Rotax Tacho G-PHXS
HANDFORDP(at)aol.com
PostPosted: Mon Jun 01, 2009 10:25 pm    Post subject: Rotax Tacho G-PHXS Reply with quote
The tacho on my 912S has suddenly decided to give a maximum reading when on max power. The engine has only done 20 hours and this has only just occurred. At lower throttle settings it appears to be working correctly. I remember reading about the use of a resistor for some problems. Can anyone that may have experience of this let me know a fix. Thank you
Peter Handford
europa(at)pstewart.f2s.co
PostPosted: Tue Jun 02, 2009 9:42 am    Post subject: Rotax Tacho G-PHXS Reply with quote
Quoting HANDFORDP(at)aol.com:
that
Peter Handford
Peter
The suggestions of putting a 200ohm resistor across the tacho pick up worked a
treat for me. I wasn't sure about soldering down by the engine so I just put
the resistor across the terminals of the actual tacho itself - hey presto.
There is an atricle on trouble shooting the tacho on Rotax owners site. I've
tried to attach it here don't know if the list will strip it off.
regards
Paul
G-GIDY
Tach_Troubleshooting.pdf
 Filename:  Tach_Troubleshooting.pdf
 Filesize:  283.6 KB
 Downloaded:  165 Time(s)
PostPosted: Tue Jun 02, 2009 8:27 pm    Post subject: Rotax Tacho G-PHXS Reply with quote
Thank you Paul, yes it was attached
Peter
