		ward.t(at)xtra.co.nz Guest
				 Posted: Wed Mar 29, 2006 1:06 pm    Post subject: Tailplane Pip pin Cover |
				Richard,
 Go down to your local hardware shop, in the plumbing division, and obtain 2
 x 50mm plastic 'end plugs' (screw on plug with rubber washers). Fit them
 into the top of your stabilator with centre being the pin, and set below the
 curved surface. When finishing the surface build up with flox to contour the
 plug with the surface. I then cut down an old Subaru key I had to make two
 points and drilled holes in the screw top to fit the key so you can unscrew
 it to check the pins. Keeps water out.
 Cheers,
 Tim Ward
 12 Waiwetu Street,
 Fendalton,
 Christchurch, 8005
 New Zealand.
 Ph +64 3 3515166
 Mobile 021 0640221
				 Posted: Wed Mar 29, 2006 3:20 pm    Post subject: Tailplane Pip pin Cover |
				Richard/Tim
 I did that, but the damn painter got solvent into the thread then I
 cocked them up getting them out again ! Great idea but I finished up
 having the two plug ends machined out of aluminium at 45 quid with a
 slot in them for a coin to be used to open them! I keep a bit of grease
 on the thread and it stops water ingress since the rubber seals tend to
 curl up and snag!
 Bob Harrison G-PTAG Europa MKI/Jabiru 3300
		sandford(at)melbpc.org.au Guest
				 Posted: Wed Mar 29, 2006 5:26 pm    Post subject: Tailplane Pip pin Cover |
				Richard
 While you are in the hardware store, get two of the disposable tapered
 nozzles used on caulking guns.
 Use them instead of the plastic tubing below the pip pins, the large end
 is cut to clear the balls and the small end leaves a small, neat hole
 for drainage in the lower surface.
 Lance Sandford in Oz
 Richard,
 Go down to your local hardware shop, in the plumbing division, and obtain 2 Tim Ward wrote:
 Cheers,
 Tim Ward
 12 Waiwetu Street,
 Fendalton,
 Christchurch, 8005
 New Zealand.
 Ph +64 3 3515166
 Mobile 021 0640221
		nwcmc(at)tiscali.co.uk Guest
				 Posted: Thu Mar 30, 2006 12:29 am    Post subject: Tailplane Pip pin Cover |
				I have a very simple idea from my inspector who works on gliders. Buy a
 sheet of white self adhesive circular discs about 50mm diameter. As well
 as the tail plane pip pins these can be used to cover the drag link pins
 on the wings where the surface is curved. If you rig and derig
 infrequently like I do just be careful when it comes to removal as it is
 possible to pull the paint at the edge of the hole. Best to puncture the
 disc and remove it in a circular motion.
 Nigel Charles
		alan(at)kestrel-insurance Guest
				 Posted: Thu Mar 30, 2006 3:22 am    Post subject: Tailplane Pip pin Cover |
				Hi Nigel
 What a good idea, where do you buy them from?
 Alan
		BEBERRY(at)aol.com Guest
				 Posted: Thu Mar 30, 2006 3:39 am    Post subject: Tailplane Pip pin Cover |
				My son uses the same stuff on his glider.  You can use the 'sticky  backed
 plastic' that many use to cut out the ident letters on the a/c
 Patrick
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Thu Mar 30, 2006 4:50 am    Post subject: Tailplane Pip pin Cover |
				I had my local graphics shop make me a bunch.  They made small ones to cover
 the flap drive inspection holes as well.  I don't recall the cost but it was
 quite inexpensive.
 Paul
				 Posted: Thu Mar 30, 2006 4:59 am    Post subject: Tailplane Pip pin Cover |
				My inspector directed me to a small company dealing in stationery. I
 have since run out and must get some more. It would be good if someone
 found a mailorder company selling them because it would take me some
 time and effort to relocate my source.
 Nigel
				 Posted: Thu Mar 30, 2006 5:01 am    Post subject: Tailplane Pip pin Cover |
				If it is difficult to find these discs ready cut to shape it should be
 possible to buy sheets of white sticky back plastic from a hardware
 store but then you have the tedious business of cutting circles.
 Nigel
		rowil(at)clara.net Guest
				 Posted: Thu Mar 30, 2006 9:41 am    Post subject: Tailplane Pip pin Cover |
				At 2006-03-29 22:48 +0100 Flying Farmer wrote:
  	  | Quote: | 	 		  Before digging out the Tailplane foam for the pip pin location, I
 want to get some information on a cover for the hole location
 Richard - I think the PFA are still regarding this as a mod, so you
 would probably save trouble by using an already-approved approach.
 Have you looked in the Club Hints & Tips? There are several
 suggestions on p22. I think Ian Rickard <mods(at)europaclub.org.uk>
 would know which was the line of least resistance - fairly important
 to consider at present while the PFA is running at one-thinrd the
 strength in Engineering that they had a short while ago (a quarter
 the strength they would like to have).
 regards
 Rowland
 | Rowland Carson (retiring) Europa Club Membership Secretary - email for info!
 | Europa 435 G-ROWI (750 hours building)  PFA #16532
 | e-mail <memsec(at)europaclub.org.uk> website <www.europaclub.org.uk>
		topglock(at)cox.net Guest
				 Posted: Thu Mar 30, 2006 5:04 pm    Post subject: Tailplane Pip pin Cover |
				This is the simplist way to go about it.  Being in the graphics
 business, I cut my own, but any graphics of vinyl sign shop will
 probably give you all the scraps you want.  Simply cut with scissors,
 peal and stick.  When it comes time to remove the pins, peal it off and
 replace once the wings are back on...
 Jeff - N55XS
 150 hrs
 Paul McAllister wrote:
 quite inexpensive.
 Paul
		SPurpura(at)aol.com Guest
				 Posted: Thu Mar 30, 2006 5:44 pm    Post subject: Tailplane Pip pin Cover |
				I USE A WHITE PLASTIC CLEAN ROOM TAPE TO COVER HOLES AND IT COMES OFF EASY
 WITH NO RESIDUE LEFT BEHIND.
