Lift Reserve - installation?
msm_9949(at)yahoo.com
PostPosted: Sun Apr 26, 2009 7:04 am    Post subject: Lift Reserve - installation? Reply with quote
Can someone who has installed Kelly Meiste's unit on a Fox please post some pictures of the installation?
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
GSC
--- On Sat, 4/25/09, R.D.(Ron) Leclerc <infow(at)mts.net> wrote:
Subject: RE: Lift Reserve
To: "Bob Brennan" <kitfox-list(at)matronics.com>
Date: Saturday, April 25, 2009, 12:21 PM
--> Kitfox-List message posted by: "R.D.(Ron) Leclerc" <infow(at)mts.net (infow(at)mts.net)>
Ok here is a summary of all of the info available on Lift Reserve
indicators on the net. Its all there for you to sort out!!
http://www.surpluscenter.com/item.asp?UID=2007040300014143&catname=air&qty=
1&item=21-1623
http://www.ronleclerc.com/photos/panel/liftreserve-gaugefaces.pdf
http://www.ronleclerc.com/photos/panel/lri-guage6.jpg
http://www.ronleclerc.com/photos/panel/lri-guage2.jpg
http://glasairproject.com/GlasairI/docs/AirsoobLRI.pdf
http://home.hiwaay.net/~sbuc/journal/liftreserve.htm
http://lri.kit.googlepages.com/
http://www.liftreserve.com/
The probes could be had from John Bolding  jnbolding1(at)teleshare.net (jnbolding1(at)teleshare.net) and
Scott at http://www.cooknwithgas.com/LRI.html
I purchased mine from John Bolding for $30!
http://www.ronleclerc.com/photos/panel/lri-guage5.jpg
http://www.pipcom.com/~cowcam/AOAr.htm
There is a lot of info to go through... the most expensive one you can buy
is a heated unit at http://www.liftreserve.com/ if you decide to buy one!
R.D.(Ron) Leclerc
CH701 Plans(Scrap) Builder #7-6699
Porsche Power Geared Redrive
Winnipeg, MB Canada
4/25/2009 11:14:29 AM
This E-Mail scanned with AVG Anti-Virus Ver: 7.5!
Sad --> Kitfox-List message posted by: "Bob Brennan"
Sad
Sad
Sad Randy,
Sad
Sad Below is the reply from Kelly, along with a shout-out to you.
Sad
Sad His kit is at http://lri.kit.googlepages.com and looks really
Sad good, at the same price you paid for it. I'll be getting one!
Sad
Sad Thanks again for the reference Randy,
Sad
Sad Bob Brennan - N717GB
Sad ELSA Repairman, inspection rated
Sad 1991 UK Model 2 ELSA Kitfox taildragger
Sad Rotax 582 with 3 blade GSC prop
Sad Wrightsville Pa
Sad
Sad
Sad ------------------------------------------------------------------
Sad ---------- ---- From: Kelly Meiste
Sad [mailto:kellymeiste(at)jcwifi.com (kellymeiste(at)jcwifi.com)] Sent: 24 April 2009 4:41 pm To:
Sad matronics(at)bob.brennan.name (matronics(at)bob.brennan.name) Subject: Re: Lift Reserve
Sad
Sad
Sad Hi Bob,
Sad
Sad Thank you for the info, glad Randy is enjoying his kit!
Sad
Sad Here's the link to my website, not much has changed.
Sad lri.kit.googlepages.com
Sad
Sad Price is still the same, but I've added a few more options (black
Sad gauge overlay, and a longer tube option).
Sad
Sad Thanks for the interest, let me know if I can answer any more
Sad questions for you.
Sad
Sad Best regards,
Sad Kelly
Sad
Sad PS. Feel free to post anything about my kit (good OR bad).
Sad
Sad
Sad ---
lcfitt(at)sbcglobal.net
PostPosted: Sun Apr 26, 2009 9:22 am    Post subject: Lift Reserve - installation? Reply with quote
Marco,
I am building, so the attached photo may be of little help to you, but I
might offer a couple of suggestions. If you have a spare wing rib from the
original kit, you may be able to fabricate a mount using that that you could
insert through an inspection ring. Or you may be able to fabricate a mount
that will clamp to the tube between the fore and aft lift struts allowing
the probe to extend forward under the wing. This latter idea might be the
easiest as you may be able to route the tubing down the lift struts rather
than fishing it through the wing.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Still building
 Filesize:  34.42 KB
 Viewed:  4593 Time(s)
PostPosted: Sun Apr 26, 2009 9:56 am    Post subject: Lift Reserve - installation? Reply with quote
One more thought after looking at the photo again, the six rivet like
projections surrounding the cutout are nutserts.
Lowell
Mark.Summers(at)lwbref.co
PostPosted: Sun Apr 26, 2009 11:08 am    Post subject: Lift Reserve - installation? Reply with quote
There are a couple of these gauges on ebay for around $15.00 ea
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Marco Menezes
Sent: Sunday, April 26, 2009 10:01 AM
Subject: RE: Lift Reserve - installation?
Marco Menezes N99KX
GSC
1&item=21-1623
R.D.(Ron) Leclerc
Winnipeg, MB Canada
Sad
Sad
Sad Randy,
Sad
Sad
Sad
Sad
Sad Wrightsville Pa
Sad
Sad
Sad
Sad
Sad Hi Bob,
Sad
Sad
Sad
Sad
Sad
Sad Best regards,
Sad Kelly
Sad
Sad
Sad
Sad ---
