whitley(at)ntlworld.com Guest
Posted: Wed Mar 29, 2006 2:18 pm Post subject: Filler tube for RV 4 |
The oil filler tube on my Superior XP-360 is too long and needs to be about an inch shorter to clear the inside of the top cowling on my RV4.
Is there a shorter oil tube available, if not what adhesive works on Lycoming plastic filler tubes.
Stan Howes U.K.
Upgrade your email with thousands of emoticons for free
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
Posted: Wed Mar 29, 2006 5:19 pm Post subject: Filler tube for RV 4 |
I cut a section out of my oil fill tube and used a piece of leftover
aileron pushrod as a sleeve over the cut section (fit mine perfectly!)
I then prosealed it all together and held it in place with a couple of
pull rivets on each side of the cut. Works like a champ!
-Mike Kraus
RV-4 Flying
RV-10 Hanger flying and working on the fuse and IP
