Aerothane
johnwigney(at)windstream.
PostPosted: Sat Jun 06, 2009 5:43 pm    Post subject: Aerothane Reply with quote
Hi Mike,
I painted my Europa with the Polyfiber/Aerothane system in 2001. 650 flying hours later it is still in good shape. I used the Smooth Prime water based primer - 3 + 3 coats rolled on as per the book. The Aerothane topcoat was my first spray job and I used an Axis HVLP gun http://www.axispro.com/index.php One of these days I might get round to doing a sanding and buffing job on the paint which would give it that showroom finish.
Some people seem to have had trouble with the system when they did not let the primer dry for at least 3 weeks.(see details at http://www.polyfiber.com/uvsmooth/) If you do use the Aerothane, I recommend that you obtain the Polyfiber "Flight Gloss" manual - http://www.aircraftcoverings.co.uk/ias.asp This has a lot of good tips.
Cheers, John
N262WF, mono XS 912S
Mooresville, NC
[quote]ORIGINAL MESSAGE
From: "Mike Parkin" <mikenjulie.parkin(at)btinternet.com>
Subject: Polyfiber Aerothane Paint.
Has anyone used Aerothane paint and if so would you recommend it.
MP[b]
