BEBERRY(at)aol.com Guest
Posted: Wed Mar 22, 2006 11:22 am Post subject: Revs |
Just recently there have been a number of letters which have indictaed that
914 flyers , and maybe others, are using a peak rpm of 5800 on take off. I
have always thought that 5,700 was the limiting number. Has there been a
change?
Patrick
Posted: Wed Mar 22, 2006 11:31 am Post subject: Revs |
BEBERRY(at)aol.com a crit :
change?
Patrick
Hey Patrick,
I think the ower's manual as not changed since 1998 regarding power
settings. How old is your engine ?
Downloadable from any good Rotax-related website
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Wed Mar 22, 2006 2:10 pm Post subject: Revs |
Hi Giles -build started (not by me) in 1999. Engine purchased 2002. Any
further commenrts on rev limits appreciated.
Patrick
Posted: Wed Mar 22, 2006 2:20 pm Post subject: Revs |
Patrick
Patrick,
That is about the date we bought our engine. In the crate you have the
manuals in English and German.
You can download them from the download section in my website or from
the Rotax website.
The limit is 5800 rpm.
Gilles Thesee
Grenoble, France
hdwysong(at)gmail.com Guest
Posted: Wed Mar 22, 2006 2:23 pm Post subject: Revs |
Hello Patrick -
10.1.1 of the Operator's Manual (July 01/2004, Rev 3) says 5800 rpm (5
min.) for Take-off, 5500 rpm Max continuous, and ~1400 rpm for Idle.
http://www.rotax-aircraft-engines.com/pdf/dokus/d03378.pdf
D
Patrick
Posted: Wed Mar 22, 2006 3:32 pm Post subject: Revs |
Gilles -- thanks , Patrick
Posted: Wed Mar 22, 2006 9:10 pm Post subject: Revs |
Hello Patrick
"I have always thought that 5,700 was the limiting number"
Like others have said 5800RPM is POH limit. That said you need a accurate
tachometer to measure. Airmaster on their Constant Speed uses 5700RPM for
take off power, 100RPM buffer so as to not overshoot the 5800 rpm redline.
I think 6100RPM was the number Phil Lockwood said the valves begin to
float.
Ron Parigoris
william(at)wrmills.plus.c Guest
Posted: Wed Mar 22, 2006 10:59 pm Post subject: Revs |
Hi Patrick and all,
May I suggest you do not rely on the accuracy of the Rotax tachometer.
After 200 hours, mine was found to be under reading by 300 rpm, which meant
I had been taking off regularly at 6,100 without knowing! Fortunately, I
never cruised at 5,500. Apparently it is not unusual for Rotax tachos to be
out of calibration to that extent.
Best wishes,
William
Posted: Thu Mar 23, 2006 1:45 am Post subject: Revs |
In a message dated 23/03/2006 07:00:29 GMT Standard Time,
william(at)wrmills.plus.com writes:
Hi Patrick and all,
Best wishes,
William
Thanks for that William. Patrick
topglock(at)cox.net Guest
Posted: Thu Mar 23, 2006 7:31 am Post subject: Revs |
I've heard the same thing about the Rotax tachs. Fortunately, the
Airmaster prop controller takes its RPM reading from the prop and
constrains the engine according to that reading. Or so I've been told.
So far (at 150hrs) the tach coincides with the factory set numbers
(5700, 5400, 5000) set up in the prop controller. I've also heard that
improper adjustment of the ignition/tach pickups can cause errant tach
readings...
Jeff - N55XS
150 hrs, and now on autopilot...
Hi Patrick and all,
Best wishes,
William
tonyk(at)kaon.co.nz Guest
Posted: Thu Mar 23, 2006 12:39 pm Post subject: Revs |
Quote: | > Fortunately, the Airmaster prop controller takes its RPM reading from
the prop and constrains the engine according to that reading. Or so
I've been told.
That's correct. There is a rotational sensor built into the Airmaster
prop and that is used to provide feedback to the the prop speed
controller.
Tony
