Fuel return line attachment point with 912UL
Goto page Previous  1, 2
Brian Davies
PostPosted: Thu Apr 23, 2009 12:10 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Karl,
Personally, I would stick to the recommended fuel supply configuration and fit two Floscan transducers as detailed in the LAA approved mod. This ensures a constant circulation of fuel in the length of pipe that joins the two carbs together and avoids vapor locking as much as possible. If you are prepared to accept the slightly increased risk of vapor locking, ( probably more likely in the future with the changes to Mogas) you could modify the fuel system as described by Marcel and then you only need one transducer. My understanding is that this would require a new mod approval but I do know that a number of aircraft are flying with this arrangement having installed it under "standard aircraft practice" and they have not reported any problems.
Regarding the location of the transducers, mine are in the engine compartment, well wrapped in firesleeve, and have not given any problem. Again, if you have the option (Trigear) it is preferable to mount them outside the "hot" area.
The Floscan transducer is also used in marine applications and you can buy the identical part, at a "reduced" price, from www.merlinequipment.com in the UK. - Still very expensive!
Note that if you are using a FS450 configured for a single transducer you will have to swap it for a double transducer model.
As usual, you pays your money and takes your choice!
Brian
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Karl Heindl
Sent: 23 April 2009 01:25
Subject: RE: Fuel return line attachment point with 912UL
Brian,
I believe it helps a lot, but I have to think about it a little more. Are you saying that I can change my plumbing and not use a transducer in the return line ? My fuel lines are as per factory recommendations apart from gascolator and location of gascolator and fuel pump.
It would save a great deal of money; the tr. is now $ 332.- from ACS. I took advantage of the ACS discount plus the $ 175.- rebate from JPI, and payed 'only' $310 for the complete FS450
single transducer kit.
What then is the LAA recommendation and what about Ian's mod submission to the LAA ?
Cheers, Karl
Date: Wed, 22 Apr 2009 19:12:24 +0100
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Verdana } No Karl, you have not missed anything. If you install the fuel system as recommended by the factory on a Rotax 921, you need two transducers so that the return flow is subtracted from the total flow- leaving you with fuel consumption. If you change the fuel supply configuration so that the return line starts before the fuel gets to the carbs, you can then have a single feed to the carbs. The fuel flow in this single feed is the fuel consumption of the engine.
Hope that helps.
Brian Davies
Sent: 22 April 2009 18:22
Hi,
I am also very confused about what has been said so far. I will be installing a FS450 fuel flow gadget, and it calls for transducers in the flow and return lines. I am not interested in how much fuel is flowing to the engine, I am interested in the fuel consumption. And that consumption is the difference between flow and return. Have I missed something ?
BTW, I am looking for another Floscan 201 A6 with a matching K-factor.
Karl
Date: Wed, 22 Apr 2009 18:00:53 +0100
--> Europa-List message posted by: "Robert Hatton" <roberthatton1(at)googlemail.com>
Hello Graham,
I am following this thread for I shall also be looking at fitting a fuel
flow meter. Could I ask you to elaborate on your comment about ignoring the
return flow for you are only measuring the fuel to the engine. I think I
understand that with the placement of the Flowscan (from Marcel's the
schematic) no problem in measuring the fuel going to the engine. But with
the fuel coming back via the return line will that not eventually (after
going through the system) go back to the engine again via the Flowscan? The
question being, are the amounts so small not to worry about it and does this
just build in a safety margin? Sorry to sound thick on this, I am just
trying to get my head around what has been said so far and the schematic.
Robert
Robert Hatton
email: roberthatton1(at)googlemail.com
US Cell: +01 303 906 9395
UK Mobile: +44 79 66 184171
-----Original Message-----
[mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Graham
Singleton
Sent: Wednesday, April 22, 2009 1:12 PM
Subject: Re: Fuel return line attachment point with 912UL
--> Europa-List message posted by: Graham Singleton
<grahamsingleton(at)btinternet.com>
The question is, how does ignoring the return flow affect the accuracy
>> of the fuel flow instrument? It depends on the quantity of the return
>> flow of course. Is there any data about this? Maybe in the rotax
>> maintenance manuals?
> That's indeed the question I so far have not found an answer to. The
> only thing I was told by different people is that return flow varies
> with RPM, but no hard numbers on return flow have made it my way. So
> basically I *know* there will be an inaccuracy when ignoring return
> flow, but *do not know* just how large this inaccuracy is (hence my
> attempt to come up with something better for a single sender setup).
> Marcel
Marcel
The return flow does not affect your fuel flow to the engine and that is
what you are measuring. So you can forget about it with this configuration
Graham
&g=======
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
. Checked by AVG - www.avg.com
ronics.com
ww.matronics.com/contribution
No virus found in this incoming message. Checked by AVG - www.avg.com Release Date: 04/22/09 17:25:00 [/b][b]
kheindl(at)msn.com
PostPosted: Thu Apr 23, 2009 3:25 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Brian and Marcel C
Many thanks for responding to my questions. I am undecided and I think I will sit on this for a while. I have done all the preparatory work for the instrument and wiring. I may install the feed line transducer just aft of the mech. fuel pump C the engine is cool in that area. If I install a second tr. C then this would go in the tunnel. My gascolator and el. pump are located next to the nosewheel bungee.
Best regards C   Karl
Date: Thu C 23 Apr 2009 09:02:33 +0100
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Karl C
Personally C I would stick to the recommended fuel supply configuration and fit two Floscan transducers as detailed in the LAA approved mod.  This ensures a constant circulation of fuel in the length of pipe that joins the two carbs together and avoids vapor locking as much as possible.  If you are prepared to accept the slightly increased risk of vapor locking C ( probably more likely in the future with the changes to Mogas) you could modify the fuel system as described by Marcel and then you only need one transducer.  My understanding is that this would require a new mod approval but I do know that a number of aircraft are flying with this arrangement having installed it under "standard aircraft practice" and they have not reported any problems.
Regarding the location of the transducers C mine are in the engine compartment C well wrapped in firesleeve C and have not given any problem.  Again C if you have the option (Trigear) it is preferable to mount them outside the "hot" area.
The Floscan transducer is also used in marine applications and you can buy the identical part C at a "reduced" price C from  www.merlinequipment.com  in the UK. - Still very expensive!
As usual C you pays your money and takes your choice!
Brian
  Brian C
I believe it helps a lot C but I have to think about it a little more. Are you saying that I can change my plumbing and not use a transducer in the return line ? My fuel lines are as per factory recommendations apart from gascolator and location of gascolator and fuel pump.
It would save a great deal of money; the tr. is now $ 332.- from ACS. I took advantage of the ACS discount plus the $ 175.- rebate from JPI C and payed 'only' $310 for the complete FS450
Cheers C    Karl
Date: Wed C 22 Apr 2009 19:12:24 +0100
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} No Karl C you have not missed anything.  If you install the fuel system as recommended by the factory on a Rotax 921 C you need two transducers so that the return flow is subtracted from the total flow- leaving you with fuel consumption.  If you change the fuel supply configuration so that the return line starts before the fuel gets to the carbs C you can then have a single feed to the carbs.  The fuel flow in this single feed is the fuel consumption of the engine.
Hope that helps.
Brian Davies
  Hi C
I am also very confused about what has been said so far. I will be installing a FS450 fuel flow gadget C and it calls for transducers in the flow and return lines. I am not interested in how much fuel is flowing to the engine C I am interested in the fuel consumption. And that consumption is the difference between flow and return. Have I missed something ?
BTW C I am looking for another Floscan 201 A6 with a matching K-factor.
Karl
[quote] From: roberthatton1(at)googlemail.com
Subject: RE: Europa-List: Fuel return line attachment point with 912UL
Date: Wed C 22 Apr 2009 18:00:53 +0100
Hello Graham C
question being C are the amounts so small not to worry about it and does this
just build in a safety margin? Sorry to sound thick on this C I am just
Robert
Robert Hatton
rampil
PostPosted: Thu Apr 23, 2009 3:52 am    Post subject: Re: Fuel return line attachment point with 912UL Reply with quote
Hi All,
I know this has been discussed before, but the present discussion
seems to discount the fact that the 912s and the 914 return fuel
quantities are quite different. The 914 has a continuous, significant
return flow while the 912s has a negligible return flow. My
suspicion is that the flow rate in a 912s is below the range of accurate
measurement of a 201b floscan.
Ira N224XS
PostPosted: Thu Apr 23, 2009 4:56 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
rampil wrote:
Hi All,
Ira N224XS
You're probably right Ira Smile
Graham
sidsel.svein(at)oslo.onli
PostPosted: Thu Apr 23, 2009 5:12 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
For what it is worth for the discussion, which I have not followed closely:
If you use the standard Europa supplied restrictor in the fuel return line
from 912S, the return flow is an amazingly high 10 liters (approx) / a
little less than 3 USG per hour even with full fuel tank pressure head on
the return line.
I use a Flowscan (don't have the type at hand) in only the supply line. For
instantaneous fuel consumption reading I have a valve on the return line
that I close. The reading then drops about 10 liters/hour after it has
stabilized (takes a few seconds due to the design of the engine driven fuel
pump). The flow reading is accurately calibrated. I close the valve only
at level flight at low to medium altitude to minimize the risk of vapour
lock.
Svein
LN-SKJ
-----Opprinnelig melding-----
Fra: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] På vegne av rampil
Sendt: 23. april 2009 13:53
Til: europa-list(at)matronics.com
Emne: Re: Fuel return line attachment point with 912UL
Hi All,
Ira N224XS
Brian Davies
PostPosted: Thu Apr 23, 2009 5:33 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Ira raises an obvious and simple solution that again a number of Europas
have- You could simply use the standard factory fuel configuration but omit
the reurn flow transducer. The FS450 has a very simple K factor adjustment
routine that would compensate for the error caused by not measuring return
flow. The difference between the return flow at low and high power settings
is probably negligible. If you are worried about it you could always
measure it during the fuel flow checks required before first flight.
This would not require a new mod (IMHO) as the fuel system would be
standard.
Brian
mz(at)cariama.nl
PostPosted: Thu Apr 23, 2009 6:11 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
[quote:5f76066678="Barry"]Hi Marcel,
Where is your nearest airfield. If I can creep in without Mode S or an ELT I can come and show you as I am only in EDLM (near Stadtlohn).
Barry[/quote:5f76066678]
Hi Barry,
Awesome offer, I'd love to see your bird and more specifically you FF setup! My home airfield is Hoogeveen (EHHO), so that's quite close to where you are.
I will drop you an email off-forum with my contact-details so we can make an appointment for your visit. Also gives you the opportunity to have a look at my G-BWON.
Looking forward to meeting you in person.
Marcel
Visit - www.EuropaOwners.org
raimo.toivio(at)rwm.fi
PostPosted: Thu Apr 23, 2009 6:51 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Svein,
What a nice example of creativenessity!
Who can have more that than an experimentalist?
I assume you surely have a warning system for closed returnline when the gear is down? Wink
I assume when not in use you close both valves in fuel turn and returnlines?
Where is your return line valve? Near main valve?
Raimo OH-XRT
PostPosted: Thu Apr 23, 2009 7:56 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Raimo,
<I assume you surely have a warning system for closed returnline when the
gear is down? Wink
My gear is always down, it's a tri-gear! Wink
<I assume when not in use you close both valves in fuel turn and
returnlines?
On most flights, I do not touch the fuel return close-off valve - it is left
wide open to ensure full fuel return to minimize risk of vapour lock.
During the test flying, I used it to find the best speed vs. fuel
consumption. I then operated over farm fields that with some skill and luck
would allow a reasonably safe landing in case the engine stopped due to
vapour lock (it never coughed). Now I use just once in a seldom while.
Nobody reading this should install such a valve without establishing where
you are with respect to the authorities. It is a critical interference in
the fuel system - if you forget to open it again you might be in
difficulties at some stage. When I close the valve, I keep my hand on the
valve until I have registered the reading and opened the valve again.
<Where is your return line valve? Near main valve?
Instead of the standard Europa fuel tank selector valve, I have an Andair
valve recessed in the top of the cocpit module tunnel immediately aft of the
throttle to select Main/Reserve/Off.
I have used the Europa supplied valve in the fuel return line instead
(blocked off one valve branch) and fitted it in the standard fuel selector
valve location, on the left side of the tunnel. I have fitted stoppers to
prevent turning the valve too far in either direction (i.e. only 90 degr
turn).
Svein
PostPosted: Thu Apr 23, 2009 10:20 am    Post subject: Fuel return line attachment point with 912UL Reply with quote
Hello Graham,
Don't doubt your own logic! Your explanation clarifies that element of the
debate up for me! Thank you for help.
Rob
Robert Hatton
jan_de_jong(at)casema.nl
PostPosted: Thu Apr 23, 2009 12:26 pm    Post subject: Fuel return line attachment point with 912UL Reply with quote
Return flow should be roughly proportional to the square root of fuel
pressure (differential pressure across flow restrictor).
Jan de Jong
kheindl(at)msn.com
PostPosted: Thu Apr 23, 2009 2:19 pm    Post subject: Fuel return line attachment point with 912UL Reply with quote
Okay C I think I will do just that. I will modify the wiring harness to allow for a second transducer C but install another tr. ONLY if it turns out I need one. Saves a lot of money and hassle and should be completely safe.
Karl
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com>
Hi All C
I know this has been discussed before C but the present discussion seems to
discount the fact that the 912s and the 914 return fuel quantities are quite
different. The 914 has a continuous C significant return flow while the 912s
has a negligible return flow. My suspicion is that the flow rate in a 912s
is below the range of accurate measurement of a 201b floscan.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=240878#240878
06:30:00
&g============
Page 2 of 2
