Posted: Fri Apr 24, 2009 6:24 am Post subject: RVSouthEast-List Digest: 5 Msgs - 04/23/09 |
Need more info on the control inputs you required to maintain a level
attitude. Certainly taking the wheel pants off would be the first step if
that is all that changed since your last flight. Was the first flight after
coming out of the paint shop? If so I would check all the rigging along with
check the balance on all your control surfaces. The little stick on weights
could have been removed, fallen off, or not fully replaced if removed.
Reweighing your plane and doing a new weight and balance on your aircraft if
certainly a consideration also. As the mauledriver said, a aft CG will
certainly make her more twitchy on the controls. Increases your cruise speed
and tightens your turn radius but with that comes the risk of a quicker
departure with an ensuing flat spin that you probably can't recover from.
Lurking YAK-50 Driver,
Roger "Doc" Kemp
YAK 50 N78YK
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: is not the same now....is me?
If it is feeling light on the controls and tending to wander in all
axiis - CG is the first thing I would check.
I am not an experienced RV flyer or test pilot. But that's what a
rearward CG feels like.
Be careful not to load anything in the back until you sort out what's
going on. If it is CG, that could be more than exciting.
Bill Watson
bertrv6(at)cfl.rr.com wrote:
Hello:
I finally had my rv6a painted some months ago. I just finished
installing the
wheel pants, except for
| Quote: | the fairings, legs/to fuselage and legs to wheel pants/
I was anxious to flight and thought that I would notice, the increase in
speed,
and maybe smoother flight?
Well to my surprise, what I found was that the plane is not stable now, I
had
to use the stick constantly
Does any one have any idea, or suggestions, I feel I am in a different
plane..
thanks
bert
rv6a
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
robertrv607(at)yahoo.com Guest
Posted: Fri Apr 24, 2009 2:05 pm Post subject: RVSouthEast-List Digest: 5 Msgs - 04/23/09 |
Thnaks for the info. I was thinking of doing just that, if by removing pants, do not
reflect any change..
the questions is , how can things change suddenly, when for the past 40 or so hours,
everything has been well, and nothing has been touch, or changed... but, things
can change by itself I* guess.
bert
rv6A
--- On Fri, 4/24/09, Roger Kemp M.D. <viperdoc(at)mindspring.com> wrote:
Subject: RE: RVSouthEast-List Digest: 5 Msgs - 04/23/09
To: rvsoutheast-list(at)matronics.com
Date: Friday, April 24, 2009, 10:23 AM
--> RVSouthEast-List message posted by: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
Roger "Doc" Kemp
YAK 50 N78YK
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
Bill Watson
bertrv6(at)cfl.rr.com (bertrv6(at)cfl.rr.com) wrote:
Hello:
installing the
speed,
had
plane..
thanks
bert
rv6a
do not arNavigator?RVSouthEast-List" target=_blank>http://www.matronics.com/Naviga= - MATRONICS &nbs http://w=======================
