hills(at)sunflower.com Guest
Posted: Thu Feb 05, 2009 8:39 pm Post subject: a gentle suggestion |
In the case I Mentioned before about the insurance company denying a claim
because of a "major" change being done after the DAR had oked the plane, I
must say that the unfortunate builder sunk his own boat.
He made the mistake of actually entering the changes, that he made to the
fuel system, into his log book as he made them, thus giving the bean
counters at the insurance company something to use against him, his own
words.
I say "mistake" because as he tried different changes to the fuel system, he
entered the changes into the log book, just as any good law abiding fellow
would do. But, as it turned out, he didn't like the changes, so he
reconfigured his fuels system into it's ORIGINAL configuration just before
his accident. Fine ok, well no.
Even though he had gone back to the original fuel system configuration, as
ok'ed, by the DAR, the insurance company tried to deny his claim saying that
he had made major changes to the fuel system without notifying the FAA and
therefore nullifying this insurance. The fact that he reverses the changes
before the crash did not matter to the insurance company; they still wanted
to deny the claim.
The moral of this story might be.... change many, enter once.
Roger
Gig Giacona
Posted: Fri Feb 06, 2009 6:24 am Post subject: Re: a gentle suggestion |
| hills(at)sunflower.com wrote: | In the case I Mentioned before about the insurance company denying a claim
words.
to deny the claim.
Roger
Or the moral of the story might be follow the law. He made his mistake in notifing the FSDO of the changes has he made them and following the rules.
It amazes me how many folks here are suggesting pencil whipping the logs to get around what is a pretty clear order from the FAA. Somebody up thread gave as a reason for doing so that it would keep your plane in test period forever. My response to that is that if you keep making major changes it should remain in test phase because you are testing the fracking thing.
It makes you wonder if the builders of some of the accident aircraft didn't do the same.
And just for the record here is the text of the rule in questions.
REF: FAA Order 8130.2E-- January 23,2003
(19) After incorporating a major change as described in § 21.93, the aircraft owner is
required to reestablish compliance with § 91.319(b) and notify the geographically
responsible FSDO of the location of the proposed test area. The aircraft owner must
obtain concurrence from the FSDO as to the suitability of the proposed test area. If the
major change includes installing a different make and model of engine or propeller, the
aircraft owner must fill out a revised Form 8130-6 to update the aircraft's file in the FAA
Aircraft Registry. All operations must be conducted under day VFR conditions in a sparsely
populated area. The aircraft must remain in flight test for a minimum of 5 hours or for the
time the FSDO assigns. Persons nonessential to the flight must not be carried. The aircraft
owner must make a detailed logbook entry describing the change before the test flight.
Following satisfactory completion of the required number of flight hours in the flight test
area, the pilot must certify in the records that the aircraft has been shown to comply with §
91.319(b). Compliance with § 91.319(b) must be recorded in the aircraft records with the
following, or a similarly worded, statement: "I certify that the prescribed flight test hours
have been completed and the aircraft is controllable throughout its normal range of
speeds and throughout all maneuvers to be executed, has no hazardous characteristics
or design features, and is safe for operation. The following aircraft operating data has
been demonstrated during the flight testing: speeds Vso ______, Vx ______, and Vy
______, and the weight ______, and CG location ______ at which they were obtained."
601XL Under Construction
Afterfxllc(at)aol.com Guest
Posted: Fri Feb 06, 2009 7:05 am Post subject: a gentle suggestion |
You guys crack me up... You take things and blow them so out of proportion. If I take a 2700 cc corvair engine out of my plane and replace it with the exact same engine it isn't a major change it is a replacement not change. Now if I were to install a o 235 that would be a major change. You guys need to go flying more and stop flying in 5 hour circles.
Using some of your logic I guess every prop pitch change is a Major change and should be written in the logs.... Geeezzz
Jeff
Great Deals on Dell Laptops. Starting at $499.
yak52
Posted: Fri Feb 06, 2009 7:21 am Post subject: a gentle suggestion |
Since the ZBAG group has been brought up, we haven't heard their usual comments lately. Does that mean their independent study results have come through, as rumored, with no significant findings? Or perhaps are they in possession of the dreaded design defect and they're just waiting for accidents so they can rejoice in the inury to others? [quote][b]
Posted: Fri Feb 06, 2009 7:26 am Post subject: a gentle suggestion |
if you want to know pay your money and find out.
| Quote: | | Since the ZBAG group has been brought up, we haven't heard their usual comments lately. Does that mean their independent study results have come through, as rumored, with no significant findings? Or perhaps are they in possession of the dreaded design defect and they're just waiting for accidents so they can rejoice in the inury to others? |
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Fri Feb 06, 2009 8:42 am Post subject: a gentle suggestion |
On Fri, Feb 06, 2009 at 10:19:04AM -0500, roger lambert wrote:
| Quote: | Since the ZBAG group has been brought up, we haven't heard their usual
I'm a member of ZBAG, and I did contribute to the analysis fund.
I find the last comment well over the line. It's not my place to annoucne
where things are currently, but I will note that there has never, ever been
any suggestion of rejoicing in injury to others. I, and I'm pretty sure the
other contributors, did so to put the incessant rumors and sniping to bed
once and for all (I know, that's a faint hope...). If there is a problem, it
won't be kept a secret, either from the community or Zenith.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
bryanmmartin
Posted: Fri Feb 06, 2009 9:07 am Post subject: a gentle suggestion |
§ 21.93 Classification of changes in type design.
(a) In addition to changes in type design specified in paragraph (b)
of this section, changes in type design are classified as minor and
major. A “minor change” is one that has no appreciable effect on the
weight, balance, structural strength, reliability, operational
characteristics, or other characteristics affecting the airworthiness
of the product. All other changes are “major changes” (except as
provided in paragraph (b) of this section).
Experimental amateur built aircraft are not issued a type certificate.
Each one is a unique aircraft. There is no document that describes the
details of every system on the airplane. It would be foolish to
document any minor change to the airplane that can't be independently
verified by the FAA or insurance company. That just gives some pompous
bureaucrat or insurance adjuster an excuse to screw you over, just
because they can. As I see it, I built my airplane, I know it better
than any other person alive, if I determine that a change I make isn't
going to cause a hazard to anyone else (by performing a proper test
flight sequence in a safe manner, if necessary), it's nobody else's
business.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Rhino
Posted: Fri Feb 06, 2009 9:44 am Post subject: Re: a gentle suggestion |
| Gig Giacona wrote: | hills(at)sunflower.com wrote:
| Quote: | ....Even though he had gone back to the original fuel system configuration, as
therefore nullifying this insurance.... |
Or the moral of the story might be follow the law. He made his mistake in notifing the FSDO of the changes has he made them and following the rules. |
The current rules don't require that the FSDO approve any major changes. They simply require a logbook entry and a flight test period, both of which are the responsibility of the builder/owner/pilot, not the FAA. The only place an FSDO is involved is in approving the location of the flight test area, not in approving the change.
The old rules used to require FSDO inspection and re-certification, from 1985 to 1993. From 1993 to 1999 the inspection and re-certification requirement was dropped, requiring only a written approval of the change from the FSDO. From 1999 to 2004 no FSDO involvement was required whatsoever, totally eliminating a approval requirement. From 2004 on, there is only the FSDO approval of the location of the test area required, again not approval of the change itself.
The FSDO does not approve your major changes, and you are not required to discuss the change with them beyond what affect the change may require on the testing location. As such, your insurance company cannot deny a claim because there was no FAA notification of the specific major change itself. And this only applies to the five hour test period anyway, a period that is assigned by you, not by the FAA.
As for what hills(at)sunflower.com wrote, the legality would not only depend on the details of the circumstances, but also as to when this actually happened.
Does a change to your fuel system plumbing really qualify as a major change? Admittedly subjective since the FAA never specifies what major change actually means, but likely it is not.
When did this happen, and what rules were in effect at the time?
Was the test period actually adhered to?
Did the incident occur during the test period?
If yes, was the aircraft being operated within the specified test area?
Without that information, none of us can adequately judge if the actions of either party were proper or improper.
By the way, although the original date of Order 8130.2E is January 23, 2003, two changes have been made to it since then. The 2004 requirement I mention above was one of those changes.
_________________ Bob Simmons
CH 750
N750TN (reserved) |
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Fri Feb 06, 2009 10:05 am Post subject: a gentle suggestion |
I do not choose to post on the Matronics Lists about the 601XL's safety record, because it is just not worth the flames. However today's post from Mr. Lambert demands a response.
I have never met Mr. Lambert. To my knowledge he has never met me. The builders and owners who have contributed to ZBAG are a small group who look at the safety record of the 601XL and draw the conclusion that, just maybe, the design of the 601XL is not perfect. And, realizing that, they have chosen to contribute to an independent analysis of the design so that they can feel more comfortable flying the airplanes in which they have invested thousands of dollars and hours. That Mr. Lambert can suggest that any ZBAGer is some sort of a ghoul who would get pleasure out of the death of fellow 601XL builder is beyond the pale. Unfortunately it is the sort of thing that can and does appear on the Matronics Forum. How very sad! I think that Mr. Lambert owes an apology to every single one of the ZBAGers whom he has slandered today.
ZBAG shares all of our reports with both Zenith Aircraft Co., the NTSB, and the FAA. What they do with the information provided is up to them.
Regarding access to that same information, Jeff said it very well:
At 10:23 AM 2/6/2009 -0500, Afterfxllc(at)aol.com wrote:
| Quote: | | if you want to know pay your money and find out. |
Terry Phillips, Proud to be a ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
bryanmmartin
Posted: Fri Feb 06, 2009 10:25 am Post subject: a gentle suggestion |
The most recent document is
ORDER 8130.2F
CHG 3
Effective Date:
April 18, 2007
http://tinyurl.com/cy4qav
On Feb 6, 2009, at 12:44 PM, Rhino wrote:
approving the location of the flight test area.
Bryan Martin
N61BM, CH 601 XL,
Bryan Martin
do not archive. |
Gig Giacona
Posted: Fri Feb 06, 2009 12:05 pm Post subject: Re: a gentle suggestion |
[quote="bryanmmartin] As I see it, I built my airplane, I know it better
business.
[/quote]
And I agree with you there. But that really isn't the point in question. The issue I'm arguing against and the one that sooner or later could bite us in our collective homebuilding butts is those that would do a major change (a real honest major change) and not follow the rules. And lets face it the rules give us a lot more freedoms in what we do to our planes than do some other country's rules.
Those rules are that way because overall we have followed them or at least not hurt too many people when we didn't. Should the FAA and/or NTSB see that it isn't working they will right more rules. If you doubt that just look at what is happening with the 51% rule.
Rhino
Posted: Fri Feb 06, 2009 12:41 pm Post subject: Re: a gentle suggestion |
| bryanmmartin wrote: | The most recent document is
ORDER 8130.2F
CHG 3
Effective Date:
April 18, 2007
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive. |
Thanks. That pretty much says what I posted, but even more detailed.
CH 750
N750TN (reserved) |
Gig Giacona
Posted: Fri Feb 06, 2009 12:57 pm Post subject: Re: a gentle suggestion |
OMG.... I some how missed this pearl of wisdom on my first pass through the messages. Of course changing the engine is a major change. And if you don't see the difference between an engine swap and a prop pitch change you are a danger to yourself, anyone that flies with you and anybody that is nearby when you are flying.
| Afterfxllc(at)aol.com wrote: | You guys crack me up... You take things and blow them so out of proportion. If I take a 2700 cc corvair engine out of my plane and replace it with the exact same engine it isn't a major change it is a replacement not change. Now if I were to install a o 235 that would be a major change. You guys need to go flying more and stop flying in 5 hour circles.
Jeff
Posted: Fri Feb 06, 2009 1:40 pm Post subject: a gentle suggestion |
Ok Gig
Here is the reg... now show me where this is a major change
major. A “minor change� is one that has no appreciable effect on the
of the product. All other changes are “major changes� (except as
Now does it effect the weight? NO
Does it effect the Balance? NO
Does it effect the structural strength? NO
Does it effect Reliability? NO engine for engine should be just as reliable
Does it effect operational characteristics? NO
Does it effect other characteristics affecting the airworthiness of the product? NO
All you have to do is make a log book entry of the serial # change of the engine.
As I said if you change engines ie a Corvair to a O 235 that would be a major change.
But you do what you like and stay in flight testing forever Gig.
And you can leave the personal attacks for the KR list. Somehow because you think you know everything and I disagree with you I somehow put people in danger is a stupid statement on your part.
Jeff
--> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com>
| Quote: | You guys crack me up... You take things and blow them so out of proportion. If I take a 2700 cc corvair engine out of my plane and replace it with the exact same engine it isn't a major change it is a replacement not change. Now if I were to install a o 235 that would be a major change. You guys need to go flying more and stop flying in 5 hour circles.
Jeff
| Quote: | --> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com>
Jeff
Posted: Fri Feb 06, 2009 2:24 pm Post subject: a gentle suggestion |
bryanmmartin
Posted: Fri Feb 06, 2009 3:01 pm Post subject: a gentle suggestion |
Even on type certificated aircraft, I don't think replacing an old
engine with a new one of the same make and model is considered a major
change.
On Feb 6, 2009, at 3:57 PM, Gig Giacona wrote:
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
Posted: Fri Feb 06, 2009 3:56 pm Post subject: a gentle suggestion |
You don't, all you do is write the new engine info in the logs and go fly. I will agree that if in our case you didn't fly a few hours around the patch whether required to or not would be foolish but we don't have to if we choose not to.
Like most of the rules made by the FAA they are allowing for pilots to make the right decisions and most would but a few won't and some of the rules are left to interpretation.
Some A&P's don't fly and they change out engines all the time and simply sign them off and the pilot goes flying... I was shocked by this and thought this is crazy but that's how it's been done for years and as long as we self police the system works well.
Jeff
| Quote: | Even on type certificated aircraft, I don't think replacing an old
change.
JAPhillipsGA(at)aol.com Guest
Gig Giacona
Posted: Fri Feb 06, 2009 8:23 pm Post subject: Re: a gentle suggestion |
A type certified engine is assumed to be reliable. A auto conversion isn't or at least shouldn't be until tested.
Posted: Fri Feb 06, 2009 11:17 pm Post subject: a gentle suggestion |
OK GUYS, HERE IS THE ORIGINAL COURT TEXT,,, READ AND LEARN FROM IT !!!!!
Roger
MAGILL, Senior Circuit Judge:
Avemco Insurance Company (Avemco) issued an insurance policy covering
William Davenport's home-built experimental aircraft. After Davenport's
aircraft crashed on May 7, 1995, Avemco sought a declaration from the
district court that, because Davenport had not complied with the terms of
the policy, Avemco had no duty to defend or indemnify Davenport for any
claims arising from the accident. The district court granted summary
judgment in Avemco's favor, and Davenport now appeals. We affirm
I.
Davenport, an experienced pilot and builder of experimental aircraft, holds
a private pilot certificate and a repairman's certificate issued by the
Federal Aviation Administration (FAA). Prior to the events giving rise to
this case, Davenport built a "VariEze" aircraft from plans he purchased from
Rutan Aircraft. Davenport eventually sold the VariEze and began building a
second aircraft in 1992. The second plane was built largely from Rutan
Aircraft's "Long EZ" plans. Because Davenport made several modifications to
these plans, he refers to his hybrid design as the "Davenport Long EZ."
In September 1994, Davenport purchased an amateur-built aircraft insurance
policy from Avemco, which provided coverage from September 13, 1994, to
September 13, 1995. The policy contained an exclusion from liability that
stated:
This Policy does not cover bodily injury, property damage or loss . . .
[w]hen your insured aircraft is in flight unless it[ ] is certified for
flight by the FAA, initially, and after a modification which requires
recertification.
Avemco Policy at 3 (emphasis omitted) (Policy Exclusion).
The FAA initially certified Davenport's aircraft as airworthy in April 1993,
but conditioned Davenport's airworthiness certificate on thirteen "Operating
Limitations. " One limitation required that "[t]he cognizant FAA Flight
Office must be notified and their response received in writing prior to
flying this aircraft after incorporating a major change as defined by [14
C.F.R. S 21.93]." Special Airworthiness Certificate, Operating Limitation
No. 10 (emphasis added). A major change is any change having any
"appreciable effect on the weight, balance, structural strength,
reliability, operational characteristics, or other characteristics affecting
the airworthiness of the product." 14 C.F.R. S 21.93(a) (1993).
According to Davenport, his aircraft was equipped with a gravity feed fuel
system at the time of the FAA's initial certification. This design relies on
gravity to transfer fuel from the fuel tanks through a fuel line and into
the engine. After receiving his initial certification, Davenport made a
series of changes to his fuel system without notifying the FAA. Davenport
first converted the gravity feed system into a pressurized fuel system by
installing a mechanical fuel pump and an electric boost pump. After flying
the aircraft for fifteen hours, Davenport removed the fuel pumps and
reconfigured the system to its original gravity feed design, again without
notifying the FAA. Hoping to improve the performance of his aircraft,
Davenport soon reinstalled the mechanized fuel pumps but again failed to
inform the FAA of this change. Davenport eventually grew dissatisfied with
the pressurized fuel system, and he removed the pumps--once again without
notifying the FAA. In sum, following the FAA's initial certification,
Davenport made four modifications to the design of his fuel system without
notifying the FAA of these changes or seeking FAA recertification of his
aircraft.
On May 7, 1995, with the most recent version of the gravity feed fuel system
in place, Davenport crashed his aircraft near an airport in Santa Monica,
California. The accident caused property damage on the ground, which in turn
spawned numerous claims against Davenport in California state courts.
Avemco filed this suit in federal district court, asserting diversity
jurisdiction and seeking a declaration that it had no duty to defend or
indemnify Davenport for claims arising from the accident. On October 30,
1996, the district court granted summary judgment in Avemco's favor. The
district court held that the Policy Exclusion applied because Davenport had
not recertified his aircraft after he modified its fuel system without
notifying the FAA. Davenport now appeals.
II.
We review the district court's grant of summary judgment de novo. Wendt v.
Host Int'l Inc., 125 F.3d 806, 809 (9th Cir. 1997). Summary judgment is
appropriate if there is no genuine issue of material fact and if the movant
is entitled to judgment as a matter of law. See Fed. R. Civ. P. 56(c).1
Under California law, the language of a contract governs its interpretation
"if the language is clear and explicit, and does not involve an absurdity."
Cal. Civ. Code S 1638. "[I]f the meaning a layperson would ascribe to
contract language is not ambiguous, we apply that meaning." AIU Ins. Co. v.
Superior Court (FMC Corp.), 799 P.2d 1253, 1264 (Cal. 1990). Exclusionary
language that limits coverage under an insurance policy must be conspicuous
and phrased in clear language. Hertz Corp. v. Home Ins. Co., 18 Cal. Rptr.
2d 267, 273 (Cal. Ct. App. 1993).
[1] We hold that the language of the Avemco policy clearly excluded coverage
in this case. The Policy Exclusion stated that Davenport's aircraft would be
covered only if it was certified for flight "after a modification which
requires recertification." Avemco Policy at 3. This language explicitly
premised coverage on Davenport's compliance with FAA restrictions. These
restrictions included an operating limitation that required Davenport to
notify the FAA upon making a change that could affect the "reliability,
operational characteristics, or other characteristics affecting the
airworthiness of the [aircraft]." 14 C.F.R. S 21.93(a). Davenport's failure
to notify the FAA prior to his initial modification of the fuel system
violated the operating limitation on his airworthiness certificate and
prohibited Davenport from operating the aircraft without recertification.
See 14 C.F.R. S 91.9(a) (1993) ("[N]o person may operate a civil aircraft
without complying with the operational limitations . . . prescribed by the
certificating authority of the country of registry."). Davenport's failure
to notify the FAA of his repeated modifications to his aircraft's fuel
system clearly triggered the Policy Exclusion and released Avemco from any
obligation to indemnify Davenport.
[2] Davenport argues that the series of modifications he made to his
aircraft's fuel system did not constitute a "major change" because the fuel
system at the time of the crash was in the same configuration as at the time
of the initial certification. We reject this argument. Common sense dictates
that altering the method of delivering fuel to the engine of an aircraft has
an obvious and substantial effect on the "reliability, operational
characteristics, or other characteristics affecting the airworthiness of the
[aircraft]." 14 C.F.R. S 21.93(a).2 The fact that Davenport made repeated
changes to the fuel system did not remedy his failure to notify the FAA
prior to making each change. Each change Davenport made to the fuel system
was major, and each change therefore required FAA notification under the
operating limitation.
Davenport also argues that the Policy Exclusion was vague and ambiguous, and
that it should therefore be construed to allow coverage. "[W]ords in an
insurance policy must be read in their ordinary sense, and any ambiguity
cannot be based on a strained interpretation of the policy language. "
Producers Dairy Delivery Co. v. Sentry Ins. Co., 718 P.2d 920, 925 (Cal.
1986). Furthermore, the "language in a contract must be construed in the
context of that instrument as a whole, and in the circumstances of that
case, and cannot be found to be ambiguous in the abstract." Bank of the West
v. Superior Court (Industrial Indem. Co.), 833 P.2d 545, 552 (Cal.
1992)(quotations and emphases omitted).
[3] We find no ambiguity in Davenport's policy. The policy clearly linked
Avemco's coverage to the continued validity of the FAA's certification of
Davenport's aircraft. Because California courts do not find ambiguity in
exclusions that similarly incorporate FAA requirements by reference, see,
e.g., Threlkeld v. Ranger Ins. Co., 202 Cal. Rptr. 529, 532 (Cal. Ct. App.
1984), we will not do so here.
[4] Davenport finally argues that, even if there is no duty to indemnify,
Avemco owed Davenport a duty to defend against pending state suits. Although
the duty to defend is broader than the duty to indemnify, see Horace Mann
Ins. Co. v. Barbara B., 846 P.2d 792, 795 (Cal. 1993), no duty to defend
arises if the undisputed facts establish that the insured is not entitled to
coverage. Montrose Chem. Corp. v. Superior Court (Canadian Universal Ins.
Co.), 861 P.2d 1153, 1159 (Cal. 1993) (agreeing with lower court that,
"where extrinsic evidence establishes that the ultimate question of coverage
can be determined as a matter of law on undisputed facts, [there is] no
reason to prevent an insurer from seeking summary adjudication that no
potential for liability exists and thus that it has no duty to defend."
(quotation omitted)). Because the facts viewed in the light most favorable
to Davenport could not have established coverage under the policy, Avemco
was entitled to summary judgment on Davenport's allegation of a duty to
defend.
Accordingly, we affirm the judgment of the district court.
AFFIRMED.
________________________________________
1 Because diversity jurisdiction exists in this case, the district court
could hear Avemco's declaratory judgment action in its discretion. See 28
U.S.C. S 2201(a). Because there was no objection to the district court's
exercise of its discretion in hearing this case, and because we do not find
extraordinary circumstances that warrant an independent inquiry by this
Court, we will not review the district court's exercise of its discretionary
jurisdiction. Government Employees Ins. Co. v. Dizol, 133 F.3d 1220, 1224 &
n.4 (9th Cir. 1998) (en banc).
2 Indeed, in an analogous regulation applying to the maintenance and repair
of non-experimental aircraft, the FAA has defined major alterations as
including "[c]hanges to the basic design of the fuel . . . system[ ]." 14
C.F.R. S 43 app. A(a)(1)(xii).
