emmanuel.quaesaet(at)wana Guest
Posted: Sun May 31, 2009 11:09 am Post subject: empennage rear spar riveting |
Hello
I have just begun to build an RV8, and I am experiencing my first problem.
So that's a beginner question:
I have tried several times to set one of the rivet assembling HS-702 with HS-404 and HS-405.
Now the hole is too big and I can not set the rivet.
Is there any solution? (the rivet is an AN-470 AD-4)
Thank you very much for your answers.
Emmanuel.
william_slaughter(at)att. Guest
Posted: Sun May 31, 2009 4:12 pm Post subject: empennage rear spar riveting |
First, get a rivet squeezer to use instead of the rivet gun. Select an over length rivet, and gently “pre-squeeze” it to make it swell slightly in diameter until you achieve a decent fit in the hole. Trim to length as required, then squeeze. Use the squeezer everywhere you can.
William Slaughter
RV-8 Fuselage almost finished.
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Emmanuel QUAESAET
Sent: Sunday, May 31, 2009 2:04 PM
To: RV8-List Digest Server
Subject: empennage rear spar riveting
Hello
Emmanuel.
| Quote: | | http://www.matronics.com/Navigator?RV8-List | 0123456789
