Steve Tilford
Posted: Sat Mar 28, 2009 12:04 pm Post subject: IO 360-A2A cylinder stud care |
I'm starting reassembly on my engine and from the looks of it, the
cleaning, inspection and alodining process has left some crud in the 1/2
x 20 and 3/8 x 24 cylinder stud threads. Is this a wire brush job? or
can I chase them out with the appropriate threading die? I spun a
couple of the old hold down nuts on for each size, and they go on
smoothly, but I'm suspicious of the gunk. Sorry if this is redundant.
thanks,
Steve
RV-7A in process
| | - The Matronics LycomingEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
_________________ RV-7A QB, Emp Under Way |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Tue Dec 15, 2009 4:15 pm Post subject: Re: IO 360-A2A cylinder stud care |
GOOD GAWD
Please don’t ever chase male threads with a die on anything that has a remote possibility of getting off the ground. Most all engine studs and aircraft hardware (and lately even common hardware store hardware) have rolled threads which significantly increases their resistance to fatigue. If a threading die is used to clean male threads, a small amount of metal will be removed at the thread root, causing stress risers in the bolts at their weakest (narrowest) point.
[b][/b]
