JAPhillipsGA(at)aol.com Guest
Posted: Sun Jun 21, 2009 9:13 pm Post subject: Measure RUDDER Deflection (Swing) Angle |
Garey, Seems you may be missing that the swing is 35 degrees relative to the outside of the fuselage, not just to the VS. I just mounted my rudder stops the other day and 35 degrees is easy with a plywood cutout of 35 degrees on 90 degrees. Does that sound right? Need a fuselage to set the stops to. Best of Luck, Bill of Georgia
In a message dated 6/21/2009 11:52:17 P.M. Eastern Daylight Time, gareywittich2000(at)yahoo.com writes:
| Quote: | Greetings:
Have my VS mounted to the work bench along with the Rudder attached. Trying to verify the 35 degree travel on the Rudder to the Left and Right of Neutral. Seen no Archieves on how to measure the angle other than laying the VS and Rudder on the work bench and using "Smart Level" to measure the deflection in the Up & Down positions. Must be "super simple" to measure it, but for some reason the method is not evident to me (now).
Appreciate your help, Garey Wittich Santa Monica, CA
A00126575x1221823273x1201398689/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JuneExcfooterNO62>See Yours in Just 2 Easy Steps!
william_slaughter(at)att. Guest
Posted: Mon Jun 22, 2009 2:20 am Post subject: Measure RUDDER Deflection (Swing) Angle |
Deflect rudder. Cut cardboard to nest into the angle. Measure angle with protractor.
William Slaughter
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Garey Wittich
Sent: Sunday, June 21, 2009 10:51 PM
To: rv-list(at)matronics.com
Subject: Measure RUDDER Deflection (Swing) Angle
Greetings:
| Quote: | | http://www.matronics.com/Navigator?RV8-List | 0123456789
