		Matt Dralle Site Admin
  Joined: 08 Nov 2005 Posts: 26477 Location: Livermore CA USA
				 Posted: Thu May 28, 2009 12:48 pm    Post subject: Mounting The Engine... |
				Dear Listers,
 I'm getting close to mounting the engine on the 'ol RV-8.  I'd like to hold off riveting the front top skin on until I'm sure all of the wiring and what not works with the various engine sensors.  Is it "safe" to mount the engine before this skin is in place?  Also, I have a QB and I noticed that none of the rivets along the sides where the cowl hinges go are riveted save for a couple of temporary pop rivets.  Can the engine be mounted before these two areas are completely riveted?
 Thanks!
 RV-8 #82880 N998RV
 Finishing Up The Wheels & Brakes...
  |  | - The Matronics RV8-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Matt Dralle
				 Posted: Thu May 28, 2009 3:23 pm    Post subject: Mounting The Engine... |
				Hum, hadn't though about actually starting the motor without the skin on.  I was just thinking about whether it would hold the static weight.  I guess to test all the wiring, the engine would really need to be started.
 So I guess I'll rephrase my question to "Could the engine be hung AND run without the top skin and sides riveted?"  ...?
 Matt
				 Posted: Thu May 28, 2009 4:03 pm    Post subject: Mounting The Engine... |
				Not sure how to respond other than why would you want to do this?
 - There should be no wiring issue that cannot be resolved after the plane is
 built.  If your design does not support this objective, you may want to make
 some changes.  An easy thing to do is to make the panel fully removable
 using Molex plugs.  I have never had to do the upside down head under the
 panel thing on my 8A.
 - All engine temperature senders can be tested with a hot air gun.  You can
 draw a vacuum for MP.  You can run the electric fuel pump to check flow rate
 and such.
 - Your first engine start essentially starts the timer to your first flight.
 You could of course go back and re-pickle the engine for storage but there
 is little to gain other scratching the itch to hear the engine (and believe
 me this is a very strong itch).
 - I would not recommend even fitting the cowl before the top skin is riveted
 on.  Remember however to take a piece of light aluminum angle across the
 baggage door before you cut out the baggage door skin - cleckoing the angle
 across what will be the open door area.  This prevents the firewall from
 flexing when you fit the cowl.
 - I suspect you will find riveting of the cowl hinges to be harder after
 mounting the engine.
 Carl Froehlich
 RV-8A (475 hrs)
 RV-10 (fuselage)
		breece28117(at)yahoo.com Guest
				 Posted: Thu May 28, 2009 4:22 pm    Post subject: Mounting The Engine... |
				I'm building an RV-8, also, and just hung�the engine a couple of weeks ago (IO-360-A1B6).  I don't think it would be good to run the engine without the top skin on.  You need to have that skin in place before you install the cowling.  Van says that you should have all your baffles and cowling in place before running the engine in order to provide adequate cooling the the cylinders.
  I've got the side and top hinges clecoed in place�around the firewall.  I don't have the top skin on yet, because I still have some work to do underneath.  I wanted to install the baffles next, but realized that the top cowl needs to be in place first.  Then I found that the prop needs to be on before the cowl is put on.  I am planning to put the prop on in the next couple of days.  The top skin has to be riveted in place before the cowl is installed, because the clecos will interfere - also to get the top of the firewall in the right place to fit the cowling.  So it looks like I'm gonna have to go back to the panel and other stuff right behind the firewall and get all that finished before I can go back to the engine side. I hope that hanging the engine will not affect the fit of the top skin.
  A question I have is: how long is it okay to have the engine exposed before it is run?  Also, what should I do to the engine before it's ready to run?  I think it might be six months before I crank it up.  It was packed at the factory for long-term storage.
  Breece
		HeathCherneski
  Joined: 08 Mar 2007 Posts: 10 Location: Enterprise, AL
		Paul Valovich
				 Posted: Fri May 29, 2009 7:11 am    Post subject: Mounting The Engine... |
				I’m building an -8A QB. I’m not ging to rivet the final top skin until the baffles, cowl and final wiring tweaks are done. I’ve got the engine hung, prop on, cowl fitted and am currently battling the black magic of the baffles. I have Skybolt cams for the cowl so fabricated the mounting strips with clecos in every hole of the firewall. Also used clecoes in every hole of the top skin.
 I will not run the engine until the top skin is riveted.  Works for me.
 Booger
 N192NM Reserved (again)
