uvtreith(at)t-online.de Guest
Posted: Wed Apr 15, 2009 2:42 am Post subject: Aileron setting and more |
Hi Europa Family,
At present I am working on fine trimming, weight and balance etc.
When I measured the angles of my ailerons, they are quite different and need correct setting.
How can I do the adjustments of this?
Thanks for help.
Best Regards,
Bruno Reith / UVT Reith
XS Mono
Brian Davies
Posted: Thu Apr 16, 2009 12:15 am Post subject: Aileron setting and more |
Hi Bruno,
From bitter experience (many wasted hours) I would recommend reading the latest factory build manual pages and following it to the letter. Provided you do every stage of the aileron rigging process, it will describe how to make adjustments to obtain the correct angles. Setting the disconnect plates vertical to a centre line drawn between the wing spar pins and adjusting the individual aileron up stops correctly before fitting the wings to the plane provides a good starting point. Get these angles wrong and nothing works as it should.
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTReith
Sent: 15 April 2009 11:41
Subject: Aileron setting and more
Hi Europa Family,
Thanks for help.
Best Regards,
XS Mono
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| No virus found in this incoming message. Checked by AVG - www.avg.com 270.11.56/2058 - Release Date: 04/15/09 06:34:00 [quote][b]
Posted: Thu Apr 16, 2009 2:06 am Post subject: Aileron setting and more |
Brian Davies wrote:
| Quote: | Hi Bruno,
Brian Davies
Bruno
Brian is right. Start by setting the up stop at the aileron, go for
23!/2 degrees, then move down the wing from there.
Bud gave a very good description of the process a few weeks ago.
Graham
