george.mueller(at)aurora. Guest
Posted: Fri May 08, 2009 5:48 am Post subject: 68" prop |
I was interested in the recent post that suggested a 72" prop is what is needed for the Rotax. A 68" Woodcomp 3 blade was provided with my Skyshops FWF kit and when I switched to a Warp Drive I got a 68" also because I assumed that was the correct diameter or Skyshops wouldn't have put it in the FWF kit. How many people use a 72" prop with a 701? I have the 912 UL 80hp engine, does that make a difference? Is the 68" appropriate for the 80 hp and the 72" appropriate for the 100HP? Am I missing out on some performance with a 68" prop?
George in MIlwaukee
N701GM 62 Hours [quote][b]
n752ms(at)softcom.net Guest
Posted: Fri May 08, 2009 6:24 am Post subject: 68" prop |
George
I have the Skyshops FWF and have the 100hp Rotax. I also have the 68" Woodcomp 3 blade prop. I have it set at 14 degrees, that gives me 5450 static run up and 5500 on climb out. WOT at level flight I have 5800 rpm at 110 mph IAS, about 105 on the GPS.
Mark S.
cscsail(at)gmavt.net Guest
Posted: Fri May 08, 2009 6:26 am Post subject: 68" prop |
I also was provided with the woodcomp 3 blade for my 912 uls 100hp. I think you just need to dial in the appropriate pitch for the hp.
I'm very happy with the performance I'm getting and haven't touched it since I set it up according to the instructions.
Gordon
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Fri May 08, 2009 7:32 am Post subject: 68" prop |
I have the Woodcomp on my 100 hp Rotax on the 701 and the Warp Drive on the 80 hp Rotax on my Kitfox. All I can objectively say is that both prop/engine combos work well, but there are enough difference between the Kitfox and the 701 that to say anything more would be like comparing apples with oranges.
nyterminat(at)aol.com Guest
Posted: Fri May 08, 2009 7:43 am Post subject: 68" prop |
68" Woodcomp from Skyshops for the 100 HP
Bob Spudis
