jhartford(at)hartford-eng Guest
Posted: Sat Mar 25, 2006 6:12 pm Post subject: Model II leading edge |
I just ran into another point of confusion. I purchased the Fuselage and
wing Kit from Denny's in 1990, but never was able to get to work on it
until 2000. Purchased the remainder of the kits at that time, but again
had to differ work on the plane.
Sky Star provided the products necessary to complete kit based on using
the original wing and filled in with Model IV parts where appropriate. I
am working on the wings and can find no reference to the 24019 leading
edge in the Model II manual.
The packing list for both the original and 2000 purchase show no
reference to the leading edges. The Wing sections on the Model II and
the Model IV are quite different and I am not sure that I should be
installing the leading edge on the Model II wing.
Can any of you provide some experience on this subject. I would like to
confirm the installation of the leading edge before moving forward.
Jim Hartford
wliles(at)bayou.com Guest
Posted: Sat Mar 25, 2006 7:05 pm Post subject: Model II leading edge |
The Model II had an undercamber wing design by Dean Wilson. It used the
front spar as the leading edge and did not require the leading edge
cuff. The cuff was for the Model IV and later wings that used a new
design airfoil without the undercamber. The undercambered wing is an
excellent STOL airfoil and nicely complements the lightweight Model II.
Jerry Liles
James C. Hartford wrote:
Jim Hartford
Posted: Sat Mar 25, 2006 7:21 pm Post subject: Model II leading edge |
Thanks Jerry this is what I suspected but it is good to get a
conformation.
Jim H
Posted: Sat Mar 25, 2006 7:27 pm Post subject: Model II leading edge |
Glad I could help.
conformation.
Jim H
Posted: Sun Mar 26, 2006 6:15 am Post subject: Model II leading edge |
Thanks for the photo and the information Ron. Is there anyone that can
provide additional information on the use of the leading edge on a Model
II Wing?
Jim Hartford
Posted: Sun Mar 26, 2006 7:54 am Post subject: Model II leading edge |
There were some who did use the leading edge cuff and claimed better
performance. Perhaps they did get a bit better top speed, but maybe
not. Personally I'm skeptical. The undercamber wing is designed for
STOL performance, a broad leading edge allows for a bit higher angle of
attack. If the leading edge cuff is installed as a droop type then it
will accentuate the effects of the undercamber and it may improve STOL a
bit, but maybe not. I think it adds weight and complexity to a design
noted for light weight, simplicity, good STOL performance, and
tremendous fun. It is an airplane designed to go out and "commit
aviation" just for the heck of it. It is a pasture airplane, not a high
speed go somewhere airplane unless you have lots of time and enjoy
seeing the countryside from low and slow (which I highly recommend).
Keep it simple, keep it light, and you'll keep it fun. Add all the
bells and whistles and it'll be a Kitpig and it still won't be fast.
Jerry Liles
II Wing?
Jim Hartford
lcfitt(at)sbcglobal.net Guest
Posted: Sun Mar 26, 2006 3:31 pm Post subject: Model II leading edge |
Thanks for all of the input. My objective is a light plane with almost
no bells and whistles. I am looking for good short field performance and
do not much care about speed. If the original design worked well I plan
to leave the leading edge on the rack and continue with the original
Model II design.
Jim H Western ND
bmwebb(at)cox.net Guest
Posted: Sun Mar 26, 2006 4:30 pm Post subject: Model II leading edge |
Absolutely awesome post! I'm still chuckling.
Bradley
