japhillipsga(at)aol.com Guest
Posted: Tue Jul 07, 2009 9:57 am Post subject: Cowl Paint Gap |
Greeting Fellow RV-8/8a Builders, Hijacking here; who can tell me how wide the gap between fuselage top skin and cowl fiberglass should be to allow for paint? Too wide and it would show, but too thin and the paint will pop with expansion. Hope to hear from you, Best regards, Bill
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Speedy11(at)aol.com Guest
Posted: Wed Jul 08, 2009 7:53 am Post subject: Cowl Paint Gap |
Bill,
Fit it as tight as you can. You can easily use a Permagrit file and quickly remove as much material as you need for paint. The paint guys will know the answer about the gap and may even do the work for you. If you paint it yourself, then worry about getting the correct gap when the time comes.
My gap varies a bit because the damn thing is such a challenge to fit, but I've got about 1/16 gap. I'm using the Skybolt fasteners and they give a bit, so the gap is going to vary anyway - even with hinges.
Stan Sutterfield
Second Flight yesterday - flys sweet
www.rv-8a.net
| Quote: | Greeting Fellow RV-8/8a Builders, Hijacking here; who can tell me how wide the
Too wide and it would show, but too thin and the paint will pop with expansion. |
Summer concert season is here! Find your favorite artists on tour at TourTracker.com.
madman266(at)comcast.net Guest
Posted: Wed Jul 08, 2009 8:09 am Post subject: Cowl Paint Gap |
try a hacksaw blade . i used one between cowl and fuselage , top cowl and bottom , and wing tips and wing . j
rick.mcbride(at)me.com Guest
Posted: Wed Jul 08, 2009 9:38 am Post subject: Cowl Paint Gap |
The saw blade technique works great. If you want a tighter fit you can use a pull saw that has a thinner blade. This technique also works well on the various empennage tips. But be careful too tight is definitely not a good thing for the cowl because the paint will chip. I know from experience.
Rick McBride
On Jul 8, 2009, at 12:08 PM, james d winkler wrote:
| Quote: | try a hacksaw blade . i used one between cowl and fuselage , top cowl and bottom , and wing tips and wing . j
href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List
JAPhillipsGA(at)aol.com Guest
Posted: Wed Jul 08, 2009 7:07 pm Post subject: Cowl Paint Gap |
J., Thanks for the info, Bill
In a message dated 7/8/2009 12:10:14 P.M. Eastern Daylight Time, madman266(at)comcast.net writes:
Looking for love this summer? Find it now on AOL Personals.
