fuel pressure
europa(at)pstewart.f2s.co
PostPosted: Thu Jun 25, 2009 2:17 am    Post subject: fuel pressure Reply with quote
Has anyone used a double banjo bolt on the (914) fuel regulator to provide a
take of for measuring fuel pressure ?
I am currently measuring fuel pressure in the fuel line to the regulator - don't
know if this would be different. The rotax owners site suggests the double banjo
idea.
Any thoughts gratefully received
Paul Stewart
G-GIDY
h&jeuropa
PostPosted: Thu Jun 25, 2009 3:02 am    Post subject: Re: fuel pressure Reply with quote
Paul,
That's exactly how ours is setup. Works fine.
Jim & Heather
N241BW
frans(at)paardnatuurlijk.
PostPosted: Thu Jun 25, 2009 3:03 am    Post subject: fuel pressure Reply with quote
I have. It is a standard part if you buy the Europa supplied
differential fuel pressure indicator. One side goes to the double banjo,
and the other side to the airbox. You measure the pressure difference
over the airbox and fuel, and this is what you want to measure, because
this is what the carbs are seeing. If you buy the Europa differential
fuel pressure indicator, you will get all required parts.
Frans Veldman
PostPosted: Thu Jun 25, 2009 8:43 am    Post subject: fuel pressure Reply with quote
Jim , Franz
Thanks for the replies.
Jim what I'm trying to find out is if there is a difference between the pressure
in the fuel line between fuel pump and regulator (where I'm currently measuring
it) and pressure in the line from regulator to carb (where the banjo would
measure it). I wasn't quite sure how you were saying yours is set up.
Franz - I'll get onto Europa re the banjo - I already have the sensor feeding
into a Blue Mountain EFIS
Paul
G-GIDY
Quoting "h&amp;jeuropa" <butcher43(at)att.net>:
Paul,
Jim & Heather
N241BW
http://forums.matronics.com/viewtopic.php?p 49930#249930
PostPosted: Thu Jun 25, 2009 12:09 pm    Post subject: fuel pressure Reply with quote
If you have a 914, just make sure you use the difference over the airbox
pressure, not the absolute fuel pressure. The absolute fuel pressure is
meaningless if the airbox pressure is the same (netto is zero, so no
fuel will flow to the carbs, despite the absolute fuel pressure).
Frans Veldman
budyerly(at)msn.com
PostPosted: Thu Jun 25, 2009 1:24 pm    Post subject: fuel pressure Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Do it all the time with the 914s. Lockwood recommends it and your Rotax parts manual has a breakdown. I have a love hate relationship with fuel pressure sensors so I won't recommend any for fear of retaliation.
Bud Yerly
Custom Flight
budyerly(at)msn.com
PostPosted: Thu Jun 25, 2009 1:31 pm    Post subject: fuel pressure Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Not to differ Frans, but to comment.
The differential is absolutely necessary, but I do the math to check MP vs Fuel Pressure, it keeps me alert. I don’t fly above 10,000 so it rarely matters in my type flying. I measure the pressure off the regulator to watch my fuel filter health. A drop in fuel pressure indicates a fuel filter in need of servicing. Learned that the hard way in test flying.
It would be the department of redundant redundancy to measure both differential and MP and fuel manifold pressures, but wouldn't it be neat.
Just my thoughts.
Bud Yerly
Custom Flight
