SSD
Joined: 27 Apr 2008 Posts: 1 Location: Port Saint Lucie, Florida
Posted: Sat Jun 06, 2009 3:26 pm Post subject: Cessna 150F Landing/Taxi light switch. |
I have a very basic question. The switch in question burnt out so I obtained a replacement. For the life of me I can't figure out which wire goes where. I have three wires, power and feeds to the Landing and Taxi lights. The switch has four connectors marked H,R,A, B. The case is marked 600 and is a pull switch with two positions.
Can anyone help? I am aware it is not RV related. When I'm not flying my RV4 I have the Cessna to take pictures etc.
SSD
_________________ SSD 954-931-8896 |
Posted: Sun Jun 07, 2009 6:14 pm Post subject: Cessna 150F Landing/Taxi light switch. |
At 06:24 PM 6/6/2009, you wrote:
| Quote: | I have a very basic question. The switch in question burnt out so I obtained a replacement. For the life of me I can't figure out which wire goes where. I have three wires, power and feeds to the Landing and Taxi lights. The switch has four connectors marked H,R,A, B. The case is marked 600 and is a pull switch with two positions.
SSD |
It has been a VERY long time since I've seen these
switches installed on the Cessnas but if it's a
4-terminal switch I suspect that an ohmmeter test
will show that with the switch has no connections
with the handle all the way in.
With the handle pulled to the first notch, I think
the pair of terminals furthest from the panel will
be connected to each other. This pair is the taxi
light circuit. With the handle all the way out, the
pair of terminals closest to the panel will be connected
to turn on the landing light. In this position, the
taxi light will be out. Here's an exemplar 4-terminal
push-pull switch from Cole-Hersee
[img]cid:.0[/img]
( -Thomas Paine 1776- )
