europa(at)pstewart.f2s.co Guest
Posted: Tue Mar 17, 2009 10:49 am Post subject: TCU / throttle software |
Just about to set the throttle using Tlr46.exe software. Understand
that this gets done with TCU powered up but engine not running. If I
run the engine will the 'Montor' menu of the software give me a real
time rpm readout? - 'cos still trying to sort out non functioning tacho.
Paul
G-GIDY
Posted: Tue Mar 17, 2009 1:24 pm Post subject: TCU / throttle software |
Hi! Paul
| Quote: | From my memory the TCU set up procedure handles percentage power linked
to throttle position. I don't think the TCU deals with RPM.
This then leaves the pilot to ensure that RPM limitation is secured by
propeller setting.
Certainly my Rotax Tacho isn't linked to anything other than the engine.
However my Smart Avionics Propeller Controller gives a power and RPM
read out for the Woodcomp Wobbly Prop
I am however just little perplexed why no one else has replied since
I'm no authority on subject!
Bob Harrison G-PTAG
h&jeuropa
Posted: Wed Mar 18, 2009 4:19 am Post subject: Re: TCU / throttle software |
Paul,
The monitor program gives a read out of all sorts of engine parameters including RPM. You use it with the engine not running to set throttle position but you can certainly use it with the engine running to see RPM and for trouble shooting.
Jim Butcher
N241BW
Posted: Wed Mar 18, 2009 9:41 am Post subject: TCU / throttle software |
Bob
From the screen shots of the software in the heavy maintenance manual
there appears to be both % power and rpm. Also the signal for my Rotax
tacho is an output from the TCU.
Paul
On 17 Mar 2009, at 21:21, Robert C Harrison wrote:
Hi! Paul
> linked
propeller setting.
engine.
Bob Harrison G-PTAG
