)bigpond.net.au Guest
Posted: Tue Jul 21, 2009 4:12 pm Post subject: VGs |
Gday John,
Yeh, maybe someday I might get back to OSH but don't know when...
Yeh, I think the spread increases because the drag of the slats increases with the square of the airspeed. All that difference isn't due to lift, but rather to drag. The reduction in drag allows all that spare power to go into climb instead.
JG
On Wed, Jul 22, 2009 at 8:53 AM, John Bolding <jnbolding1(at)teleshare.net (jnbolding1(at)teleshare.net)> wrote:
[quote] Hi John, Wish you were coming to OSH again this year, we could continue the short visit we started when you were here.
LO&SLO John Bolding
graeme(at)coletoolcentre. Guest
Posted: Tue Jul 21, 2009 5:24 pm Post subject: VGs |
approx a week ago there was alink to zenith and alloy VG's for elevator alloy CH701.
could some one repost
Thanks Graemecns
dwilde(at)clearwire.net Guest
Posted: Tue Jul 21, 2009 5:42 pm Post subject: VGs |
ronlee wrote:
That is very nice of John G. at Stolspeed to offer to replace broken VGs.
I have them on my 701( no slats) and they perform excellent. I wouldn't go back to slats on a bet. It's just a much easier plane to fly.
Ron Lee
Tucson, Arizona
Jeez. I didn't know my plane was hard to fly.
Dan Wilde
peterlthomson(at)gmail.co Guest
Posted: Tue Jul 21, 2009 11:52 pm Post subject: VGs |
I have the Stolspeed VG's on wings and elevator.
I took my slats off, and I'll never re-fit them.
I think the only time you'll find a difference (if one exists) is
when the nose is pointing at an angle which would scare most people to
death.
The Vg's on the elevator make it easy to hold the nose off at very
slow touchdown speeds.
Key advantages are the loss of drag, better fuel economy and ease of
cruise near the maximum.
Peter
CH701 SP (CZAW)
912ULS
VG's - no slats
JohnDRead(at)aol.com Guest
Posted: Wed Jul 22, 2009 6:15 am Post subject: VGs |
Why bother to build a STOL aircraft if you take away the things that make it so? VGs only make poor airfoils work better, they do not make a STOL wing out of any airfoil. Flame away!
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 7/22/2009 1:52:36 A.M. Mountain Daylight Time, peterlthomson(at)gmail.com writes:
| Quote: | --> Zenith701801-List message posted by: Peter Thomson <peterlthomson(at)gmail.com>
death.
Peter
CH701 SP (CZAW)
912ULS
VG's - no ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
What's for dinner tonight? Find quick and easy dinner ideas for any occasion.
cscsail(at)gmavt.net Guest
Posted: Wed Jul 22, 2009 8:02 am Post subject: VGs |
I'm with you 100% John. People that like the planes flying characteristics with the slats removed, probably selected the wrong plane to build.
Gordon
john.marzulli(at)gmail.co Guest
Posted: Wed Jul 22, 2009 9:04 am Post subject: VGs |
Has anyone experimented with "gap sealing" the slats to the wing to "complete" the airfoil while using VGs?
This seems like a more reasonable solution than simply pulling the slats off and would probably result in less drag when flying in cruise than presenting the unslatted wing.
John Marzulli
http://www.GenevieveMarzulli.org/
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Wed, Jul 22, 2009 at 8:57 AM, Gordon <cscsail(at)gmavt.net (cscsail(at)gmavt.net)> wrote:
[quote] I'm with you 100% John. People that like the planes flying characteristics with the slats removed, probably selected the wrong plane to build.
Gordon
John Bolding
Posted: Wed Jul 22, 2009 9:41 am Post subject: VGs |
Gilpin (among others) has. Found that the center of lift moved forward, lending credence to the notion that the slats do nothing/very little in cruise. I'll provide the nose ribs if anyone with a flying airplane wants to test the full airfoil. Mine is still a year or better in the future.
arno7452(at)bellsouth.net Guest
Posted: Wed Jul 22, 2009 9:43 am Post subject: VGs |
Hey John,
There have been some efforts. However, Vne is a troublesome factor. Covering the struts and waxing a painted CH701 reduces drag such that Vne is too close.
Talk with Roger at Zenith. He is a CH701 expert. Per his recommendation, I installed plastic VGs on the elevator. Works great since they are only used during slow speeds such as landing.
Ken
Posted: Wed Jul 22, 2009 1:41 pm Post subject: VGs |
Yes, I tried sealing the gaps between the slats and the wing. Cruise speed was the same as no slats, but the centre of lift had moved forward such that there was a more aft CofG that didn't feel good in my aircraft. Turns out that the slats don't act like part of the lifting wing at cruise, which was proven in that there is no change in cruise trim with slats/no slats.
Closing those gaps effectively extends the the chord of the wing much farther forward, thus moving the centre of lift farther forward and increasing the wing area considerably. This is much like the extended leading edge that John Bolding has been considering. I think it has real good possibilities for a better balance for 701's with heavy car engines and floats.
JG
On Thu, Jul 23, 2009 at 3:00 AM, John Marzulli <john.marzulli(at)gmail.com (john.marzulli(at)gmail.com)> wrote:
[quote]Has anyone experimented with "gap sealing" the slats to the wing to "complete" the airfoil while using VGs?
John Marzulli
Gordon
Posted: Wed Jul 22, 2009 2:19 pm Post subject: VGs |
No we didn't choose the wrong aircraft at all. The 701 is a great aircraft, and we've found ways to make it even better for our use. As Peter has testified, we lose very little, (if any) STOL capability, and gain much better x-country cruise capability and handling. It really expands the aircraft's envelope. It's like the difference between an original Willys Jeep and a Suzuki 4WD; the Suzi can match the Jeep anywhere off-road, and is a whole lot better on the highway. There's nothing that can't be improved, and this is just evolution in action....
JG
On Thu, Jul 23, 2009 at 1:57 AM, Gordon <cscsail(at)gmavt.net (cscsail(at)gmavt.net)> wrote:
Gordon
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Jul 22, 2009 4:54 pm Post subject: Re: VGs |
John,
No flames needed, no one says VGs make a poor airfoil into a helicopter. Only that VGs do perform close to the slats and improve other aspects of the 701 performance and handling. And that they help less STOL airfoils some. CH has given his stamp of approval on this 701 mod from an engineering stand point. Though he does reserve the performance stamp of approval.
My guess is it is a marketing issue, but who knows?
Are they for everyone... nope, but they are for me. I have spoken to the John Gs customers and they support his claims 100%. And as for the idea that he is selling something, so buyer beware... run the numbers, he is providing a product that gets him some gas money, he really does not have $ signs in his eyes.
Kevin
CH 701 SN 7172
N701DZ
[quote="JohnDRead(at)aol.com"]Why bother to build a STOL aircraft if you take away the things that make it so? VGs only make poor airfoils work better, they do not make a STOL wing out of any airfoil. Flame away!
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
| Quote: | --> Zenith701801-List message posted by: Peter Thomson <peterlthomson>
death.
Peter
CH701 SP (CZAW)
912ULS
VG's - no ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; � ===================================================
_________________ “Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune |
d.shrader
Posted: Thu Jul 23, 2009 4:33 pm Post subject: Re: VGs |
John,
vg's are part of all modern airfoil design STOL included from boeing on down to cessna. If it didn't come equiped that way there is a STC for it. All the aircraft I work on have them and most of the ones that fly out of this reagon have them. Cub's & 185's included. I'm not trying to stoke the flames at all just pointing out vg's will improve almost any airfoil (not lamanar flow) study it for your self and make an informed decision and good luck in your build.
Dave
Posted: Thu Jul 23, 2009 8:53 pm Post subject: VGs |
I am familiar with vgs and how they work. The fact is that a slotted wing is the best way to get STOL characteristics. And I'll repeat vgs make a poor (or under performing) airfoil work better. They will not make a regular airfoil into a STOL airfoil. Find a copy of Abbot and Von Doenhoff, they explain slots very well.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 7/23/2009 6:34:59 P.M. Mountain Daylight Time, chilledj(at)yahoo.com writes:
| Quote: | --> Zenith701801-List message posted by: "d.shrader" <chilledj(at)yahoo.com>
John,
Dave
http://forums.matronics.com/viewtopic.php?p=254537#254537===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
jpspencer(at)cableone.net Guest
Posted: Sat Jul 25, 2009 2:17 am Post subject: VGs |
Guys
I sincerely want to know...have any of you who don't believe in vgs on the 701 ever flown a 701 first with slats and then with properly placed vgs? I mean, really? If so, please speak up. I'm not being confrontational here, I really would like to hear from you and get your first hand experience for the group.
The 701 is a different animal from anything else I have ever flown. The lowspeed handling really sucked when slowed up to below say 40 mph, til I replaced the slats with vgs. Then it settled down to an acceptably flying airplane...not the best, just acceptable.
Like I said before, don't knock it til you have tried it...but if you have tried it and didn't like it let us hear from you.
Joe
Hitting the road for the big shindig up nawth
keninalaska(at)gmail.com Guest
Posted: Sat Jul 25, 2009 6:14 am Post subject: VGs |
Watch this video, and tell me again how sucky the 701 is at slow speed:
http://www.youtube.com/watch?v=YlgfTV3Jpio
I don't think the problem is the slats!
On Sat, Jul 25, 2009 at 2:15 AM, Joe Spencer <jpspencer(at)cableone.net (jpspencer(at)cableone.net)> wrote:
[quote] Guys
Joe
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
kmccune
Posted: Sat Jul 25, 2009 9:00 am Post subject: Re: VGs |
But this is what happens if you pull the power too high.
http://www.youtube.com/watch?v=f4KKH_AIXaw
Luckily Gus is a pretty good pilot and the 701 is pretty tough. The point is how much STOL do you need and would a little more speed or less fuel burn or easier low speed manors be preferable. The VGs are not for everyone, I do not believe that they are as good as slats in extreme nose high attitude's at slow speeds. And the induced drag really is a good air brake. But we all have our check list, mine includes very good STOL, high wing, relatively easy plans building, low cost, reasonable cruise and low fuel burn. I do not need to drop into clearings twice the length of my garage with 30 foot trees all around it. So the VGs are better for me. Why is this so hard for some, to under stand?
Now if Zenith offered a Pegstol like wing, none of us would be having this conversation. But I guess some would need to claim that the slats may not extend and that they are not as safe as fixed slats?
Kevin
Dorothy McCune |
NYTerminat(at)aol.com Guest
Posted: Sat Jul 25, 2009 3:44 pm Post subject: VGs |
Has anyone actually flown with the Pegastol wing on a 701? I sure am curious as to the performance.
Bob Spudis
N701ZX
In a message dated 7/25/2009 1:01:38 P.M. Eastern Daylight Time, kmccune(at)somtel.net writes:
A Good Credit Score is 70001462830/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID=115&bcd=JulystepsfooterNO115>See yours in just 2 easy steps!
kmccune
Posted: Sat Jul 25, 2009 3:52 pm Post subject: Re: VGs |
Yes, but they need to chime in themselves.
Kevin
Dorothy McCune |
