mark.supinski(at)gmail.co Guest
Posted: Sun Mar 22, 2009 1:53 pm Post subject: Z-19 + Ford regulator killing batteries? |
Hello All-
I have a system based on the Z-19 drawing for an EFI based airplane. Getting ready to fly for the first time, but I am now almost convinced my setup is killing the batteries for some reason. I have gone through 3 already over the last 16 months just testing out the airplane & running the engine in test spurts.
Here's the symptoms, hopefully someone can shed some light:
- Recommended Ford regulator
- 2x UB 12220 22AH batteries (3" w x 7" l x 6.5" h)
- 80 Amp alternator
My engine monitor keeps complaining that the alternator is putting out too high a voltage (typically 15.0 - 15.5 after start with the engine running). Don't know if this is just because the batteries were just discharged starting the engine -- haven't had long enough engine runs to see if the load drops.
All the batteries fail the same way -- suddenly they won't hold a charge & output only 3v or so. Just had another one fail today.
After doing some additional reading, I am starting to wonder whether these seal mat batteries are such a good idea. The literature suggests they are quite finicky on how to recharge.
I must confess that I may have killed the batteries myself. I have an external battery cart & I have simply been hooking the batteries up & setting the charger to 40amp when the batteries were running down. The batteries seem to want an initial charge of 3 amps or less before upping the amperage.
Help!
Mark
Posted: Mon Mar 23, 2009 3:54 pm Post subject: Z-19 + Ford regulator killing batteries? |
At 04:52 PM 3/22/2009, you wrote:
| Quote: | Hello All-
Here's the symptoms, hopefully someone can shed some light: - Recommended Ford regulator
- 80 Amp alternator
My engine monitor keeps complaining that the alternator is putting out too high a voltage (typically 15.0 - 15.5 after start with the engine running). Don't know if this is just because the batteries were just discharged starting the engine -- haven't had long enough engine runs to see if the load drops. |
No . . . the regulator has one responsibility only. HOLD the
bus at 14.2 to 14.6 volts under ALL conditions where the
alternator is turning fast enough to shoulder system load
AND recharge the battery.
| Quote: | | All the batteries fail the same way -- suddenly they won't hold a charge & output only 3v or so. Just had another one fail today.After doing some additional reading, I am starting to wonder whether these seal mat batteries are such a good idea. The literature suggests they are quite finicky on how to recharge. |
EVERY battery hates to be charged at 15+ volts. The
difference is that you can pour water into some
batteries . . . others simply become re-cycle
fodder.
| Quote: | | I must confess that I may have killed the batteries myself. I have an external battery cart & I have simply been hooking the batteries up & setting the charger to 40amp when the batteries were running down. The batteries seem to want an initial charge of 3 amps or less before upping the amperage. |
An external power supply should ALSO be set
for 14.2 volts. You say it's a "battery cart"
with a current setting? Sounds like an AC mains
power supply of some kind. 14.2 volts is the
rule. Recharge rates are a problem only if
you deeply discharge the batteries. If you have
ground power available, then there's no good
reason to deeply discharge the battries.
It sounds like lack of attention to voltage control
is the root cause of your difficulties.
( -Thomas Paine 1776- )
Posted: Mon Mar 23, 2009 7:11 pm Post subject: Z-19 + Ford regulator killing batteries? |
On Mon, Mar 23, 2009 at 5:52 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | At 04:52 PM 3/22/2009, you wrote:
| Quote: | Hello All-
- 80 Amp alternator
So this suggests that the regulator has a problem. It is certainly generating bus voltages in excess of 15.0v -- I have 2 devices which display voltage & both agree within 1v of each other that voltages are above 15. I can't imagine the regulator is adjustable, so it must be a dud, correct?
fodder.
The 110v charger allows one to set how many amps to charge with & for how long -- it puts out 14.5V while charging. However -- *EVERY* AGM battery I have seen claims a maximum charging amps of 7A or less. This confuses me since I don't know how to control this when they are being recharged via the alternator. Some I have seen say "Initial" charging amps, others say Max.
Here is what I see in the manufacturer's literature for my batteries:
Charge Method (Constant Voltage) - Cycle Use - Initial Current - 7.7A or smaller
Charge Method (Constant Voltage) - Cycle Use - Control voltage - 14.5 - 14.9 V
Charge Method (Constant Voltage) - Float Use - Control Voltage - 13.6 - 13.8 V
There is no good reason to discharge the batteries... except when one forgets to turn off the master switch & the ECU quietly continues running all week as the acft sits in the hangar.
If certainly has my attention now! If step one is to replace that regulator, I'll do it forthwith. If another step is to follow a different procedure when ground charging (or get a smaller charger) I'll certainly do that too.
Thanks, Bob -- appreciate the help.
Mark
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
rv-9a-online(at)telus.net Guest
Posted: Tue Mar 24, 2009 8:29 am Post subject: Z-19 + Ford regulator killing batteries? |
In my opinion your regulator is working fine, but the wiring to the inputs of your regulator is suspect. Poor connections, too small a gauge of wiring or faulty (resistive) switches will cause overvoltage when the alternator is heavily loaded.
Bob has an article that discusses this, you'll have to search his website.
Here's the fix that I did on my RV-9A to eliminate this problem:
http://www.vx-aviation.com/rv-9a/photos/Electrical/Regulator_relay_app.jpg
The K3 relay is wired firewall-forward directly from the battery (using a fuselink) and the regulator. D17 is not strictly necessary, but guards against a dual failure (stuck relay and overvoltage at the same time). I went from varying charging voltage (up to 15.5V) to rock-solid 14.2V.
Vern Little
Vx Aviation
JohnInReno
Posted: Tue Mar 24, 2009 9:53 am Post subject: Z-19 + Ford regulator killing batteries? |
Vern Little wrote: Slightly off topic, but I notice a Hall Effect sensor (S5) that appears to be on the forward side of the firewall. I am installing an AFS 3500 with a Hall Effect sensor and two alternators ala Z-13/8. I would like to keep all of the alternator and regulator stuff firewall forward but the EMS wants the Hall sensor on the cabin side. Is there any problem with the Hall sensor living on the firewall?
John Morgensen
RV9A
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
Posted: Tue Mar 24, 2009 11:01 am Post subject: Z-19 + Ford regulator killing batteries? |
| Quote: | No . . . the regulator has one responsibility only. HOLD the
Vern brings up another possibility . . . excessive
drop in the regulator's field supply wiring. Take
a look at:
http://aeroelectric.com/Pictures/Regulators/Ford_Test_Reg.jpg
Wire up your regulator like this and install it
directly to the back of the alternator. See what
happens to the bus voltage when all aircraft wiring
is out of the circuit.
I am skeptical that this is the problem. THAT large
an upward shift would almost always cause severe
instability too . . . but give it a try and report
back.
| Quote: | An external power supply should ALSO be set
There is no good reason to discharge the batteries... except when one forgets to turn off the master switch & the ECU quietly continues running all week as the acft sits in the hangar. |
Okay. Assuming the manufacturer's literature is the
"bible" for battery recharge protocols. How are you
going to comply with them after the airplane is
finished?
If you've every driven a car with a battery ammeter
(discharge-zero-plus display) you'll recall that after
starting the engine, the ammeter lays over to the charge
side with some gusto. After a few minutes, it tapers back
to some point just above zero. The same thing will happen
in your airplane. After cranking the engine (and perhaps
running some electro-whizzies during pre-flight) how do
you plan to limit the recharge rates to values requested
by the manufacturer of your battery?
The point is there is no practical way to limit the
recharge rate . . . nor is it necessary.
| Quote: | | If certainly has my attention now! If step one is to replace that regulator, I'll do it forthwith. If another step is to follow a different procedure when ground charging (or get a smaller charger) I'll certainly do that too. |
The charger you have is just fine. It sounds like
some form of programmable 'smart charger'. When
used to recharge a stand alone battery, it will
have a recharge profile something like this:
http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf
Here's what another charger does when it was
being used like a "ground power" support supply.
http://www.aeroelectric.com/Pictures/Curves/schumacher_4.jpg
Another concern is the 22 a.h. rating of the batteries.
This battery package size started out as a 17 a.h.
device. In later years 20 and now 22 a.h.
ratings were offered. I'm thinking they may have
achieved a larger 20 hour discharge capability at
the expense of robustness.
If you replace these critters, I'd have more
confidence in their robustness as beat-n-bash
airplane batteries if they were rated more like
their ancestors. A validation of this idea can
be found in ratings for the Odyssey PC680 which
is rated at 17 a.h. The vast majority of
product in that package size are 17 or 18 a.h.
batteries. I think I'd steer clear of "stretched"
versions.
Bob . . . [quote][b]
chasb(at)satx.rr.com Guest
Posted: Wed Mar 25, 2009 7:41 am Post subject: Z-19 + Ford regulator killing batteries? |
My Ford regulator is adjustable. Mine was set at 13.8 volts. No problems so far.
Charlie Brame
RV-6A N11CB
San Antonio
Time: 12:01:39 PM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: Z-19 + Ford regulator killing batteries?
| ----------------------------snip--------------------------
