dlm46007(at)cox.net Guest
Posted: Thu Jan 29, 2009 12:52 pm Post subject: heads up |
When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident..
billderou(at)yahoo.com Guest
Posted: Fri Jan 30, 2009 8:52 am Post subject: heads up |
This is why we always have the tail tie-down ring installed.
Bill DeRouchey
N939SB
--- On Thu, 1/29/09, David McNeill <dlm46007(at)cox.net> wrote:
Quote: | From: David McNeill <dlm46007(at)cox.net>
Subject: heads up
Date: Thursday, January 29, 2009, 12:39 PM
| [quote][b]
Phil.Perry(at)netapp.com Guest
Posted: Fri Jan 30, 2009 11:58 am Post subject: heads up |
Scott Schmitt has the same thing happen to him.
We need a kickstand.
From: Bill DeRouchey [mailto:billderou(at)yahoo.com]
Sent: Friday, January 30, 2009 10:32 AM
Subject: Re: heads up
Bill DeRouchey
N939SB
Subject: heads up
| [quote]
href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
scottmschmidt(at)yahoo.co Guest
Posted: Fri Jan 30, 2009 1:27 pm Post subject: heads up |
This has happened to many of us early on and was posted multiple times but it is good to repeat from time to time as it is sometimes difficult to read all the posts.
My standard for loading is one person in back, one in front, then the second in back and finally the pilot.
The issue arises when you have two in back and two people step up at the same time. That is like having two guys in the baggage compartment and two in the back seats.
I also de-plane the same way. Also keep your tie-down in at all times. I have had it tip one other time but it just hit the tie down ring like previously mentioned.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Friday, January 30, 2009 9:32:03 AM
Bill DeRouchey
N939SB
Subject: heads up
| [quote]
Tim Olson
Posted: Fri Jan 30, 2009 2:57 pm Post subject: heads up |
It's actually really old news, going back all the way to the beginning
of customer built RV-10's flying. There are at least maybe 8 or 10
that I know of that cracked their rudder fairings by doing this.
Just don't put two people on the steps at the same time, or don't
load the plane and put two passengers in the rear seats and then
go bounding on to the steps and you should be ok. But it does
take some remembering to be careful.
Perry, Phil wrote:
*From:* Bill DeRouchey [mailto:billderou(at)yahoo.com]
*Sent:* Friday, January 30, 2009 10:32 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: heads up
Bill DeRouchey
N939SB
--- On *Thu, 1/29/09, David McNeill /<dlm46007(at)cox.net>/* wrote:
Subject: heads up
Posted: Fri Jan 30, 2009 4:44 pm Post subject: heads up |
If you leave the tail tiedown loop in does it stop the fairing from hitting?
Sent via BlackBerry by AT&T
Kellym
Posted: Fri Jan 30, 2009 5:19 pm Post subject: heads up |
Well, some transport aircraft have retractable tail skids, more to
prevent a hit from over-rotation. Wouldn't be surprised if a DC8-62
needed something, given how long it is.
Bill DeRouchey
N939SB
Subject: heads up
KCHD |
Posted: Fri Jan 30, 2009 6:45 pm Post subject: heads up |
we used to fly a 747 combi DHA-AMS-IAH. Always at the AMS refueling, the announcement was made to remain seated until the tail stand was installed
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Friday, January 30, 2009 12:26 PM
Subject: RE: heads up
Bill DeRouchey
N939SB
Subject: heads up
| [quote]
Posted: Fri Jan 30, 2009 7:23 pm Post subject: heads up |
This can also happen when loaded at the aft CG and burning off a lot of your fuel, then taxiing across uneven ground (ie. parking fields at Oshkosh). Note that even a tie-down ring won't save your rudder bottom fairing when on grass. When loading near gross, we always load baggage, then load copilot seat, then rear seats, then pilot last. I've never seen it hit the tail with someone in the front seat. We also make it a rule not to ever use both steps at the same time as already mentioned.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 30, 2009, at 4:07 PM, Scott Schmidt wrote:
Quote: | This has happened to many of us early on and was posted multiple times but it is good to repeat from time to time as it is sometimes difficult to read all the posts.
Scott Schmidtscottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
From: Bill DeRouchey <billderou(at)yahoo.com (billderou(at)yahoo.com)>
Bill DeRouchey
N939SB
--- On Thu, 1/29/09, David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
Quote: | From: David McNeill <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Subject: heads up
daveleikam(at)wi.rr.com Guest
Posted: Fri Jan 30, 2009 9:05 pm Post subject: heads up |
After having read about this before, I will probably mount a small piece of spring steel in the shape of a "U" at the tie down point using the tie down ring to hold it in place. Haven't decided where to get the spring steel yet, but that's my thought.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
Kelly McMullen
Posted: Sat Jan 31, 2009 7:08 am Post subject: heads up |
You can see that setup on many a Cessna, combo tail skid and tiedown
ring. Heck, even my Mooney has a tail skid. Helps when pilot gets
confused and tries to land it like a taildragger.
On Fri, Jan 30, 2009 at 9:45 PM, Dave Leikam <daveleikam(at)wi.rr.com> wrote:
[quote] After having read about this before, I will probably mount a small piece of
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
A&P/IA, EAA Tech Counselor
KCHD |
