gareywittich2000(at)yahoo Guest
Posted: Sat Apr 11, 2009 7:03 pm Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
Greetings:
Back in 2000 a builder recommended a 3M product "IIRC" = silver colored windshield sealant, rubbery, can paint over.
Can not find this 3M Product on the Internet and his E-mail address in no longer valid.
Does anybody have info on this Product or a valid 3M Product Number ???
Is there an equivalent to this product ??? What did you use ???
Thanks, Garey
kboatright1(at)comcast.ne Guest
Posted: Sun Apr 12, 2009 3:55 am Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
JB weld is a good product for that application.
Deems Davis
Posted: Sun Apr 12, 2009 7:44 am Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
An award winning RV builder (Rod Bower)
http://www.ramairforhomebuilts.com/Photos/RV8/default.htm gave me a
great tip for this and appearances as well. he uses a diluted mixture of
Pro Seal, wipes it around all of his rivet lines to partially fill any
creases/voids and irregularities around the rivet head and the
skin/dimple. Said it only took him a couple of hours to do his RV8.
Deems Davis # 406
'Its all done....'
http://deemsrv10.com/
Kyle Boatright wrote:
kearney
Posted: Sun Apr 12, 2009 10:10 am Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
Hi Deems
Do you know what he used to dilute the pro-seal?
Cheers
Les Kearney
RV10 # 40643 - some assembly required
chaskuss(at)yahoo.com Guest
Posted: Sun Apr 12, 2009 12:18 pm Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
Les,
The manufacturer recommends thinning be done with Toluene, although many builders have used MEK successfully. Lacquer thinner is about 92% Toluene. I've used it many times to thin ProSeal, when straight Toluene was not available.
Charlie Kuss
--- On Sun, 4/12/09, Les Kearney <kearney(at)shaw.ca> wrote:
[quote] From: Les Kearney <kearney(at)shaw.ca>
Subject: RE: Fill MK319BS Rivet Head holes to seal out moisture
To: rv-list(at)matronics.com
Date: Sunday, April 12, 2009, 2:09 PM
Hi Deems
Cheers
Les Kearney
Deems Davis
Posted: Sun Apr 12, 2009 12:39 pm Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
I'm not 100% sure, but when I was doing the tanks, the best solvent for
ProSeal was MEK, it doesn't evaporate as quickly as Acetone, and if I
recall correctly it seems to cut the pro seal a little better.
Deems Davis # 406
'Its all done....'
Les Kearney wrote:
Hi Deems
Cheers
Les Kearney
kearney
Posted: Sun Apr 12, 2009 3:18 pm Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
Hi Deems et all
Thanks for the info.
Cheers
Les
