Longeron and Fuselage Bending
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pitts-List
gcostabile(at)embarqmail.
PostPosted: Sun Apr 19, 2009 12:11 pm    Post subject: Longeron and Fuselage Bending Reply with quote
Looking for tips on how to jig and weld the fuselage for an S-1S. The books I can get my hands on seem to indicate the “horizontal” (in the plane parallel to the ground when the fuselage is level) bends are made using blocking squares on the jig table: block the outside according to plans, then bend the longerons to fit inside the blocking squares. When cross members are then welded, the bends are held. Same for the bottom. To bend the bottom in the vertical plane, the bottom is constructed flat, then bent. Will heat have to be applied simultaneously to both sides to make the vertical bends? Appreciate any insight.
- The Matronics Pitts-List Email Forum -
http://www.matronics.com/Navigator?Pitts-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pitts-List All times are GMT - 8 Hours
