Zjopa
Joined: 21 Feb 2007 Posts: 23 Location: Pacific Northwest
Posted: Mon Jul 06, 2009 5:59 am Post subject: Idling problem... |
Flew yesterday.. Everything normal on the taxi out, run up, and throughout the flight..
Landed after 30 mins, throttled back to idle... and the engine wanted to stop!
Had to taxi with a fair amount of power to keep the engine running.
Back at the hanger throttled back to Idle.. and she quit!
Any ideas as to what might cause such a sudden change??? Water??
Thanks in advance
wlannon(at)persona.ca Guest
Posted: Mon Jul 06, 2009 8:12 am Post subject: Idling problem... |
M14P or Huosai??????
Sounds like a fairly large intake manifold leak.
Walt
N13472(at)aol.com Guest
Posted: Mon Jul 06, 2009 8:41 am Post subject: Idling problem... |
Check to make sure your primer was/is locked in the closed position.
Tom Elliott
CJ-6A NX63727
702-595-2680
Zjopa
Posted: Mon Jul 06, 2009 9:23 am Post subject: Re: Idling problem... |
M-14, and the primer was locked... first thing I checked.
I had a water in fuel problem a few hours ago... wondering if there might be some residual?? Vladimir and I thoroughly drained the tanks and the fuel filter... Might try that again today.
_________________ "Well, boys, we got three engines out, we got more holes in us than a horse trader's mule, the radio is gone and we're leaking fuel and if we was flying any lower why we'd need sleigh bells on this thing... "
- Henry Paulson, US Treasury Secretary |
Posted: Mon Jul 06, 2009 11:18 am Post subject: Idling problem... |
Some thoughts:
Yes, check for more water.
Is this known good fuel?
Take a look at fuel pressure at idle.
Pull both fuel filters and check them.
Run on one mag at a time at idle and make sure it does the same thing on
both mags, running on one at a time.
Check intake tubes to be sure they are tight at both ends.
If you get desperate, and nothing else seems to help, and you are using
automotive spark plugs, consider replacing them, and make sure they are
gapped correctly.
Find a good mechanic. I am not one of those. Vladimir is one of the
best. Tell him I said hello.
Mark Bitterlich
Zjopa
Posted: Wed Jul 08, 2009 7:08 pm Post subject: Re: Idling problem... |
Thanks Mark... I chatted with Vladimir.. he advised the same... There was about 20ccs of H2O in the main filter, and a little in the fine filter!.
She now runs like a dream. We think the water came from a faulty seal on one of the tip tanks.
Thanks for the advice.
Ron
