gareywittich2000(at)yahoo Guest
Posted: Mon Feb 16, 2009 6:29 pm Post subject: Elevator Horn Weldment - Installation |
Greetings:
Ref - RV-8A:
When trying to attach the Elev Horn Weldment to the Elev Spar and Root Rib, the Weldment did NOT lay flat against the Spar and Root Rib simultaneously. Measured the Weldment's angle of 68 degrees. The angle formed by the Spar and Root Rib is 70 degrees. Inorder to get the Weldment angle to spread from 68 degrees to 70 degrees, MUCH force is needed. This does not seem right as too much stress would be applied to the Spar / Root Rib / Weldemnt combination.
Both Left and Right Weldments measure 68 degrees. (I have an OLDER Kit, so maybe this could be the problem where the NEWER Kit is 70 degrees.)
Has anybody else experienced this and how did you handle it ??
Appreciate your help !!!!
Garey Wittich Santa Monica, CA (310) 392-1682
Garey
william_slaughter(at)att. Guest
Posted: Tue Feb 17, 2009 3:22 am Post subject: Elevator Horn Weldment - Installation |
I adjusted the position of the root rib to match the angle of the weldment.
Will Slaughter
RV-8 Fuselage
Subject: Elevator Horn Weldment - Installation
Greetings:
Ref - RV-8A:
combination.
Garey
