Posted: Thu May 21, 2009 9:11 am Post subject: Gas springs for doors |
So what specific gas springs have folks purchased for the doors on their
701s? Closed and open lengths, force, who you bought them from, etc? How
have the springs worked? Did you need to reinforce the door frame? Pictures
would be great.
-- Craig
n752ms(at)softcom.net Guest
Posted: Thu May 21, 2009 1:06 pm Post subject: Gas springs for doors |
Craig.
Go to www.ch701.com , pictures and part numbers of what I used are posted.
Mark S.
Dwight Early
Posted: Fri May 22, 2009 8:23 am Post subject: Re: Gas springs for doors |
Craig, I found a guy on Ebay that sells all different sizes and pressures and he is very reasonable.
The ones I used have 20lbs of pressure if memory serves me well and were about 12" overall length, compressed. The number on the actual shock is 38593, I am sure if you emailed him he would give you the details of the shock.
His email is ohopbob(at)yahoo.com
I would post a picture but can't seem to downsize my attachment.
20lbs holds the door up lightly, a strong will blow it shut, but when you close it, there is no strain on the frame.
_________________ Dwight Early
N701EF
Zenith CH701/Revmaster
Daleville, In |
dons701
Posted: Fri May 22, 2009 10:37 pm Post subject: Gas springs for doors |
Thanks! So p/n 9416K18 worked for you? What force did you select? It comes
in 15, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120 or 130 pounds.
-- Craig
dons701
Posted: Sat May 23, 2009 6:10 am Post subject: Re: Gas springs for doors |
Craig and all, good morning.
Have'nt bought any yet as i'm working through other issues. I was told by an employee at ZAC that the 30# rating is supposedly used for the 750. I dont know if the 750 uses the same bubble doors as what's offered for the 701, perhaps the fellow enthusiasts constructing the new 750's could help I know I will fab the door bracket to assure door is forced closed to prevent "accidental opening" by having the spring go over center at the near closed position. The length of this bracket or "arm" should'nt need to be much.
I recently had my bubble door fall from the open position from the wing sucker, which ended up breaking the back edge of my door because the harness buckle was hanging out of the door opening "just right". The sellection chart can get you what ever range you want. Hope this helps.
Don B
NYTerminat(at)aol.com Guest
Posted: Sat May 23, 2009 9:38 am Post subject: Gas springs for doors |
Craig, I used 30 lb from McMaster. Tried the 20 lb first, wasn't enough
Bob Spudis
In a message dated 5/23/2009 10:12:00 A.M. Eastern Daylight Time, burdon1(at)comcast.net writes:
| Quote: | | Have'nt bought any yet as i'm working through other issues. I was told by an employee at ZAC that the 30# rating is supposedly used for the 750. I dont know if the 750 uses the same bubble doors as what's offered for the 701 |
Recession-proof vacation ideas. Find free things to do in the U.S.
Posted: Sat May 23, 2009 12:07 pm Post subject: Gas springs for doors |
Thanks. Do you know the p/n of the spring or the open and closed lengths? And do you know how far from the hinge you fastened the spring to the door frame and the fuselage?
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com
Sent: Saturday, May 23, 2009 11:34 AM
Subject: Re: Re: Gas springs for doors
Bob Spudis
| Quote: | | http://www.matronics.com/Navigator?Zenith701801-List | 0123456789
