Posted: Fri May 08, 2009 6:17 am Post subject: Voltage Runaway on Plane Power Alternator |
At 08:35 AM 5/8/2009, you wrote:
| Quote: | G'day Everyone,
I have a strange fault that has developed on my RV7, with Plane
Power Internally regulated alternator. I bought is as it has
crowbar voltage protection built in. The aircraft has 20 hours on
it and up till recently the alternator worked fine.
The last two flights I have received Over Voltage alerts on takeoff
from my EFIS and the 5A breaker has popped - so I guess the crowbar
works as advertised and my avionics is all OK. Resetting the
breaker works fine once at pattern altitude and the prop is back to
2500 RPM or so. The unit then performs flawlessly for the rest of
the flight. I have not tried applying takeoff power at altitude, so
I cannot be certain it is the high RPM causing it.
I called the guys at Plane Power and they suggested checking the
field line and breaker which I will do tomorrow. However, this is a
pretty strange failure mode and I was wondering if anyone else on
the list had any ideas. I don't really want to risk cooking my
radios etc. There really is not much that can go wrong with the
unit's wiring as it only has two wires connected to it.
There is only one reason for an alternator to produce
TOO MUCH voltage . . . serious fault in the regulator's
ability to sense bus voltage -OR- some failure within
the regulator's itty-bitty innards.
It's unusual for an electronic failure on an integrated
circuit to be intermittent/transient as you've described.
But as you've observed, the ov protection system is ringing
loud bells to let you know that the system needs some
attention to details. It's unfortunate that you're so
remote to the Plain Power facilities. If I were Plane
Power, I'd want to get the unit back for inspection.
I think it unlikely that "loose wiring" in the airplane
would cause this, more likely that the problem is internal
to the alternator. Work closely with Plane Power. They
know more about their product than anybody else.
( -Thomas Paine 1776- )
frank.hinde(at)hp.com Guest
