Mike Hoffman
Posted: Mon Apr 27, 2009 10:25 am Post subject: Wiring 912 ULS oil pressure sensor |
I have a new 100 hp 912 uls and it came with wiring to the oil pressure switch. The older engines only had one wire and the new engines now have 3 wires (black, white and red). The black is cut off and appears they are only using the Red and White.
The wiring diagrams I have do not show how to wire the new 2 wire set up to the oil pressure gage. I could guess at it but prefer not to. If I had to guess, red would go to the "S" post and the white would be added to the "-" gnd post.
Has anyone else encountered this?
Mike H
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dpark748(at)hotmail.co.uk Guest
Posted: Mon Apr 27, 2009 11:52 am Post subject: Wiring 912 ULS oil pressure sensor |
Mike C
Rotax apparently no longer use the old VDO sender and now use a Honeywell sender with red/white/black - not used/shield.
I have bought a UMA 1 1/4" gauge to match sender. White - signal/ Red - 14 volts/ Shield - to ground at the gauge.
Waiting for fuselage coming back from spraying!!!!! to fit!!!!
Regards Dave
[quote] Subject: Wiring 912 ULS oil pressure sensor
Date: Mon C 27 Apr 2009 11:25:04 -0700
--> RotaxEngines-List message posted by: "Mike Hoffman" <mhoffman9(at)tampabay.rr.com>
I have a new 100 hp 912 uls and it came with wiring to the oil pressure switch. The older engines only had one wire and the new engines now have 3 wires (black C white and red). The black is cut off and appears they are only using the Red and White.
The wiring diagrams I have do not show how to wire the new 2 wire set up to the oil pressure gage. I could guess at it but prefer not to. If I had to guess C red would go to the "S" post and the white would be added to the "-" gnd post.
Mike H
http://forums.matronics.com/viewtopic.php?p=241483#241483
Mike Hoffman
Posted: Tue Apr 28, 2009 1:12 am Post subject: Re: Wiring 912 ULS oil pressure sensor |
Thanks Dave,
I guess I now need to decide if I should replace the sender with the old VDO style or try and find a gage that matches my others.
Thanks again,
Mike H
rampil
Posted: Tue Apr 28, 2009 6:52 am Post subject: Re: Wiring 912 ULS oil pressure sensor |
Hi Mike,
Be careful of the desire to have style replace safety.
The old VDO sender was a dog which is why it was switched, big
mass on a moment arm, none too accurate either.
Best of luck with the gauge
Ira
Mike Hoffman
Posted: Wed Apr 29, 2009 3:02 am Post subject: Re: Wiring 912 ULS oil pressure sensor |
Thanks Ira, I ordered a new sender for now. Ill change it out later when I find a gage that works out. I didn't realize the old gage was a problem.
K Dilks
Posted: Wed Apr 29, 2009 11:00 pm Post subject: Re: Wiring 912 ULS oil pressure sensor |
Honey well sensor does not work on the VDO gauge.
Get the Road electronic gauge Rotax part number 956413.
Description: |
 Download |
Filename: |
956413 Oeldruckgeber technische Spezifikationen.pdf |
Filesize: |
189.75 KB |
Downloaded: |
802 Time(s) |
_________________ Back home ................. |
Mike Hoffman
Posted: Thu Apr 30, 2009 1:38 am Post subject: Re: Wiring 912 ULS oil pressure sensor |
K Dilks, Thanks for the part number.
Mike H
