Posted: Fri May 15, 2009 11:00 am Post subject: MX20 Vertical stripes - update |
I was finally able to replicate the problem with the primary alternator, secondary alternator, and more importantly - running on battery power alone.
Contacted Garmin and they suggested I send the unit in - they replaced the display head and it is on its way back to me.
Ralph
frank.hinde(at)hp.com Guest
Posted: Fri May 15, 2009 11:46 am Post subject: MX20 Vertical stripes - update |
Excellent,
Sounds like it can't be an alternator noise problem then..I know whan I had painted steel alternator brackets (which produced high resistance ground path between the alt and the engine block) it played havoc with my GNS 430.
Finally had the "duh" moment, changed the brackets and voila no more problems.
Frank
