7suds(at)Chartermi.net Guest
Posted: Fri Mar 27, 2009 11:49 am Post subject: Wing Strut Fairings |
All,
The wing struts for my Model 5 have the PVC fairings, the end that attaches
to the fuselage has the aft fairing squared off and covered with fabric and
then the gap between them covered with sheet aluminum. I decided I wanted to
block out all the extrusion lines in the PVC fairings so I removed the
fabric and the aluminum and found all the gaps in that area filled with
bondo, which I have removed. Is the bondo thing normal? I do not have the
instructions for the install of the struts so I was wondering what others
have done and what others have seen for a finished weight for a strut with
the PVC fairings? What have other used for fairings besides the PVC?
Lloyd C
UP Mi.
Mod 5 912ul
IVO IFA
Checked by AVG.
8:05 PM
Lynn Matteson
Posted: Fri Mar 27, 2009 1:06 pm Post subject: Wing Strut Fairings |
I have a Model IV, with the same fairings that you describe, but I
left the "extrusion lines" as is, covered them, and the sheet
aluminum at the lower end, with fabric and let it go at that.
Lynn Matteson
Jabiru 2200, #2062, 618.4 hrs
Sensenich 62x46
Status: flying
On Mar 27, 2009, at 3:44 PM, Cudnohufsky's wrote:
<7suds(at)chartermi.net>
All,
attaches
fabric and
wanted to
with
have the
others
strut with
Lloyd C
UP Mi.
Mod 5 912ul
IVO IFA
Checked by AVG.
8:05 PM
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
skyflyte(at)comcast.net Guest
Posted: Fri Mar 27, 2009 1:38 pm Post subject: Wing Strut Fairings |
Those "extrusion lines" are actually vortex generators which were part of the design to reduce drag. Eliminating them increases DRAG!!
Mike
490MC
M II 582
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Fri Mar 27, 2009 2:40 pm Post subject: Re: Wing Strut Fairings |
| 7suds(at)Chartermi.net wrote: | All,
Lloyd C
UP Mi.
Mod 5 912ul
IVO IFA
Checked by AVG.
8:05 PM |
LLoyd, I talked with The Kitfox folks at the Arlington Wash. fly in last summer before I bought my PVC strut fairing. They suggested using hysol (structrual epoxy) to fill the gaps and finish the trailing edges on the fuselage end of the fairing where they are cut. The aluminum cuff is the option they sell to cover the fuselage end. The hysol provides a sturdy base to rivet into along the trailing edge of the aluminum cuff.
The demonstrator kitfox there had the extrusion lines smoothed out. I think Debra said she had installed those and had sanded the lines off before painting the fairing.
Wood fairing covered with fabric is used also. It is a little lighter but a lot more work than the PVC.
I installed the PVC fairing according to their suggestions. I mixed cotton flox with the hysol so it is very hard when set up. I weighed before and after. Gained 12.5 pounds. I can't tell any difference in climb rate and gained about 8 MPH cruise speed with my little 52 horse engine. 84 mph true airspeed at 5800 RPM now.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Posted: Sat Mar 28, 2009 5:23 am Post subject: Wing Strut Fairings |
Mike,
Thanks for the reply, you are probably correct that they are in by design since extrusion processes have evolved to the point where the outcome will be exact to the design. I guess in my thinking I have never seen vortex generators as continual lines on a surface especially strut fairings, all the strut fairings I have seen on aircraft are smooth. I suppose if I was building a Lancair I would kick myself but since I am building a Kitfox I’m not too alarmed over my decision. Offhand do you know what the difference in drag coefficient is with and without the vortex generators on the struts? I would imagine the manufacturer would have developed some numbers before investing in the dies.
Lloyd
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of skyflyte(at)comcast.net
Sent: Friday, March 27, 2009 4:37 PM
Subject: Re: Wing Strut Fairings
Mike
490MC
M II 582
Lynn Matteson
Posted: Sat Mar 28, 2009 8:50 am Post subject: Wing Strut Fairings |
Perhaps John McBean can shed some light on these "vortex generating"
ridges? Why don't we see this same design on wings, wheelpants, etc?
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 28, 2009, at 9:23 AM, Cudnohufsky's wrote:
[quote] Mike,
Lloyd
Mike
490MC
M II 582
N369LM |
propellerdesign(at)tele2. Guest
Posted: Sat Mar 28, 2009 9:20 am Post subject: Wing Strut Fairings |
because wings ... are not under critical on Re Nr. as short chord wingstruts
are.
Jan
Posted: Sat Mar 28, 2009 11:00 am Post subject: Wing Strut Fairings |
Jan,
Excuse my ignorance but what does "critical on Re Nr. " mean?
Lloyd
Posted: Sat Mar 28, 2009 12:10 pm Post subject: Wing Strut Fairings |
it is the critical number of Reynolds number, sorry.
if it is under the critical number the drag increase, it can be helped with
some sort of VG's, look at the golf ball, the "dimples" make the air to
become turbulent near the surface, (laminar layer/turbulent layer) the
turbulent layer hold more energy that can follow the curved surface better
to the back side, making the "wake" smaller, same on wing struts, if it is
poorly shaped or to short/to fat it will help if laminar layer is tripped to
turbulent.
Jan
Lynn Matteson
Posted: Sat Mar 28, 2009 2:25 pm Post subject: Wing Strut Fairings |
So I did good to leave the ridges as is, then, on mine? Sounds like
it, and thanks for the explanation, Jan.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 28, 2009, at 4:08 PM, JC Propeller Design wrote:
<propellerdesign(at)tele2.se>
helped with some sort of VG's, look at the golf ball, the "dimples"
make the air to become turbulent near the surface, (laminar layer/
turbulent layer) the turbulent layer hold more energy that can
follow the curved surface better to the back side, making the
"wake" smaller, same on wing struts, if it is poorly shaped or to
short/to fat it will help if laminar layer is tripped to turbulent.
Jan
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Mar 31, 2009 4:41 pm Post subject: Wing Strut Fairings |
Lloyd,
I sanded them off with a belt sander then finer sand paper, then used a
sanding primer (maybe a bit of spot putty first) and painted right over
them - no lines.
Lowell
Posted: Tue Mar 31, 2009 4:52 pm Post subject: Wing Strut Fairings |
I respectfully disagree that these are vortex generators. If you look at
the ridges, they exactly line up with the internal beads designed to grip
the lift strut. With a thicker mass of hot plastic in these areas, a
disproportunate amount of shrinkage will occur on the surface opposite the
beads - presto a slight depression.
Lowell
Posted: Wed Apr 01, 2009 6:38 pm Post subject: Wing Strut Fairings |
Lowell,
Thanks for the feedback, that is pretty much the process I am using other
than beginning with an automotive DA Sander.
Lloyd
