Attaching upper leg intersection fairing
orchidman
PostPosted: Wed Jun 03, 2009 8:31 am    Post subject: Attaching upper leg intersection fairing Reply with quote
In section 48 Gear Leg & Wheel fairings, on page 48-12 Figure 1, to attach the leg gear upper intersection fairing, the plans call for "screw #6 x 1/2 SS SMS 3 Places". I assume these are Stainless Steal Sheet Metal Screws. I can't find them listed in the hardware listing and going through all my packages, I can't find anything resembling sheet metal screws.
For those who have already passed this point, did Vans provide these screws? I know I can get them locally but no need to get dups if they were provided and I have over looked them.
I know some have gone to nutplates in all 4 locations but I am not sure if I can get to the inside for the 3 fuselage locations to try to add nut plates.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
dave.saylor.aircrafters(a
PostPosted: Wed Jun 03, 2009 8:49 am    Post subject: Attaching upper leg intersection fairing Reply with quote
Gary,
I installed some mounting points called Nut-Serts for those screws.  They install from the outside.  Then you can use a machine screw.  Just be careful however you mount them.  Fuel and brake lines are just above.
On Wed, Jun 3, 2009 at 9:31 AM, orchidman <gary(at)wingscc.com (gary(at)wingscc.com)> wrote:
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
pascal(at)rv10builder.net
PostPosted: Wed Jun 03, 2009 9:17 am    Post subject: Attaching upper leg intersection fairing Reply with quote
they're in bag# 1526 1 looks like small simple screws.
Sent: Wednesday, June 03, 2009 9:31 AM
Subject: Attaching upper leg intersection fairing
screws.
plates.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 46617#246617
n223rv(at)wolflakeairport
PostPosted: Wed Jun 03, 2009 9:23 am    Post subject: Attaching upper leg intersection fairing Reply with quote
I used rivnuts and machine screws.... No sheet metal screws in my
planes!!!
to add nut plates.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
dmaib@me.com
PostPosted: Wed Jun 03, 2009 9:25 am    Post subject: Attaching upper leg intersection fairing Reply with quote
I installed Click-Bond nut plates. They can be installed pretty
easily from the inside. Riv-Nuts or Nut-Serts would be another option.
David Maib
40559
Flying
to add nut plates.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
David Maib
RV-10 #40559
New Smyrna Beach, FL
Tim Olson
PostPosted: Wed Jun 03, 2009 10:54 am    Post subject: Attaching upper leg intersection fairing Reply with quote
And the spar, too. I had one I couldn't put where I wanted because of
the spar.
Tim Olson - RV-10 N104CD
David Saylor wrote:
Gary,
to add nut plates.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Jim Berry
PostPosted: Wed Jun 03, 2009 10:54 am    Post subject: Re: Attaching upper leg intersection fairing Reply with quote
If you want to use nut plates, one way to do it is the following:
1. Get 2 pieces of small diameter wire about 18" long. I used welding wire, but hinge pin material works also.
2. After drilling the rivet holes for the nut plate, insert one of the wires in each rivet hole. This can be done from either inside or outside the fuselage. Slide the nut plate down over both wires till it bottoms out on the fuselage skin.
3. Install a machine screw in the nut plate to hold it firmly to the skin. Remove one wire and install a blind rivet; remove the other wire and install second blind rivet.
As others have mentioned, Rivnuts or Nutserts work well also.
Jim Berry
40482
N15JB
pitts_pilot(at)bellsouth.
PostPosted: Wed Jun 03, 2009 11:19 am    Post subject: Attaching upper leg intersection fairing Reply with quote
And if you really want to prevent some aggravation, clean the nut-sert
and the aluminum around the hole and use some red Loctite or JB-weld on
the nut-sert before you squeeze it. Use anti-sieve on the screw. This
way you won't have the problem of turning the nut-sert when you remove
the screw.
Linn
David Saylor wrote:
Gary,
to add nut plates.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
Checked by AVG - www.avg.com
PostPosted: Wed Jun 03, 2009 11:27 am    Post subject: Attaching upper leg intersection fairing Reply with quote
I hate it when I do that!!! Meant riv-nut, not nut-sert. Sheesh!
Linn
the screw.
Linn
David Saylor wrote:
> Gary,
> above.
> to add nut plates.
> Dave Saylor
> AirCrafters LLC
> 140 Aviation Way
> 831-722-9141 Shop
> 831-750-0284 Cell
orchidman
PostPosted: Wed Jun 03, 2009 11:39 am    Post subject: Re: Attaching upper leg intersection fairing Reply with quote
Thanks all for the quick replies. I just ordered some nutserts from AC after I called Dave and discussed a plan of attack.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
