anthonyhiggins596(at)btin Guest
Posted: Sun May 17, 2009 8:24 am Post subject: High oil pressure |
Just been for a short flight and had to return due to VDO oil pressure gauge having gone off the clock. On ground and at low RPM, normal cruise pressure shown.
Has any one out there had this problem either with the gauge or sender or with a sticky pressure relief valve. The engine is a 3300 130 hrs. I will be checking valve tomorrow.
To: jabiruengine-list(at)matronics.com
Sent: Saturday, 16 May, 2009 8:17:58 PM
Subject: Re: 2200 Starter
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I can't talk for the black starter, but the later silver one can be removed without disturbing any other component. As I recall, three socket-head cap screws hold it on. There is an adapter nose that will come off the starter when the starter is removed, and it can only be reinstalled one way, I have found.
Lynn Matteson
Jabiru 2200, #2062, 651.8 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 16, 2009, at 2:54 PM, Chuck Deiterich wrote:
| Quote: | My 2200 engine, #988, has a black starter case with black end plate and silver cap for end bearing. I think it is a Bosch starter.
I was doing some ground tests and the engine started fine as usual. There was no sluggishness or hesitation to start. Then without any warning, the starter motor just spun without turning the engine. When I try it now, there is a “clink� noise for a split second and then the starter just spins. I suspect the starter bendix/gear is not engaging the flywheel gear.
Can the starter be removed without taking any other components off (for example the alternator or flywheel)?
If it is just the bendix/gear, can it be replaced?
Are there any special alignment adjustments when reinstalling the starter?
Chuck D.
N701TX
====== - The JabiruEngine-List Email Forum -vigator?JabiruEngine-List" target=_blank>http://www.matronics.com/Navigat= - MATRONICS WEB FORUMS -> http://forum - List Contribution Web Site -http://www.matronics.co==================
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
tonyplane(at)bellsouth.ne Guest
Posted: Sun May 17, 2009 9:15 am Post subject: High oil pressure |
I had my VDO oil pressure sender go TU at around 300 hrs, It would go to either 79 or 80 psi on my Grand Rapids (apparently the max for the Grand Rapids) even at idle but would also, at idle, swing back and forth between normal and max.
Cured with a new VDO sender from NAPA auto parts.
Tony Graziano
Zodiac 601XL/Jab 3300; N493TG; 490 hrs
mefriesen(at)mts.net Guest
Posted: Sun May 17, 2009 9:31 am Post subject: High oil pressure |
I replaced my VDO sender last fall, when during a flight, the oil pressure read to the max of 80 psi, setting off the EIS alarm. I checked the oil pressure with a manual gauge on the ground and the readings were fine. After installing the new one, pressures were very similar to the readings of the manual gauge. No issues since then. I wonder if the vibrations of the engine shortens the life of the pressure sender.
Mervin Friesen
Sonex with Jab 2200
[quote] From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of ANTHONY HIGGINS
Sent: May 17, 2009 11:08 AM
Subject: High oil pressure
Posted: Sun May 17, 2009 9:56 am Post subject: High oil pressure |
Thanks for your response.
I will check out tomorrow, pretty sure the sender is at fault.
Regards Tony
Sent: Sunday, 17 May, 2009 6:27:38 PM
Subject: RE: High oil pressure
DIV { MARGIN:0px;} I replaced my VDO sender last fall, when during a flight, the oil pressure read to the max of 80 psi, setting off the EIS alarm. I checked the oil pressure with a manual gauge on the ground and the readings were fine. After installing the new one, pressures were very similar to the readings of the manual gauge. No issues since then. I wonder if the vibrations of the engine shortens the life of the pressure sender.
Mervin Friesen
Sonex with Jab 2200
[b][b]
GREGSMI(at)aol.com Guest
Posted: Sun May 17, 2009 11:48 am Post subject: High oil pressure |
I had this problem. In cruise, the oil pressure pegged, but at idle, it seemed to register correctly. I replace the sending unit and that fixed the problem.
Greg
In a message dated 5/17/2009 11:25:18 A.M. Central Daylight Time, anthonyhiggins596(at)btinternet.com writes:
| Quote: | Just been for a short flight and had to return due to VDO oil pressure gauge having gone off the clock. On ground and at low RPM, normal cruise pressure shown.
Lynn Matteson
Status: flying
Chuck D.
N701TX
List href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
A strong credit score is 700 or above. See Yours in Just 2 Easy Steps!
Lynn Matteson
Posted: Mon May 18, 2009 2:05 am Post subject: High oil pressure |
No problems with my VDO on a 2200 and a Model 4000 EIS from Grand
Rapids Tech.
Lynn Matteson
Jabiru 2200, #2062, 654 hrs
Status: flying
<lynnmatt(at)jps.net>
Lynn Matteson
Status: flying
the engine. When I try it now, there is a “clink” noise for a split
starter?
> Thanks,
> Chuck D.
> N701TX
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon May 18, 2009 12:42 pm Post subject: High oil pressure |
No problems with my VDO on a 2200 >>
Hi,
I have a 2200 on my Kolb and have had some trouble and replaced sensers
couple of times. Now pressure builds OK but then slowly fades over 20
minutes flying. Everything seems to be working Ok, nothing loose. I have
today drained the Aeroshell 100 and replaced with 15W-50. A long shot.
Pat
