		maarten versteeg
				 Posted: Fri Apr 03, 2009 5:47 am    Post subject: Firewall surface treatment? |
				Hello,
 I am working on the support brackets for my 601 firewall which I made out of
 26 gauge galvanized steel as listed in the drawings. I am treating the
 Aluminum
 surfaces with self etching primer. Any ideas, suggestions on whether and
 how
 to treat the galvanized steel parts?
 Maarten Versteeg , plans #6484, reserved 581SL
 plans building 601xl, working on fuselage
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Maarten Versteeg
601XL  scratch building wings |
		bryanmmartin
				 Posted: Fri Apr 03, 2009 7:20 am    Post subject: Firewall surface treatment? |
				I left mine bare. It doesn't need any treatment, the zinc coating will
 protect it.
 On Apr 3, 2009, at 9:45 AM, mversteeg wrote:
  Hello,
  made out of
  the Aluminum
  and how
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		maarten versteeg
				 Posted: Fri Apr 03, 2009 8:28 am    Post subject: Firewall surface treatment? |
				Hello Bryan,
 I agree that the zinc coating will protect steel from the elements on
 it's own.
 My question/concern was if there was anything special that might be needed
 for the contact surfaces between aluminum and the galvanized steel to
 protect
 it over time.
 - Maarten
  	  | Quote: | 	 		   |*I left mine bare. It doesn't need any treatment, the zinc coating will
  protect it.
  On Apr 3, 2009, at 9:45 AM, mversteeg wrote:*|
 > Hello,
 > out of
 > the Aluminum
 > and how
  Bryan Martin
  N61BM, CH 601 XL,
  do not archive*
 Maarten Versteeg    Southwest Research Institute
 Phone: (210)522-5029    P.O. Drawer 28510
 Fax: (210)522-5499    San Antonio, TX 78228-0510
		bryanmmartin
				 Posted: Fri Apr 03, 2009 8:54 am    Post subject: Firewall surface treatment? |
				As I recall, I put zinc chromate primer on the aluminum where it meets
 the firewall, although it really wasn't necessary. Zinc and aluminum
 play well together, you shouldn't need any treatment between the two.
 Zinc or cadmium are the two recommended platings for fasteners used
 with aluminum because there is minimal corrosion potential between
 them. Stainless steel is another matter, aluminum will act as a
 sacrificial anode to stainless, so a coating between the two is
 necessary if there is a chance exposure to moisture.
 On Apr 3, 2009, at 12:26 PM, mversteeg wrote:
  Hello Bryan,
  on it's own.
  needed
  to protect
  it over time.
 Bryan Martin
 N61BM, CH 601 XL,
 do not archive.
Bryan Martin
do not archive. |
