CJ Extended Range Fuel Tank Installation
barryhancock
PostPosted: Mon May 04, 2009 4:02 pm    Post subject: CJ Extended Range Fuel Tank Installation Reply with quote
Gang,
People have been asking about the progress of our fuel tanks. Well, here are pics of our second installation. We are well along on our 3rd installation and have standardized the process. A bit over 31 gallons a side gives you "BBR" capability (Beyond Butt Range or Beyond Bladder Range).
[img]cid:391AEABB-B91A-4660-A990-B9D1DACD1ECF[/img]
CJ Extended Range tanks
31 Gallon Long Range fuel tank installed. 3rd strap added to support additional weight. Meets all FAA structural sheetmetal modificaiton criterion. Fuel cap with capacitance sending probe at high end of tank allowing for reading of full capacity of tank. Vent fitting not attached.
[img]cid:CA8E27A9-7D5B-4EE9-8FFB-FF7497FA35F2[/img]
US quick drain installed for ease of defuling. Original strap and fuel fitting locations and specifications.
[img]cid:E35A60E9-B716-4866-A0B7-2FA148AF4D8D[/img]
Strap bracket installation.
[img]cid:D79D9C7E-67E6-4F36-954A-54672F0858C4[/img]
Tank goes through rib which is properly reinforced.
[img]cid:149F326A-1B05-44AB-8AEB-CA5DFDCE14A9[/img]
Price is $7000 installed, or $3000 for tanks with all parts required for installation. Give us a call if you have any questions.
Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com
(909) 606-4444 office
(949) 300-5510 cell
"The complete center for warbird excellence"
Express Mailing address:
7000 Merrill Ave, B-110, Unit J
Chino, CA 91710
Regular Mailing address:
7000 Merrill Ave., Box 91
Chino, CA 91710
The information contained in this e-mail message is intended only for the personal and confidential use of the designated recipients. If the reader of this message is not an intended recipient, you are hereby notified that any review, use, dissemination, forwarding or copying of this message is strictly prohibited. Please notify us immediately by reply e-mail or telephone, and delete the original message and all attachments from your system. Thank you
 Filesize:  63.87 KB
 Viewed:  1188 Time(s)
 Filesize:  56.29 KB
 Filesize:  73.01 KB
 Filesize:  65.99 KB
 Filesize:  99.2 KB
Barry Hancock
