Transponder questions
Deems Davis
PostPosted: Tue Apr 21, 2009 6:21 pm    Post subject: Transponder questions Reply with quote
Today, I was informed by tower that they were not receiving my
transponder, (GTX 327). Once back on the ground, I dug out the
installation manual, and found a diagnostic 'page' on the display that
purports to display the encoder input altitude, It displays both the
binary, as well as the decoded altitude, In this case it was displaying
1300 ft (baro adjust altitude at the field was 1400). To my uneducated
mind this suggests that the encoder is providing some (perhaps
erroneous). Alltitude info to the transponder. So. where should I look
next? I originally had the 'pole' antenna installed, but changed it out
for the Commant blade style, Is the antenna/coax/ connections the next
logical place to look.
Any suggestions gladly received?
Deems Davis
N519PJ Phase1
gengrumpy(at)aol.com
PostPosted: Tue Apr 21, 2009 6:36 pm    Post subject: Transponder questions Reply with quote
Might be time to invest in the IFR cert if you have an avionics guy on
your airport.......
grumpy
that purports to display the encoder input altitude, It displays
both the binary, as well as the decoded altitude, In this case it
was displaying 1300 ft (baro adjust altitude at the field was 1400).
To my uneducated mind this suggests that the encoder is providing
some (perhaps erroneous). Alltitude info to the transponder. So.
where should I look next? I originally had the 'pole' antenna
installed, but changed it out for the Commant blade style, Is the
antenna/coax/ connections the next logical place to look.
Deems Davis
N519PJ Phase1
Kelly McMullen
PostPosted: Tue Apr 21, 2009 6:38 pm    Post subject: Transponder questions Reply with quote
Were they not seeing transponder reply, or just altitude? IMHO, you
need a transponder certification anyway. Atlantic, nee Westwind used
to have that capability, and relatively cheap for VFR cert. Since you
are in Class B 30 mile arc, you need a fix pronto before the FSDO
takes an interest.
On Tue, Apr 21, 2009 at 7:18 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
Today, I was informed by tower that they were not receiving my transponder,
(GTX 327). Once back on the ground, I dug out the installation manual, and
found a diagnostic 'page' on the display that purports to display the
encoder input altitude, It displays both the binary, as well as the decoded
altitude, In this case it was displaying 1300 ft (baro adjust altitude at
the field was 1400). To my uneducated mind this suggests that the encoder is
providing some (perhaps erroneous). Alltitude info to the transponder. So.
where should I look next?  I originally had the 'pole' antenna installed,
but changed it out for the Commant blade style, Is the antenna/coax/
Deems Davis
N519PJ Phase1
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Deems Davis
PostPosted: Tue Apr 21, 2009 7:40 pm    Post subject: Transponder questions Reply with quote
Kelly they aren't seeing anything, and I'm not seeing any
'pings/replies' on the unit in the panel. I agree, this needs to get
fixed before going aloft again, don't want to wake up the bear. I do
need the cert, but I need to have something certifiable, which at
present I don't. I'm going to go down the antenna route, coax, pins,
shield, connectors, ground, etc. and see if that leads to an improvement.
Deems
takes an interest.
> Deems Davis
> N519PJ Phase1
Kelly McMullen
PostPosted: Tue Apr 21, 2009 8:06 pm    Post subject: Transponder questions Reply with quote
You are fortunate in that there is at least one, probably two ATC
radars that should splash DVT if you are clear of the hangars, on the
north ramp. PHX has a new one at Union Hills and Central Ave, and of
course Luke's radar is pretty new and also close by. So if you power
up from external power, you should be able to test ping on the ground.
With the unit getting power, lighting up, either your antenna isn't
feeding a signal in, to trigger a reply, or the transponder output is
no good. Avionics shop may be willing to see if it works on the bench,
gratis. Infant mortality is not unheard of.
On Tue, Apr 21, 2009 at 8:30 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
Kelly they aren't seeing anything, and I'm not seeing any 'pings/replies' on
the unit in the panel. I agree, this needs to get fixed before going aloft
again, don't want to wake up the bear. I do need the cert, but I need to
have something certifiable, which at present I don't. I'm going to go down
the antenna route, coax, pins, shield, connectors, ground, etc. and see if
Deems
> takes an interest.
>> transponder,
>> and
>> decoded
>> is
>> So.
>> Deems Davis
>> N519PJ Phase1
Kelly McMullen
KCHD
Barry Chapman
PostPosted: Wed Apr 22, 2009 3:43 am    Post subject: Transponder questions Reply with quote
Since the antenna was changed out, some things come to mind. 1) was the coax re-hooked back up to the new antenna? 2) A way to troubleshoot would be to put the pole antenna back on and see if they see you, if they do then it's the new antenna; if not then it's the xpdr or the wiring. 3) You could have messed up the antenna coax connector when you chnged the antenna out. 4) Anyone near by that would be willing to let you put your xpdr in their plane? Would be a quick way to see if it is the xpdr or your wiring.
Hope this helps
Barry Chapman
RV9A
Sent: Tuesday, April 21, 2009 11:03:35 PM
Subject: Re: Transponder questions
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
On Tue, Apr 21, 2009 at 8:30 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
Deems
> takes an interest.
> On Tue, Apr 21, 2009 at 7:18 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
>> transponder,
>> and
>> decoded
>> is
>> So.
>> Deems Davis
>> N519PJ Phase1
&bsp; -Matt Dralle, ===========
Barry Chapman
RV-9A in progress
Tail complete, Wings here, Engine needs rebuilt
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
msausen
PostPosted: Wed Apr 22, 2009 4:34 am    Post subject: Transponder questions Reply with quote
That was kinda my thought too. If the coax is quick and easy to get to check that first otherwise I would see if someone can bench test it just you you can eliminate that as a possibility. If you suspect the unit, let me know and I can send you my 327 to give a try.
Michael
Tim Olson
Forgive me for asking the obvious, but, you did select
ALT mode on the transponder, correct? I've seen some
people go flying without doing that (if you don't provide
some way for the transponder to auto-sense you're flying)
and then not get any altitude readout to ATC.
Deems
> takes an interest.
>> transponder,
>> manual, and
>> decoded
>> altitude at
>> encoder is
>> transponder. So.
>> installed,
>> Deems Davis
>> N519PJ Phase1
jim(at)CombsFive.Com
PostPosted: Wed Apr 22, 2009 4:43 am    Post subject: Transponder questions Reply with quote
(1) Check to see if the transponder is showing the reply indicator on the display. That is an indication that it is attempting to transmit. (I had a bad cable and even though the unit was doing the reply, it was not going out). The cable connector was faulty (My fault!)(2) Check the setup in the transponder as to what it is expecting from the EFIS. You may need to check the EFIS manual for the proper setup. Jim C40192 - Flying - 58 hours!--------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>Today, I was informed by tower that they were not receiving mytransponder, (GTX 327). Once back on the ground, I dug out theinstallation manual, and found a diagnostic 'page' on the display thatpurports to display the encoder input altitude, It displays both thebinary, as well as the decoded altitude, In this case it was displaying1300 ft (baro adjust altitude at the field was 1400). To my uneducatedmind this suggests that the encoder is providing some (perhapserroneous). Alltitude info to the transponder. So. where should I looknext? I originally had the 'pole' antenna installed, but changed it outfor the Commant blade style, Is the antenna/coax/ connections the nextlogical place to look.Any suggestions gladly received?Deems DavisN519PJ Phase1 [quote][b]
jesse(at)saintaviation.co
PostPosted: Wed Apr 22, 2009 4:57 am    Post subject: Transponder questions Reply with quote
It might be a good idea to pull out your unit & slide it in another
plane to verify the unit is good. Then I'd check for continuity & no
short in the antenna cable. If that checks good, then maybe the
antenna, but it probably is something simple & obvious once you get to
checking.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
replies' on the unit in the panel. I agree, this needs to get fixed
before going aloft again, don't want to wake up the bear. I do need
the cert, but I need to have something certifiable, which at present
I don't. I'm going to go down the antenna route, coax, pins, shield,
Deems
> takes an interest.
>> transponder,
>> manual, and
>> the
>> the decoded
>> altitude at
>> encoder is
>> transponder. So.
>> installed,
>> Deems Davis
>> N519PJ Phase1
Deems Davis
PostPosted: Wed Apr 22, 2009 6:14 am    Post subject: Transponder questions Reply with quote
Thanks to all who responded with information & suggestions. I did verify
in the air that the ALT func was selected, but no replies were being
seen in the panel. I hadn't thought of swapping, but that's a great
idea, shouldn''t be too hard to find someone to help out on that end.
Short of that, I'll have to tear out the center console and it's gadgets
in order to get into the tunnel where the antenna and cable are
mounted/routed.
URGH!!!
Deems
rv6(at)att.net
PostPosted: Wed Apr 22, 2009 8:06 am    Post subject: Transponder questions Reply with quote
Make sure antenna is grounded to mounting area. Might need to rough up the
aluminum on inside of cockpit if it is painted or primed, use an aluminum
plate with nut plates to accept antenna screws. The plate should ground to
the skin.
Jerry
n223rv(at)wolflakeairport
PostPosted: Wed Apr 22, 2009 8:21 am    Post subject: Transponder questions Reply with quote
Before you do all that, make sure you pull out and re-seat the radio
in the tray real well. Many times it is just a bad connection between
the radio and the tray itself...
On Apr 22, 2009, at 10:11 AM, Deems Davis <deemsdavis(at)cox.net> wrote:
Bob Turner
PostPosted: Wed Apr 22, 2009 9:21 am    Post subject: Re: Transponder questions Reply with quote
BTW, the altitude readout on the transponder is pressure altitude. To check its accuracy, set the aircraft altimeter to 29.92".
Bob Turner
RV-10 QB
robin1(at)mrmoisture.com
PostPosted: Wed Apr 22, 2009 9:30 am    Post subject: Transponder questions Reply with quote
Is that the pain of which you were speaking?
Robin
Deems Davis
PostPosted: Wed Apr 22, 2009 2:12 pm    Post subject: Transponder questions Reply with quote
Yeah, and I was kinda hoping that I had made my last trip upside down
underneath the panel until annual time!!!
Deems
Robin
Deems Davis
PostPosted: Wed Apr 22, 2009 7:19 pm    Post subject: Transponder questions Reply with quote
Jerry, after noodling on this, I actually think this might be the
culpret. And will be the 1st place I look. I changed out the original
'pole' antenna for a 'blade' type during the build process, and in doing
so I also installed a doubler, in looking back at the photo log it
appears that I primed the double before attaching it !?!? . I pulled the
unit and took it to an avionics shop on field today and they put it on
their tester and said it was clean, so either the encoder & connections
or antenna & connections.
Thanks to all for the help so far.
Deems
I also tried the unseat and reseat step.
the skin.
Jerry
Kelly McMullen
PostPosted: Wed Apr 22, 2009 8:01 pm    Post subject: Transponder questions Reply with quote
You also could disconnect the encoder, after verifying the antenna
grounding and see if it works in Mode A only. KISS. One step at a
time, get the basic unit working, then the encoder.
On Wed, Apr 22, 2009 at 8:16 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
Jerry, after noodling on this, I actually think this might be the culpret.
And will be the 1st place I look. I changed out the original 'pole' antenna
for a 'blade' type during the build process, and in doing so I also
installed a doubler, in looking back at the photo log it appears that I
primed the double before attaching it !?!? . I pulled the unit and took it
to an avionics shop on field today and they put it on their tester and said
it was clean, so either the encoder & connections or antenna & connections.
Deems
> the
> to
> the skin.
> Jerry
Kelly McMullen
KCHD
