bakerocb
Posted: Mon Mar 20, 2006 11:28 am Post subject: Key Ignition Switch |
3/20/2006
Hello Fellow Builders, Several of us have a real dislike for the key type
ignition switches found in many type certificated airplanes and also
installed by builders who may just assume "that's the best way".
The following web page offers another data point on why that type of
ignition switch is dislked by many of us.
http://www.avweb.com/news/columns/191792-1.html
OC
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Mar 20, 2006 12:07 pm Post subject: Key Ignition Switch |
Obviously, the article describes a skew, as it was a defective switch "out
of the box".
But, you must also look at the size of the ring of keys involved in
situations like this. If your airplane key is one of the 50 keys on that 2"
key ring, you are putting mechanical loads on the switch that it was not
designed for.
But in the interests of learning something here, how would you secure your
airplane other than with a keyed ignition switch?
bakerocb
Posted: Mon Mar 20, 2006 12:20 pm Post subject: Key Ignition Switch |
3/20/2006
Please put this in web page form starting
here//http://www.avweb.com/news/columns/191792-1.html
OC
frank.hinde(at)hp.com Guest
Posted: Mon Mar 20, 2006 12:51 pm Post subject: Key Ignition Switch |
Yes and if the this type of switch fails on a mag it sort of fails
same...sort of...If it fails when you have both electromic ignition
sysytems running through it your engine will quit.
That is why over and over again we warn of not using ANY single single
point of failure common to both ignition systems (or fuel pumps for that
matter).
In other words you need an indvidial on/off switch for each critical
component.
Good reminder OC
Posted: Mon Mar 20, 2006 1:00 pm Post subject: Key Ignition Switch |
You can still use a keyed switch but better to make sure it only
controls a single ignition and the starter. The second ignition will be
on a separate switch. Hard to start it unless you want to swing the prop
by hand.
Frank
mprather(at)spro.net Guest
Posted: Mon Mar 20, 2006 1:16 pm Post subject: Key Ignition Switch |
Hi Bill,
With a chain around the propeller.. How about a padlock through the guard
on the toggle switch which controlls the starter?
How do you propose that a key switch provides significant security for
your airplane? Granted, the dumbest criminals don't know how a magneto
works, but the determined ones will. As has been discussed here in the
past, airplanes are easy to hotwire.
BTW, I don't think multiengine airplanes have keyswitches...
Matt-
<bdenton(at)bdenton.com>
"out of the box".
2" key ring, you are putting mechanical loads on the switch that it was
not designed for.
your airplane other than with a keyed ignition switch?
rv8ch
Posted: Mon Mar 20, 2006 1:23 pm Post subject: Key Ignition Switch |
| Quote: | Hello Fellow Builders, Several of us have a real dislike for the key type
Me too. I'm leaning towards a canopy lock and a prop lock. I've
also seen a very clever control stick lock.
Got any better suggestions?
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
BigD(at)DaveMorris.com Guest
Posted: Mon Mar 20, 2006 2:04 pm Post subject: Key Ignition Switch |
I'm wondering more about the kid at Oshkosh that likes to push buttons,
than the hardened criminal who thinks he's gonna steal an airplane with the
word "EXPERIMENTAL" written all over it and a bunch of controls he's never
seen before in his life.
Dave Morris
At 03:22 PM 3/20/2006, you wrote:
<mick-matronics(at)rv8.ch>
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Mar 20, 2006 3:52 pm Post subject: Key Ignition Switch |
In an RV-8 you could install a switch in the front baggage compartment that
disables the starter switch. You would probably only use it when you thought
there was some risk, such as leaving the plane out overnight or at a fly-in.
Locking the baggage compartment would prevent anyone from getting to the
switch.
Terry
RV-8A finishing
Seattle
<BigD(at)DaveMorris.com>
Dave Morris
type
| Quote: | > ignition switches found in many type certificated airplanes and also
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
lhelming(at)sigecom.net Guest
Posted: Mon Mar 20, 2006 7:46 pm Post subject: Key Ignition Switch |
I secure mine by locking the canopy. If someone wants to break the canopy
and fly my plane with winds blasting them smack in the face, that is their
life they will risk.
Indiana Larry
Posted: Mon Mar 20, 2006 8:11 pm Post subject: Key Ignition Switch |
Bill,
Do a quick friendly ramp check on your local Bell 206 JetRanger. There is a
key switch that enables/disables the starter circuit, but in itself has no
bearing on the operation of the start switch. In fact the keyswitch is on
the Pilot's side of the center console beside his calf, and the starter
switch is on the collective. I'm thinking about using some kind of
arrangement like this to disable the starter circuit on my airplane and keep
it safer from theft...
Rob
RV-10
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Mar 20, 2006 8:52 pm Post subject: Key Ignition Switch |
Dave Morris "BigD" wrote:
And that happens. I climbed into my airplane to fly in the airshow at
OSH several years ago only to find every switch in the airplane, master
included, turned on and battery dead. No flight for me that day.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
bicyclop(at)pacbell.net Guest
Posted: Mon Mar 20, 2006 9:09 pm Post subject: Key Ignition Switch |
A throttle lock would do more good than a key switch.
Pax,
Ed Holyoke
nuckollsr(at)cox.net Guest
Posted: Mon Mar 20, 2006 10:07 pm Post subject: Key Ignition Switch |
At 09:07 PM 3/20/2006 -0800, you wrote:
Pax,
. . . or a padded chain over the prop. I've talked with
numerous operators who prefer this method. It's right out
in front so the midnight airplane shopper will see it
right off. Further, it's right out in front where any
attempts to removed it (time consuming) is more
likely to be observed. It's inexpensive even when the
hardest chain and locks are used and one size fits most.
http://www.aeroelectric.com/Pictures/Misc/AC_Theft_Protection.jpg
A keyed mag switch is only a slight inconvenience. I once
lost the key to a rental machine and brought the
airplane home by breaking the p-lead terminals off the
back of the mags with my fingers, hand-propped the
airplane and came home. 20 minutes with a crimp tool
and strippers repaired the 'work-around' and I cut some
new keys from the office spare. Others have told me
that they did similar work-arounds by breaking the
terminals off at the mag switch. One or the
other is easy to get at. If you're really
crude . . . a pair of diagonal wire cutters works too.
aerobubba(at)earthlink.ne Guest
Posted: Tue Mar 21, 2006 4:30 am Post subject: Key Ignition Switch |
I too will be locking my canopy. In addition, there will be a specific
switch configuration for starting. For example, when shut down, all
switches will be off. While in operation, a certain minimum number of
switches will be on. For starting, there will be one of those 'minimum for
flight' switches that will be off. This is a DPDT, with the start
contactor circuit using one set of contacts. Anyone not familiar with this
configuration will not be able to crank my plane. Those who don't have as
complex an electrical system could easily do the same sort of thing by
requiring the dome light to be on, or an auto pilot armed, or the baggage
light to be on, or any other switch not normally associated with engine
starting. The bad guy will most likely assume a problem with the plane and
move on. Of course, a prop lock will tend to make him select an easier
target before breaking into your plane...
Glen Matejcek
aerobubba(at)earthlink.net
harley(at)AgelessWings.co Guest
Posted: Tue Mar 21, 2006 5:06 am Post subject: Key Ignition Switch |
Morning, Glen...
I too agree that a canopy lock is probably the best route. Maybe both
that and the prop chain.
Sure, a prop lock would prevent them from flying off with the plane, but
if all they are after is the neat avionics that we experimental builders
tend to install....
If they REALLY want the plane or avionics, then they smash the canopy,
and/or they call their friendly neighbor with a flat bed truck.
We can't prevent all attempts of thievery if someone really wants it,
but at least the canopy lock will keep the little kids from touching the
instruments and switches with their peanut butter coated fingers when
we're not around.
Harley Dixon
Long EZ N28EZ
Glen Matejcek wrote:
| Quote: | >But in the interests of learning something here, how would you secure your
Glen Matejcek
Posted: Tue Mar 21, 2006 5:40 am Post subject: Key Ignition Switch |
I've got a throttle quadrant from an F-100 and I'm going to use one of the
switches on top of the handle for my starter switch. That way I don't have
to take my hands off the throttle or stick to do an in-flight restart. The
key switch on the ignition is just for the ignition, and the starter won't
run with the key off either, but you don't turn the key to crank the starter.
http://www.davemorris.com/Photos/Dragonfly%20Electrical/WiringTheCenterSwitchPanel.jpg
Dave Morris
At 12:02 AM 3/21/2006, you wrote:
<nuckollsr(at)cox.net>
>Pax,
steveadams
Posted: Tue Mar 21, 2006 7:46 am Post subject: Re: Key Ignition Switch |
Back to the original post. As far as I know, most common production GA aircraft use a keyed starter switch. I understand it can fail, just like any other switch. I also understand redundancy is usually a good thing, however you need to balance redundancy with complexity and risk potential. You also have to ensure that your "fix" is not more failure prone than the original. I'm no expert, but there are a lot of experts designing and building aircraft you start with a key. Of the millions of flights made with a keyed switch, how many accidents have been attributed to a failed switch? Are there any service letters, SB's, or AD's addressing a problem with the switch? I'm not trying to be argumentative, but I have a keyed ignition switch as called for in my aircrafts design, and wonder if this is really something that I should be concerned about.
brinker(at)cox-internet.c Guest
Posted: Tue Mar 21, 2006 7:49 am Post subject: Key Ignition Switch |
This may have been discussed before. I was thinking about
putting a simple toggle switch in an out of the way place maybe under the
instrument panel on the pilot side or even under the cowl close to the
firewall on the outside. If it we're outside no one would even notice that
you switched it on during preflight and what thief would ever suspect or
understand such a setup. I think my main concern would be an avionics thief
tearing up my instrument panel and stealing multiple thousands of dollars
worth.
Randy
jlbaker(at)telepath.com Guest
Posted: Tue Mar 21, 2006 8:28 am Post subject: Key Ignition Switch |
| Quote: | AD's addressing a problem with the switch?
http://tinyurl.com/j3m5j
Jim Baker
580.788.2779
'71 SV, 492TC
Elmore City, OK
