brianm(at)snolab.ca Guest
Posted: Sat Jul 04, 2009 5:38 am Post subject: Circuit breaker IVO IFA? |
Hi
I am installing a ivo IFA on my 912 and was wondering what size of breaker I
should be installing in the loop. What works for others?
Brian
wannafly
Posted: Sat Jul 04, 2009 9:05 am Post subject: Circuit breaker IVO IFA? |
It should come with one in the wire harness. It did on mine.
mic
| Quote: | From: brianm(at)snolab.ca
To: kitfox-list(at)matronics.com; kitfox-list-digest(at)matronics.com
Subject: Kitfox-List: Circuit breaker IVO IFA?
Date: Sat C 4 Jul 2009 09:13:32 -0400
--> Kitfox-List message posted by: "Brian Morissette" <brianm(at)snolab.ca>
Hi
Brian
&g==================
Windows Live helps you keep up with all your friends C in one place.
kitfoxsport(at)verizon.ne Guest
Posted: Sat Jul 04, 2009 10:43 am Post subject: Circuit breaker IVO IFA? |
10 amp
George
Sport Model - 914- almost, but not yet!
To: kitfox-list(at)matronics.com; Kitfox-List Digest List <kitfox-list-digest(at)matronics.com>
Sent: Saturday, July 4, 2009 6:13:32 AM
Subject: Circuit breaker IVO IFA?
--> Kitfox-List message posted by: "Brian Morissette" <brianm(at)snolab.ca (brianm(at)snolab.ca)>
Hi
should be installing in the loop. What works for others; -Matt Dralle, Lis
Posted: Sat Jul 04, 2009 10:49 am Post subject: Circuit breaker IVO IFA? |
Thanks. I bought my prop and wiring used and the wiring that I received was some yucky extension cord material. I threw all the wiring away and there wasn't a circuit breaker in the wiring I received. I have it currently hooked up to a 3 amp breaker which trips quite easily when I get to the end of the stroke.
How many amps is the breaker that came with your wiring harness?
I thought I read 10 amps somewhere but I can't find the article to confirm.
thanks
Brian
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of mic thiessen
Sent: July 4, 2009 1:01 PM
Subject: RE: Circuit breaker IVO IFA?
mic
Date: Sat, 4 Jul 2009 09:13:32 -0400
Hi
Brian
Windows Live helps you keep up with all your friends, in one place. [quote]
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
wannafly
Posted: Sat Jul 04, 2009 11:34 am Post subject: Circuit breaker IVO IFA? |
Brian
Not sure of my amps as my Kitfox is not close to home at the moment C but would venture a guess that it is 10 amps ot higher. Give IVO a call. they could clear it all up. Mine has never triped the breaker. When it hits dead end you can see it on your altenator gauge will spike and its time to let go of the switch.
mic
Subject: RE: Kitfox-List: Circuit breaker IVO IFA?
Date: Sat C 4 Jul 2009 14:45:30 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Thanks. I bought my prop and wiring used and the wiring that I received was some yucky extension cord material. I threw all the wiring away and there wasn't a circuit breaker in the wiring I received. I have it currently hooked up to a 3 amp breaker which trips quite easily when I get to the end of the stroke.
thanks
Brian
Sent: July 4 C 2009 1:01 PM
mic
Hi
Brian
Windows Live helps you keep up with all your friends C in one place. | Quote: |
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
| Internet Explorer 8 makes surfing easier. Get it now! [quote][b]
akflyer
Posted: Sat Jul 04, 2009 12:45 pm Post subject: Re: Circuit breaker IVO IFA? |
Did you end up with an ungodly amount of extra wire that you coil up and stuff behind the pannel? IVO sends out a very long harness and cautions you not to cut it as it limits the current that gets to the motor. If you run shorter wires with less resistance, you run the risk of frying the motors, which used to be 37 bucks but are now 100 bucks. I have been through 6 of them until I figured out what the problem was (using high pitch blades as recommended by my brother) that requires the poor little motor to work too hard to flatten them out enough for take off RPM.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Posted: Sat Jul 04, 2009 1:05 pm Post subject: Circuit breaker IVO IFA? |
thanks a bunch Mic
Brian
Sent: July 4, 2009 3:28 PM
Brian
Not sure of my amps as my Kitfox is not close to home at the moment, but would venture a guess that it is 10 amps ot higher. Give IVO a call. they could clear it all up. Mine has never triped the breaker. When it hits dead end you can see it on your altenator gauge will spike and its time to let go of the switch.
mic
Date: Sat, 4 Jul 2009 14:45:30 -0400
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Verdana } Thanks. I bought my prop and wiring used and the wiring that I received was some yucky extension cord material. I threw all the wiring away and there wasn't a circuit breaker in the wiring I received. I have it currently hooked up to a 3 amp breaker which trips quite easily when I get to the end of the stroke.
thanks
Brian
mic
Hi
Brian
Windows Live helps you keep up with all your friends, in one place. | Quote: |
ronics.com
