mprather(at)spro.net Guest
Posted: Thu Jun 04, 2009 12:44 pm Post subject: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving n |
Just goes to show you that "shielding everything" isn't a magic bullet.
It's not clear to me from your description that the noise is present when
the radio is receiving as well as transmitting.
Other ideas:
- Does disconnecting the antenna mitigate received noise?
- Have you verified that you don't have a "hot mag" by turning off both
ignitions while the engine is running - the engine should quit. (Maybe
this is normally how you stop the engine - I don't know if your fuel
delivery system allows "idle-cutoff"...) Additionally, if the noise is
from the ignition system (which I am now doubting), turning both of the
switches off should douse the electrical noise as well.
Matt-
<post(at)edgeperformance.no>
I will give it a try tomorrow. But I cant figure what I have done wrong.
Radio is connected right to the battery, all wires out of the molex
connector are shielded, jacks to headsets are isolated with plastic
washers through the front panel, have a grounded 50x45cm ground plate
inside the body with the antenna screwed right in the center of the
plate
EdgePerformance
Posted: Thu Jun 04, 2009 1:00 pm Post subject: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210 Recivi |
Hi,
i have the aerocarb so normally i use idle-cutoff but both magnetic coils are new and they work fine. Ignition cutoff work great on both cold and hot engine no matter what throttle setting.
What do you mean by antenna mitigate ? My English aren't that great. (Poor Norwegian).
I tried to turn off both ignition switches in flight and the engine didn't get to stop completely before the transmission was over, but I could clearly hear the noise frequency becoming lower. But that could also be both alternator and ignition I believe.
I really hope I can figure this out soon so that I can go out and fly my new build jabiru 2200 turbo kitfox IV.
I only have noise while receiving, other planes can hear me crystal clear ! But I cant hear towers or other planes near by me because this horrible noise.
_________________ Kitfox IV w\ Jabiru 2200 Turbo\Aerocarb |
Posted: Fri Jun 05, 2009 8:38 am Post subject: Kitfox IV - Jabiru 2200 - Icom IC-A210 Reciving n |
Hello EdgePerformance,
I'm just suggesting some basic trouble shooting methods. One of those
methods is to disable possible antagonists - things that might be creating
noise - while still being able to operate the victim. This can help to
identify which system is the source of the noise. In turn:
- Disable the ignition
- Disable the alternator
To verify that I understand clearly, you simultaneously turned off both
ignitions - causing the engine to stop running, but the prop windmilled
the engine for a short time? And the noise was still present, though the
frequency was winding down? I would expect that if the ignition were the
source of the problem, turning the ignition off would instantly stop the
generation of the noise, even as the engine continued to windmill.
Assuming this suggests to me that the source of the noise is in the
charging system.
Can you turn off the alternator while the engine runs?
Another way of attacking the problem is to identify how the noise is
getting into the victim.
- Running the radio from a battery can help identify if noise is getting
in through power/ground
- Disconnecting the antenna (from the back of the radio) can identify if
the noise is coming through the VHF/RF section of the radio
More questions:
- Do you have a separate audio panel or intercom? Can you disable it?
- Does the noise present itself while on the ground (with the engine
running)? This would make the debug process easier..
- Is it possible the noise is audio in nature, only (not electrical)?
Maybe a mic issue? Disconnect the mic plug from the audio system?
On some Permanent Magnet alternator systems, it is recommended that a
bypass capacitor be installed at the output of the regulator. A cap with
a value of 10kuF with at least a 40V rating would be adequate.
I apologize if it seems I'm repeating myself.. I just want to make sure
my non-existent Norwegian isn't causing a communication problem.
Matt-
Hi,
coils
| Quote: | are new and they work fine. Ignition cutoff work great on both cold and
(Poor
| Quote: | Norwegian).
didn't
| Quote: | get to stop completely before the transmission was over, but I could
EdgePerformance
Posted: Fri Jun 05, 2009 1:10 pm Post subject: Re: Kitfox IV - Jabiru 2200 - Icom IC-A210 Recivi |
Hi Matt,
Thanks alot for all suggestions. Yes I believe it may be alternator noise as the prop did windmill for a few second while I was receiving a transmission. I have fully charged my battery now, and will try to take a landing circuit with the alternator wires disconnected.
I use the integrated intercom in my Icom IC-A210 transceiver witch works exceptionally great. The intercom and transmissions are crystall clear.
The noise does exist on ground, but it seems to affect the radio noise even more as in flight.
I will try out all suggestions tomorrow and come back with a test resault. I have also got hold on a new RA-Miller com antenna I will try as well as a completly isolated battery.
Thanks again,
Thomas
| intercom(at)spro.net wrote: | Hello EdgePerformance,
charging system.
More questions:
Matt-
<post>
Hi,
coils
(Poor
didn't
