		asarangan(at)yahoo.com Guest
				 Posted: Sun Mar 19, 2006 9:32 pm    Post subject: Aileron deflection angle |
				When attaching the ailerons to the wing, the manual calls for 25-deg up
 and 22-deg down (for a final travel of 23.5-deg up and 20-deg down).
 I don't have any problem with the 22-deg down, in fact, mine goes down
 as far as 35-deg. But the up-swing is only about 20-deg. This is after
 drilling holes for the anchor nuts to enter the leading edge of the
 aileron.
 I am not sure how to get another 5-degrees. The manual does not address
 this issue. Is there something I am missing??
 Andrew Sarangan
 http://www.sarangan.org
		ward.t(at)xtra.co.nz Guest
				 Posted: Sun Mar 19, 2006 11:28 pm    Post subject: Aileron deflection angle |
				Andrew,
 Adjust the aileron bell crank settings to get the required displacements. I
 think the manual does mention this at the end.
 Cheers,
 Tim Ward
 12 Waiwetu Street,
 Fendalton,
 Christchurch, 8005
 New Zealand.
 Ph +64 3 3515166
 Mobile 021 0640221
		Troy Maynor
				 Posted: Mon Mar 20, 2006 4:56 am    Post subject: Aileron deflection angle |
 aileron.
 Andrew Sarangan
 http://www.sarangan.org>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
 Andrew,
 I think shortening or lengthening the rod going through the wing will change
 the setting. However, be aware that the mechanical stop that the bell crank
 hits,(not the counter weight)is the limit for the opposite aileron. It was
 an exercise in patience for me to say the least.
 Troy Maynor
 N120EU Europa Monowheel Classic
 Left to finish:
 Paint,interior,engine install, wiring.
 Weaverville, NC USA
				 Posted: Tue Mar 21, 2006 7:21 pm    Post subject: Aileron deflection angle |
				Jeremy,
 That is exactly right. I am referring to the deflection without the
 pushrods attached.
 The gap between the hinged surfaces is more than the 1.5mm called for
 in the manual; however, I have not checked whether that's where the
 deflection is being restricted.
 I am assuming the neutral position (zero-degrees) to be when the
 aileron is aligned with the trailing edge of the wingtip. I think that
 makes sense because that would make the most streamlined situation to
 be zero-degrees.
 --- Jeremy Davey <europaflyer_3(at)msn.com> wrote:
  I think what Andrew's saying is not that the pushrods won't allow him
  the
  movement, but that the aileron is fouling on the wing when he tries
  to get
  up deflection with the pushrods disconnected.
  Andrew, it sounds to me like you need to check the following:
  1) the positioning of your hinges - are they too close in?
  2) your start point for zero degrees deflection - are you starting
  from a
  few degrees out?
  I hope this helps.
  Kind regards,
  Jeremy
  Jeremy Davey
  Europa Monowheel 537M G-EZZA
  Europa Club Vice-Chairman, Webmaster, PFA NC Representative
  PFA EC Member
  "If you can keep your head when all about you are losing theirs, then
  it is
  possible you haven't grasped the severity of the situation."
  Tail done
  Standard XS wings with mods underway
  CM installed in fuse (with airbrakes fittings)
  1430 build hours to date, build currently stalled due to house moves
  and
  lack of workshop
  Intended fit:
  Rotax 914 turbo, Airmaster CS fully-feathering prop
  Lots of lights, buttons, switches, gizmos, and alarms
 Andrew Sarangan
		asarangan(at)YAHOO.COM Guest
				 Posted: Tue Mar 21, 2006 8:36 pm    Post subject: Aileron deflection angle |
				OK, I figured out where the aileron is getting snagged. It is rubbing
 against the top surface of the aileron closeout (which is on the
 trailing edge of the wing) throughout its entire range of motion. This
 is what is restricting its max travel to 20-degrees. I can even see
 where this rubbing pressure has even lifted portions of the closeout
 skin that used to be bonded to the sides at the root end of this
 closeout.
 One solution is to trim about 5mm from the closeout's upper lip.
 However, I am not sure if this will cause any problems when bonding the
 top skin on. Any ideas are appreciated.
 --- Andrew Sarangan <asarangan(at)yahoo.com> wrote:
  Jeremy,
  pushrods attached.
  that
  be zero-degrees.
  him
  > the
  > to get
  > from a
  > few degrees out?
  > I hope this helps.
  > Kind regards,
  > Jeremy
  > Jeremy Davey
  > PFA EC Member
  then
  > it is
  > Tail done
  moves
  > and
  > lack of workshop
  > Intended fit:
  Andrew Sarangan
 Andrew Sarangan
		dglauser(at)gmail.com Guest
				 Posted: Tue Mar 21, 2006 8:49 pm    Post subject: Aileron deflection angle |
				Let it rub for now. When applying the top skin, you can use mixing
 sticks to provide space between the aileron and the closeout. Any
 subsequent rubbing can be handled by removing a bit of the trailing
 edge of the closeout.
 I trimmed mine back and thought all was well. Then when it came time
 to bond the top on I found I did not have enough bonding area and the
 top skin was not firmly on in places. (Inspection was done with a
 small "lipstick" TV camera placed in the wing through the access
 panels.) I ended up having to cut more access panels, apply more
 epoxy/glass and adhesive through them, reinforce the panel edges, and
 reinstall the skin cutouts. A royal pain.
 David
 On 3/21/06, Andrew Sarangan <asarangan(at)yahoo.com> wrote:
  closeout.
  > Jeremy,
  > pushrods attached.
  > that
  > be zero-degrees.
  > him
  > > the
  > > to get
  > > from a
  > > few degrees out?
  > > I hope this helps.
  > > Kind regards,
  > > Jeremy
  > > Jeremy Davey
  > > PFA EC Member
  > then
  > > it is
  > > Tail done
  > moves
  > > and
  > > lack of workshop
  > > Intended fit:
  > Andrew Sarangan
  Andrew Sarangan
		Roger.Mills(at)btinternet Guest
				 Posted: Wed Mar 22, 2006 1:58 am    Post subject: Aileron deflection angle |
				It might just be worth checking the Europa service bulletins - a batch of XS
 wings were made with the close-out fixed too far towards the trailing edge
 and this would certainly have an impact on the available deflection.
 The fix is to remove the close out and re-install slightly further forward.
 I forget the service bulletin number but a check with Roger or Andy at the
 factory might be wise.
 Roger Mills
 G-BVUV
		keithhickling(at)clear.ne Guest
				Andrew,
 I have just done this part too. I found the main restriction on aileron
 deflection occurred where the upper aileron closeout joins the wingtip
 moulding.  Most of the upper closeout can move upwards a little with the
 aileron, but at the tip where it is tethered it can not move. I found that
 cutting forwards a few mm where the rear edge of the upper closeout joins
 the tip moulding allowed sufficient upward deflection of the aileron without
 having to actually trim the closeout  (even though the aileron continues to
 rub on the upper closeout - it is meant to do that at this stage).
 Keith
				 Posted: Wed Mar 22, 2006 10:55 am    Post subject: Aileron deflection angle |
				I wish the manual had mentioned that the rubbing motion is normal at
 this stage. Any kind of rubbing would seem abnormal unless mentioned.
 Also, reading ahead, I saw that you are supposed to trim the close-out
 skin along with the wing skin after the top skin is bonded on.
 On my wing, the main restriction to the aileron deflection is at the
 root end, where the upper closeout is bonded to an end-cap. I spoke to
 Andy at Europa, and he said that the end-cap is not that critical, and
 I could snip the joint to relieve the pressure.
  Andrew,
  aileron
  wingtip
  the
  that
  joins
  without
  continues to
  Keith
		wdaniell(at)etb.net.co Guest
				 Posted: Wed Mar 22, 2006 2:05 pm    Post subject: Aileron deflection angle |
				My aileron channels were too closed - apprently some came out like that.
 Nev recommended that you could cut the flange to a minimum of 5/8 - although
 you might want to check with Nev about that.
 In the end the despite cutting back, the "closing" of the channel led to a
 1/4 gap between the top skin and the channel flange. The aileron channel was
 far too strong to be bent by force.  So I applied heat and opene the channel
 to the right proflie and then reinforced with bid.
		jan.de.jong(at)xs4all.nl Guest
