DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Fri Jun 05, 2009 1:05 pm Post subject: Wanted (maybe) Model IV Nose Gear |
I'm thinking of converting my Model IV to tri gear for various reasons, ie insurance costs, flight instruction, etc. A used set would be cheaper than a new set from Kitfox I'm sure, so I though I'd look around before I buy new.
Thanks in advance
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jun 05, 2009 3:33 pm Post subject: Wanted (maybe) Model IV Nose Gear |
Hi Dan and others,
I am curious about this as well - primarily from the design standpoint. I
know of some others who have made the switch. Is the conversion available
from the factory and if so, what is the approximate cost. My understanding
is that it requires a new engine mount with the hard points for the nose
gear.
The next question has to do with the main gear geometry. Is the nose gear
strut designed to mate with the bungee gear, Grove gear or is it adjustable
to accommodate either. I know the two gear designs have different lengths
to the ground.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Covering
