gareywittich2000(at)yahoo Guest
Posted: Sun Jun 21, 2009 7:51 pm Post subject: Measure RUDDER Deflection (Swing) Angle |
Greetings:
Have my VS mounted to the work bench along with the Rudder attached. Trying to verify the 35 degree travel on the Rudder to the Left and Right of Neutral. Seen no Archieves on how to measure the angle other than laying the VS and Rudder on the work bench and using "Smart Level" to measure the deflection in the Up & Down positions. Must be "super simple" to measure it, but for some reason the method is not evident to me (now).
Appreciate your help, Garey Wittich Santa Monica, CA
acepilot(at)bloomer.net Guest
Posted: Mon Jun 22, 2009 2:39 am Post subject: Measure RUDDER Deflection (Swing) Angle |
Maybe draw a center line on the bench and then from a point that is the
centerline of the hinges draw lines out at 35 degrees (protractor) on
each side of the centerline on the bench. Swing the rudder and watch
for the trailing edge to line up with the 35 degree lines at the end of
travel.
Garey Wittich wrote:
| Quote: | Greetings:
Scott
http://corbenflyer.tripod.com/
Flying Corben Junior Ace - Building RV-4
Gotta Fly or Gonna Die
wgill10(at)comcast.net Guest
Posted: Mon Jun 22, 2009 4:23 am Post subject: Measure RUDDER Deflection (Swing) Angle |
Garey,
The critical part is Van’s “additional instruction” that states that the distance between rudder and trailing edge of the elevator shall not be closer than one inch. After complying with this instruction, I found that the rudder swing in each direction was a few degrees less than the 35° callout. Additionally, the rudder stop dimensions were different from the plans to meet the 1” callout.
Bill
RV-7 N151WP
Lee’s Summit, MO
