wroe1(at)dbtech.net Guest
Posted: Wed May 27, 2009 12:06 pm Post subject: Alternator with built-in regulator |
I am building an RV-7 and have purchased a stock alternator from Vans
(in firewall forward kit). I understand this unit to have a built-in
regulator. I hope to use the B&C LR3C-14. Being new to aircraft
electronics...will this create an issue or is there something that I'm
missing?
Wade Roe
SOUTHERN CARBIDE TECHNOLOGIES, INC.
7739 Unity Road M&D Industrial Park
Tuscaloosa, AL 35401
205-248-6700
205-248-6372 fax
frank.hinde(at)hp.com Guest
Posted: Wed May 27, 2009 12:43 pm Post subject: Alternator with built-in regulator |
If the regulator is built in it means exactly that..No external regulator will be required or indeed desired... Did you get the Plane Power 60A alternator or the rebuilt Honda unit I think it is.
The Plane Power is the finest internally regulated alternator there is and Van's has the best prices on them.
If you are building an electrically dependant airplane or an IFR bird then this is the unit you should have.
Frank
Posted: Wed May 27, 2009 1:23 pm Post subject: Alternator with built-in regulator |
The alternator from Vans is a reconditioned Japanese automobile unit
(Honda?) that came with the firewall forward kit. I figured the B&C
linear regulator to be a superior/cleaner product than that on the
alternator.
The plane will be IFR and all electric.
Wade Roe
Posted: Wed May 27, 2009 1:30 pm Post subject: Alternator with built-in regulator |
At 02:59 PM 5/27/2009, you wrote:
missing?
Do you have a copy of the 'Connection? It speaks to
the various configurations for internally/externally
regulated alternators. The updated chapter on alternators
is posted at:
http://aeroelectric.com/R12A/03_Alternator_12A1.pdf
Most single engine airplanes fly with externally
regulated alternators for reasons offered in the
chapter cited above. But either configuration can
be adapted to aircraft.
If you have a Plane Power unit from Van's, know
that it has been successfully integrated into
aircraft while meeting design goals for ON/OFF,
any time, any conditions control. Further, it's
fitted with over-voltage management.
You won't need an LR-3 for this alternator.
( -Thomas Paine 1776- )
Posted: Wed May 27, 2009 1:52 pm Post subject: Alternator with built-in regulator |
In that case send that alternator back to Vans and exchange it for the plane power unit...Trying to use the B&C regulator (which it was not designed for) is a bit like putting lipstick on a pig..Its still a pig!
I futzed with a rebuilt alternator for a while and had a couple of scary moments in IMC..then I changed to the Plane power and its been faultless ever since. They come with a wonderful reputation. No electrical noise, just fit (with the supplied brackets) and forget it.
On An all electric IFR airplane the alternator is not the place to be making shortcuts!!!..The extra couple of hundred bucks is WELL spent.
Frank
RV7a..all electric IFR including 2* EI's and the fuel pumps!
Posted: Wed May 27, 2009 7:40 pm Post subject: Alternator with built-in regulator |
Wade Roe
Wade, would it be a fair assumption then that
a second alternator will go onto the vacuum
pump pad?
Posted: Thu May 28, 2009 6:10 am Post subject: Alternator with built-in regulator |
Roger that. I plan to use the B&C 8 amp alternator or the 20 amp as
backup.
Wade Roe
IPhone message
On May 27, 2009, at 10:38 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com
> wrote:
> Wade Roe
pump pad?
longg(at)pjm.com Guest
Posted: Thu May 28, 2009 6:44 am Post subject: Alternator with built-in regulator |
One caveat on P & P alts. The one I had came with what I'll call a cheap
Molex connector for the field wire etc. I replaced it with sold wiring
after it vibrated and sheared itself off for the second time. I now use
and internal job and have not had any issues. It's all about the core
quality. Alternators are one of the biggest scams in automotive history.
They cost about $10.00 to rebuild and the vendors charge you an arm and
a leg.
As Frank mentioned, start with a good core and stick with it. I'm using
one off a Porsche and it works like a champ.
Glenn
Posted: Thu May 28, 2009 7:20 am Post subject: Alternator with built-in regulator |
Me too..I found that the SD8 was adequate and remember I run electric fuel pumps..One of them MUST be running or I become a glider.
I have a GNS 430W, transponder etc etc and found that with sensible load management the SD8 would maintian the battery volts at 12..Not enough to charge the battery but it would keep up with the load.
Frank
Posted: Thu May 28, 2009 12:18 pm Post subject: Alternator with built-in regulator |
At 08:51 AM 5/28/2009, you wrote:
backup.
Most builders find the SD-8 to be adquate to the
task. Consider Figure Z-13/8.
