Use of Transponder TRIG TT31 Mode S
uvtreith(at)t-online.de
PostPosted: Wed Feb 18, 2009 4:09 am    Post subject: Use of Transponder TRIG TT31 Mode S Reply with quote
Hi Europa Family
Walter Swoboda / Germany has installed in his Classic Monowheel the TRIG TT31.
Is there somebody who is using the same Transponder and is this Transponder already registered for use in a Europa?
If so, please send the Approval Letter.
In this case Walter can use this also for his Europa showing the LBA and has not to do the quite expensive and time killing Flight Tests for this Transponder.
Many thanks for help in this matter.
All the Best to all of you,
Bruno
