cfrhoads(at)YAHOO.COM Guest
Posted: Wed Feb 18, 2009 6:37 pm Post subject: LED LANDING LIGHTS |
Since I have always been unhappy with the output of my landing lights and their large appetite for power, I was happy to find some LED lights that looked very promising. The lights from J.C. Whitney use about .5 amps and their output is MUCH better than the old halogen ones. Every thing is great until I try to transmit and then there is a huge amount of interference.
Any suggestions?
Chuck Rhoads
A100 Louisville, KY
110 hours
__________________________________________________________
craigb(at)onthenet.com.au Guest
Posted: Thu Feb 19, 2009 2:59 am Post subject: LED LANDING LIGHTS |
are you sure your lights are LED, in theory LED should offer nil EM interference. Maybe HID???
[quote] --
frans(at)paardnatuurlijk. Guest
Posted: Thu Feb 19, 2009 3:26 am Post subject: LED LANDING LIGHTS |
craig bastin wrote:
Quote: | are you sure your lights are LED, in theory LED should offer nil EM
LED's use a much lower voltage than 12 volts. If I were to build a
powerfull LED system, I would use a switching power supply to avoid
converting to much voltage into heat. Switching power supplies are
notorious for their ability to generate EM interference.
Frans Veldman
rick.sivier(at)btinternet Guest
Posted: Thu Feb 19, 2009 8:27 am Post subject: LED LANDING LIGHTS |
I'm sure that I saw something in a magazine a little while ago about LED
strobes. Has anyone had any direct experience of these? Can they be as
bright as a normal strobe?
Rick
Posted: Thu Feb 19, 2009 12:03 pm Post subject: LED LANDING LIGHTS |
I made my own LED strobes. I modified a circuit for flashing lighthouse to
get the desired pulses and duration
basically its a 555 timer running a decade step counter to give you ten
possible "ON" positions for the strobes
then tapped off that on say pin 1 and 3 which gives you a nice quick double
pulse and and about 4 seconds off
time. this can be adjusted by the resistor on the 555 timer. This the drives
the LED strobe head which consists
of a 3x3 array of 280,000 mcd leds which makes it about the same size as
typical strobe, but you could make
it any shape you want just by moving the LED's around. The LED's are running
on 12v but they are set up in series. Its took a little bit of fiddling but
after 2 test runs I got the resistance correct and they ran for 2 months
on a car battery before the battery went flat. As for brightness, I would
say they are equally as bright as a
comercial strobe unit. given the slight overdiving of the leds they should
be around 3000 candle power per pulse.
they are easily visible in full sun enough to not be desirable to look at.
craig
Posted: Thu Feb 19, 2009 5:18 pm Post subject: LED LANDING LIGHTS |
Craig,
J.C. Whitney advertised them as LED lights; however, that doesn't mean a whole lot. How do you tell the difference?
Chuck Rhoads
cfrhoads(at)yahoo.com
322 Links Dr.
Simpsonville, KY 40067
(502) 410-1357
Sent: Thursday, February 19, 2009 6:06:49 AM
Subject: RE: LED LANDING LIGHTS
DIV { MARGIN:0px;} are you sure your lights are LED, in theory LED should offer nil EM interference. Maybe HID???
[quote] --
rampil
Posted: Fri Feb 20, 2009 3:55 am Post subject: Re: LED LANDING LIGHTS |
LED high intensity elements are often pulsed to achieve higher
output within thermal constraints hence RFI
ami(at)mcfadyean.freeserv Guest
Posted: Fri Feb 20, 2009 2:08 pm Post subject: LED LANDING LIGHTS |
The difference is that a HID light (typcally of 35watts) would drain about 3 amps, not 0.5amp, and burn-off your retinas!.
Duncan McF.
Posted: Sat Feb 21, 2009 12:36 am Post subject: LED landing lights |
Hi ChickI took a look at JC Whitneys LEDs [url=http://www.jcwhitney.com/autoparts/ProductBrowse?storeId=10101&Pr=p_Product.CATENTRY_ID:2017635&productId 17635&catalogId=10101]http://www.jcwhitney.com/autoparts/ProductBrowse?storeId=10101&Pr=p_Product.CATENTRY_ID:2017635&productId 17635&catalogId=10101[/url] They look like the same Fog driving LEDs that Pep Boys sells. Pep Boys sell them for 49.99 for pack of two.I purchesed both the round and rectangle LEDs to fool with and a Kitfox builder wanted the one that looked more suitable, so I am going to return the round and send him the rectangle.I checked the rectangle one tonight and sure enough it makes a lot of noise in a handheld vertex VXA-700. What is making the noise is the regulator that drops battery voltage down to LED voltage. The package I have has a button you can push and run one LED off two button batteries that are supplied in package and radio is dead silent. Anyway you need to find a cleaner way to supply voltage to the LEDs, don't use supplied regulators or clean them up.I will put up a few pics in gallery in near future with.Ron Parigoris [quote][b]
